Go Back   CleanMPG Forums » Modding and Hardware » Technical
Technical Technical discussion on HW and SW mods with the intent of increasing performance and/or fuel economy.
Civic aero mods - grill block and wheel covers
Old 02-09-2009, 01:39 PM
PaleMelanesian's Avatar
Beat The System
Mod 1
A new upper grill block, made out of plexi glass. The old one was pieces of foam mat stuffed into the cracks. It blocked airflow, but wasn't smooth or aerodynamic on the outside. Since this grill is near the top and angled up, smoothing the airflow makes sense.
Before - see the upper grille. The lower is unchanged.
After. It's attached with "utility wire" looped and twisted through holes and through the factory grill. 3 attachment points - 2 top corners and 1 bottom center.
Side view to show the smooth surface
Mod 2
Smooth wheel covers made from coroplast - cleaned up some campaign signs back in November. (mccain-palin for the best aerodynamic benefit ) The new ones are flush with the bulge in the sidewall, compared to the old ones that stuck out a good inch in the center.
Before - nice air-churning 5-spoke hubcaps
After:
3 pieces of wire looped through the holes in the steel wheel and twisted together to hold it on. Also, a hole for access to the valve stem - if I can't get to it easily, I know I'll neglect the air pressure.
The new look, completed.
Andrew
Old 02-09-2009, 01:45 PM
kendan's Avatar
kendan kendan is offline
Mid TN Hypermiler!
Vehicles: 1995 Mitsubishi Mirage, 2001 Hyundai Elantra
Re: Aero mods - new grill block and wheel covers
Looks good...I hadn't thought about using wire looped front to back to attach these mods. Having any trouble overheating?? I did just lower grill and so far, no problems. Guess I'll try the wheels next...thanks for sharing!
Old 02-09-2009, 01:48 PM
Beat The System
It was already fully blocked. This makes it more aerodynamic. In the heat of summer, I can pull out 1/4 or 1/2 of the lower block and keep things cool. This is a very cool-running engine, and the lower opening is HUGE. The radiator only covers 1/2 of the grill opening. Unless I'm using the AC (never!), I can leave the other side fully covered at all times.
Andrew
Old 02-09-2009, 02:06 PM
Right Lane Cruiser's Avatar
Penguin of Notagascar
Nice work, Andrew!
- Sean
New? Start here!
Old 02-09-2009, 02:26 PM
SlowHands's Avatar
SlowHands SlowHands is offline
Hypermiling Ironman
Vehicles: 96 Ranger 5MT, 98 Ranger AT, 92 Ford Van AT
Nice work Andrew! I like the clear plexiglass... stealthy
Old 02-09-2009, 02:27 PM
WoodyWoodchuck WoodyWoodchuck is offline
Sophomore Hypermiler
Vehicles: 08 Yaris LB M5
Very nice! I have my grill block on with 12 gauge wire also for fairly easy on/off. Never thought about the wheel cover with it but that’s the next project now. Great idea, thank you.
Lifelong log
Winter Challenge
Old 02-09-2009, 03:19 PM
bestmapman's Avatar
bestmapman bestmapman is offline
Vehicles: 2010 Toyota Prius, 2009 Kawasaki C-14
Very nice Andrew.
Drivin slow in the FAS lane.
Old 02-09-2009, 05:52 PM
abcdpeterson's Avatar
abcdpeterson abcdpeterson is offline
I have been thinking about improving my grill block. Nice to see how well it looks on your car, as I am thinking of Posabley doing Plexiglas also.
Thanks for sharing the nice photos!
-Allen
Old 02-09-2009, 07:53 PM
msirach's Avatar
msirach msirach is offline
Looks slick!
Old 02-09-2009, 11:34 PM
MnFocus's Avatar
MnFocus MnFocus is offline
hanging member :)
Vehicles: 1996 Honda Civic HX
slick and well timed
~ Rick
My aero grille block and wheel covers 99LeCouch Technical 11 03-18-2009 12:15 AM
Aero Wheel Covers? 99LeCouch General 4 02-12-2009 03:22 PM
2006+ Honda Civic Grill block, and a funny smell mtbiker278 Honda 1 11-11-2008 09:08 AM
Prototype grill block/wheel fairings chilimac02 General 5 09-01-2008 09:46 PM
Added more aero mods to my 92 Civic hatch...results, 79MPG basjoos Fuel Economy 19 08-09-2006 03:58 PM
