Acceleration - how hard?
Old 02-28-2009, 06:11 PM
Eddles's Avatar
Eddles Eddles is offline
Simple question. How hard should I accelerate? As my FE is nearly zero when accelerating, the logical conclusion is to accelerate as hard and as fast as possible to my desired cruising speed, obviously assuming there is nothing in front of me, e.g. traffic lights, possible events that I will need to slow down for. But this sounds like a whole load of fuel would be used up, or is it just being counter-intuitive?
Or is my logic faulty, and I should be accelerating as gently or possible? Or somewhere in between?
Thanks very much for your time in advance!
Old 02-28-2009, 06:19 PM
abcdpeterson's Avatar
abcdpeterson abcdpeterson is offline
Re: Acceleration - how hard?
I have read a lot of people recommending engine load around 80, and shift around 2k.
I have found load in the 70’s and keep rpm’s under 2150 works best for my car.
-Allen
Old 02-28-2009, 06:29 PM
diamondlarry's Avatar
Super MPG Man/god :D
I think I'm with Allen on this one. Moderate acceleration seems to give me the best results. I've been thinking about doing some calculations on how much fuel is burned overall during a pulse. I would be using the GPH feature of the Scanguage and a stop watch to see how much fuel is burned to go from a lower target speed to a higher target speed during my P & G routine.
Old 03-02-2009, 08:50 AM
PaleMelanesian's Avatar
Beat The System
Call me a salesman for Autospeed.
http://www.autospeed.com/cms/A_110216/article.html
Andrew
Old 03-02-2009, 09:45 AM
that artical is great,
a lot to understand on a 1st read, I find my self rereading that one every month or so.
-Allen
Old 03-02-2009, 10:47 AM
jimepting jimepting is offline
Vehicles: Honda Insight 1 MT
It is indeed a GREAT article. I've read it several times and I have a general understanding - I think. But, I am always left with some of the same questions. The main question I have is, how do we apply the article results to our individual cars. The article clearly indicates that best BSFC is going to occur at different loads and different RPM for different cars. In other words, there are different graphs for each car. How do we figure out, except in a very general sense, what the graph looks like for our own cars.
It would seem that one could gather experimental data with the SGII on GPH times time, as diamondlarry proposes. By doing that at different loads, one could graph the results and spot the optimum. As in all testing, a level road and a windless day would be required. In his case, it would seem that the electric assist might complicate the results, but I know very little about Prius.
Old 03-02-2009, 10:51 AM
Beat The System
My personal experience shows the rainbow colored chart to be fairly accurate for my car.
There's also a thread at ecomodder where people post whatever charts they've found. http://ecomodder.com/forum/showthrea...-got-1466.html
Andrew
Old 03-02-2009, 12:42 PM
Yow Andrew, you are just a fount of great information! The 1.0L Metro engine is one of the engines I was most interest in an there is the info I was seeking. I do note from the chart that the "sweet spot" is very narrow in terms of torque, or load, so driving a 1.0L Metro in the sweet spot, over a wide range of conditions, is gonna be very difficult. Installing the long gear and doing a lot of shifting would probably be required. I think some experimentation, as diamonlarry suggests, would help nail the actual load, but without SGII capabilities, even that approach has problems.
The site you ref has no info on other cars so apparently this type of vehicle specific information is hard to come by.
Old 03-02-2009, 03:53 PM
steveyfrac steveyfrac is offline
The map from autospeed is exactly what i was thinking should happen. Lower gear, and higher throttle increases peak cylinder pressure, which tends to improve thermodynamic efficiencies of any cycle. Nice to have suspicions confirmed. Thanks for the post.
Old 03-02-2009, 10:08 PM
hummingbird hummingbird is offline
So what is the practical implication of this article for me? Is it better to floor it while pulsing? Does this not go against the adage "accelerate like a granny"?
Adapting Basic Hypermiling Techniques to the HCH-II tarabell Articles 90 11-19-2010 09:29 PM
Acceleration Rates 87LX Fuel Economy 8 11-01-2008 11:20 AM
I Need help with Acceleration, or new improved Scangauge? abcdpeterson Fuel Economy 6 08-14-2008 09:01 PM
Optimal Acceleration AT&MT - Gas only Tweakfreak Fuel Economy 11 08-01-2008 07:05 PM
