| ScanGauge Anything ScanGauge related is open for discussion here. |
Why is there MAP?
02-05-2009, 06:32 AM
Why is there MAP?
MAP = Manifold-Absolute-Pressure = Indicates the pressure in the intake manifold
Why would there be pressure on the intake side?
The air is being pulled in, shouldn't that result in negative pressure?
Arent vacuum lines taken off the intake side?
I can see Pressure with a turbocharged as it pushes air in.
-Allen
02-05-2009, 07:14 AM
Kaizen Driver
Vehicles: 2002 Toyota Corolla Verso 1.6 VVT-i Manual
Re: Why is there MAP?
That's exactly why it is MAP. Absolute pressure means pressure as compared to the only stable pressure comparison: perfect vacuum.
The other alternative would be amount of negative pressure compared to ambient at startup,
and thus would change during your drive.
02-05-2009, 07:28 AM
Reformed speeder
Yup, exactly. To expand on this a bit, normal atmospheric (barometric) pressure at sea level is around 14.4psi. The engine may pull a vac relative to this but the manifold pressure cannot be <0, since 0 is a perfect vacuum. At wide open throttle, the MAP sensor will read close to the atmospheric pressure.
Atmospheric pressure decreases with altitude and other factors. The MAP sensor is one way of calculating the air mass going into the engine so that the fuel delivery can be adjusted appropriately.
When people talk about manifold vacuum, they mean vacuum relative to atmospheric pressure.
02-05-2009, 07:31 AM
Thanks!
I know it's going to be a good day, when the day starts with new knoledge.
I added MAP to scangauge, it never reported anything. is MAP not always reported?
-Allen
02-05-2009, 07:36 AM
Penguin of Notagascar
Not all vehicles have that sensor.
- Sean
New? Start here!
02-05-2009, 07:44 AM
Reformed speeder
Not sure if this is true of the Vibe (which is a rebadged Toyota Matrix??), but as I understand it most GM cars use a MAF (Mass Airflow Sensor) which indirectly measures air flow rather than pressure. Don't know how OBD handles this, but MAF might be reported on a different channel from MAP and you would therefore get no reading on MAP?
More info here:
http://en.wikipedia.org/wiki/Mass_airflow_sensor
I'm not an expert so I may be wrong here??
02-06-2009, 04:30 AM
Kaizen Driver
My car, which is of the same platform as Matrix, Vibe etc reports only LOAD too.
No MAP, MAF nothing.
But I notice LOD is very similar to MAP 99 when stopped, and down to 7-8-9 when dfco at high rpm.
