| Ford Escape Hybrid Everything and anything relating to the Ford Escape or Mercury mariner Hybrid. |
Anyone doing a grill block for FEH?
11-10-2008, 10:12 AM
Vehicles: 2008 Ford Escape Hybrid
As it is getting colder here in S. California. i was wondering if anyone is doing or thinking about a grill block. or even if it is a good thing or not. It is just taking alot longer for my FEH ice to cut off.
Any advice or suggestion short of a heater?
Thank,
hybrid_tkm
11-10-2008, 12:36 PM
Still Learning
Vehicles: 07 FEH, 94 Trek 720
Re: anyone doing a grill block for FEH?
I was contemplating that just this morning as we had our first sub-freezing morning commute today. It was 27 degrees and the old FEH was having a hard time warming up.
I'm going to first try the two-piece cardboard method, but I haven't decided how to fasten it yet. I would really like to find some black cardboard to match the exterior paint color, but I might just use a quick coat of spray paint instead. I have read that it is important to be able to easily remove the grill block if the fWT gets too high on the sgii and that it works best if it is close to the radiator, so those two things will be my guide to piecing this together.
I definitely think its a good thing, as long as you watch the fWT and keep it under 210 degrees.
I would be interested to know what you end up doing as well.
- Rob
-Rob
| FEH: 65.0 MPG - 14.0 mile commute | | 45.598 MPG - best tank | | 615 miles - longest tank |
11-10-2008, 01:34 PM
C'est quoi 'hypermile' en Francais?
Vehicles: 2006 Toyota Yaris LB Auto
I've done a near-complete grill upper grill block on my Yaris, and while I haven't noticed much of a temperature change (from 188 without to 198 with), my warm-up time and MPG has stayed rather constant even with the advent of the cold spells.
-Jaume
Hop Suisse!
11-12-2008, 02:24 AM
Vehicles: 2007 Ford Escape Hybrid
I've done a grill block on my '07 Escape. It blocks the upper part of the grill and extends down to behind the bumper while leaving the lower portion below the bumper to have air circulate. I did this last spring and have left it on. It sits up against the radiator. The temps have stayed below 190 deg. Living in Chicago I get all sorts of temp shifts. It looks so good that the Ford techs have not noticed it while doing oil changes last year.
If I could figure out how to post pics I'd post some.
11-12-2008, 10:03 AM
Lone Ranger,
If you coudl get pics that would be great. also what and how did you make it from> and attach it??
Thanks
hybrid_tkm
11-12-2008, 10:12 AM
ФЕХ Царйца
Vehicles: 2005 Ford Escape Hybrid FWD
I keep the top portion of my radiator blocked year-round. My "system" is *very* low-tech, if not downright dorky  - I "recycle" cardboard from our mailing room, cut it to fit in front of the grill, inside of the "U" of the bumper. Then I wrap it in clear packing tape, add my "Ask me about my Ford Escape Hybrid" sign (same as what's on my t-shirt  ), cover *that* with the same tape, & tape it to the front of the grill. It holds up surprisingly well in rain & snow, & when it gets too bad, I just make another one  I do take it off if I have to go to the dealership
This summer, I tried something different - instead of doing the whole cardboard thing, I just put the clear packing tape over the grill. It seemed to work as well in the warmer weather as the cardboard
Purrs,
Debbie
I  my FEH
11-12-2008, 02:34 PM
Still Learning
I like the clear packing tape idea. So you are just putting that on the outside of the grill and tucking it into the edge? Did you find extra wide or just in multiple strips? Got any pictures to share?
-Rob
11-12-2008, 03:18 PM
ФЕХ Царйца
Actually, I wasn't being that elegant about it - just cutting strips of tape a little longer than the grill, with maybe an inch or so on the bumper itself (I have the non-painted bumpers).
Multiple strips of 2" wide tape.
Unfortunately, I have the cardboard on now, but I think I can send a photo of that
Purrs,
Debbie
I  my FEH
11-12-2008, 05:05 PM
Originally Posted by escape_tkm
Lone Ranger,
Thanks
I'll take some pics and try and post them. If I can't post them send me your email and I'll attach them, I can do that. I am so not computer savvy when posting pics on the web.
11-13-2008, 07:29 PM
Still Learning
