Energy to build a car?
Tags: ,
Old 12-21-2008, 03:00 PM
Ebeo1 Ebeo1 is offline
Vehicles: 1968 mercury cougar
Looks to me like a number of people here have traded in there vehicles for a more economical and ecological ride. I can understand there is a lot of immediate gain when comparing an I4 compact car to a monstrous V8 truck at the gas pump and exhaust pipe. When a car is built there must be an enormous amount of energy that goes into the harvesting of the natural resources, processing, transporting, manufacturing, and toxin by products. The more non-immediate gains to the earth by keeping your current vehicle must by far out weigh buying a new one.
I know this not a black and white argument but a 1997 car getting 25 mpg must be more "earth" ecological from all the factors stated above than a new 2009 hybrid getting 65 mpg. The average American switches cars every 4 years so in the 1997 vs 2009 if you were to buy a new car every four years you would have gone through three cars and all the energy to get them to your local dealer. A little old grandma driving her 1988 V8 oldsmobile 4 times a week and the hypermiler commuting 60 miles daily might burn the same amount of gas but is the negative effects to the environment from combustion enough to warrant grandma buying a new car?
How much energy does manufacturing a new car take?
How many gallons of gas do you need to save before this number is off set?
Old 12-21-2008, 04:50 PM
donee donee is offline
Vehicles: 2006 Prius
Re: Energy to build a car?
Hi Ebeo1,
Argonne National Labs and other researchers (specifically at MIT) have evaluated this issue.
The Prius specifically was evaluated. Here is the two-bit description of the research results. Typical cars used 20 % of their total life cycle energy for production, and consumed nearly all the remaining 80 % as fuel energy. The Prius requires about 1.5 times as much energy to make as a standard car of the same passenger capacity (4 adults). But, it uses about 1/2 the energy to operate. So, using percentages of a standard car, that is 30 % to produce, and 40 % to operate, for a total only 70 % of lifetime energy consumption of a standard car the same size. Another way to look at it is the balance point, how much lifetime of the cars is when they have consumed equal energy. 10% extra energy is used to make the Prius. If 80 % of standard car energy consumption is used in 125K miles of operation , and the Prius uses 40 % of the standard car total energy to operate for 125K miles, then algebra can be applied. It works out to 31.25K miles. Both cars driven that far have used the same total amount of energy. After which the Prius will use less energy than the standard car. The extra energy to make the Prius is totally recouped on only 31.25 K miles of operation. Since the Prius lasts 125K miles (at least), then 93.75 K of those miles the car has used less total energy than a standard car.
Its apples-to-oranges to compare the short range grandma Olds to the long range Hypermiler. As the grandma typically does not generate as much total product for society in that same week. I am in the 50 miles (daily) comute sitatuion. I use about 4.5 gallons of gas per week in my Prius. Grandma driving short distances, is not getting that big cast-iron V8 warmed up, so probably gets 10 mpg (15 mpg warmed up). If she were to drive more than 45 miles in a week, she would be using more gas than me in the same period. That equates to a 11.25 miles for each of those 4 days. 45 miles is less than 1/5 the distance (.18 actually) I get on the same gas. So by these numbers, I can use less energy, and dispense less CO2 in my Prius driving 250 miles a week, than grandma in her Olds V8, if she drives 45 or more miles each week. The numbers would be allot different if grandma was driving a Ford Focus - maybe grandma can drive 100 miles per week (25 miles a day) before she polutes more than me.
Additionally, not all jobs are available in every neighborhood. But all jobs need to be done. So, people end up communting some distance not because of the desire for an inexpensive luxury house, in a town with good schools, but some end up in a situation where moving would be more energy intensive, let alone expensive, than the longer commute. In the end, there is no excuse for any of us, in whatever driving range to not be careful about what resources we use, and act to minimise that usage.
The 1997 car is probably more ecological only if one assumes its life cycle is over, and one is remanufacturing the car, and only using the remanufacturing energy against the original production energy of the ecological car. The remanufactured 1997 standard car will be cheaper, because, well the dollar bought more energy of production in 1997, and remanufacturing uses allot less energy and very small fraction of the original materials. But cheaper does not mean more ecoological in this situation. If you compare the original 1997 production energy and fuel consumption, against the 2004 Prius, well, the Prius is more ecological. If the 2004 Prius was made in 1997, one would see this clearly.
Old 12-21-2008, 05:33 PM
Right Lane Cruiser's Avatar
Penguin of Notagascar
To quote a prominent phrase here on the site, "Learn to raise fuel economy and lower emissions in whatever you drive" -- loosely translated by some members as, "Dance with the girl you brung."
Your point is well taken in that in many cases you are better off doing what you can with what you have (considering environmental impact), and that is pretty much what I've done with my '02 Elantra (last tank at 65.2mpg). I did buy an Insight nearly a year ago, but I can't justify that in terms of cost savings. For me the car was definitely a "want" purchase, but two things tempered that. First, the car is actually worth more now than when I bought it and it will continue to retain or even appreciate in value as the price of fuel rises. Second, if things get really bad, I'll still be able to afford to drive when many may not.
I do have plans to get another vehicle in the next several years, but the point of that purchase would be a full electric vehicle with long AER which I would then keep for much longer. I expect both my vehicles to be over 10yrs old by then and to have been hypermiled to way lower consumption values than the average driver would accomplish with either.
As Donee pointed out though, there are valid reasons for purchasing a more efficient vehicle. Aside from the reasons he listed, there is also the increased safety equipment and reliability aspects to consider. This is why I sold my '95 Elantra back in '02 and bought my current Elantra (which is holding up WAY better than that vehicle did, I should add).
- Sean
New? Start here!
Old 12-21-2008, 07:02 PM
peacefrog_0521's Avatar
peacefrog_0521 peacefrog_0521 is offline
Raj Against The Machine
I think this is a very interesting question, though I must admit it's a bit bit academic, much like question of whether greenhouse gas emissions through the use of plug-in hybrids are increased by shifting the emissions from vehicles to powerplants.
And as a caveat: if we bought based on which manufacturers were most efficient, we'd all be buying Chrysler vehicles. They were found to be the most efficient manufacturer (even more so than Toyota or Honda) in terms of hours per vehicle.
I doubt anyone would buy the argument that one is "going green" by driving a Chrysler ...
Old 12-22-2008, 07:34 PM
xcel's Avatar
xcel xcel is online now
___Here is Toyota's numbers for North American production as I am doing a write-up on their 08 Environmental report currently...
Total energy usage of manufacturing facilities/operations in North America = 6.6 MMBTU/vehicle produced.
Old 12-22-2008, 09:14 PM
NiHaoMike NiHaoMike is offline
But what kind of energy is used? Obviously, solar or hydroelectric power would be less of an impact than fossil fuels.
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
I wish I was more skinny like Allie Moore... for more MPGs!
Old 12-22-2008, 09:52 PM
xcel's Avatar
Hi NiHaoMike:
___That is the average and changes as a given plant or non-production facility receives more renewable energy inputs as time goes by. Reading deeper into the 08 Toyota report, the number appears to be more along the lines of 6.9 MMBTU/vehicle produced through the end of this year.
Old 12-23-2008, 12:50 AM
xcel's Avatar
___I still have a few more hours on the Toyota Environemental Report synopsis before it is ready but here is the energy consumed per vehicle from Toyota directly. I hope this helps...
Old 12-28-2008, 08:17 AM
jkp1187's Avatar
jkp1187 jkp1187 is offline
Vehicles: Ides of March, 1970
Originally Posted by donee View Post
Hi Ebeo1,
Argonne National Labs and other researchers (specifically at MIT) have evaluated this issue......
Donee, that's very interesting. Do you have a citation or link for this study?
Old 01-02-2009, 01:00 PM
some_other_dave's Avatar
some_other_dave some_other_dave is offline
Vehicles: 2012 MINI Cooper
I'm having fun hypermiling my 1990 model year car...
I'm only capable of around 40 MPG so far, but that's still 30%-50% better than most new cars driven by "average" people, so I figure I'm pretty far ahead on the game there.
Plus it's been paid for, and has been for many years.
-soD
Press Roundtable - U.S. Energy Secretary Bodman & U.S. Agriculture Secretary Johanns xcel In the News 2 09-10-2006 02:03 PM
Texas shows off its energy diversity. xcel In the News 0 07-30-2006 10:01 PM
The best car to buy for your (Teen) tigerhonaker Honda 3 06-17-2006 12:24 AM
Energy independence is a disaster in the making. Valleyforge In the News 12 03-04-2006 08:15 AM
