Go Back   CleanMPG Forums » CleanMPG Topics » Fuel Economy
MPG Difference with H or T-rated Tires
Tags: ,
  #1   Submit to Clesto Submit to Digg Submit to Reddit Submit to Furl Submit to Submit to Spurl
Old 10-23-2008, 10:55 AM
greenrider's Avatar
greenrider greenrider is offline
Vehicles: 2006 HCH II w/ Navi, 2010 Honda Insight II EX w/Navi
I'm about to buy Nokian WR G2s for my HCH II and have a question regarding speed ratings. Obviously, differently-rated tires have higher or lower speeds, depending on the rating. As for the different ratings, are the compounds they are constructed from different and would a lower or higher rated tire perform better from a fuel economy and LRR standpoint? Speed isn't a concern, but MPGs and winter handling are big issues up here in northern Illinois.
Thank You!
  #2   Submit to Clesto Submit to Digg Submit to Reddit Submit to Furl Submit to Submit to Spurl
Old 10-23-2008, 12:38 PM
Showbizk's Avatar
Showbizk Showbizk is offline
Vehicles: 04 WRX Sport Wagon; 08 Hyundai Veracruz
Re: MPG Difference with H or T-rated Tires
It's a bit embarrassing that I work for the largest tire co. in the world, and AFAIK, no tire manufacturer publicizes (and maybe doesn't even test) rolling resistance (RR) for their tires. I also know however that my company is designing tires for lower RR. I found some information here that will be helpful, I think...
"It's crackers to slip a rozzer the dropsy in snide!"
  #3   Submit to Clesto Submit to Digg Submit to Reddit Submit to Furl Submit to Submit to Spurl
Old 10-23-2008, 01:07 PM
voodoo22 voodoo22 is offline
Cheaper than the bus
Vehicles: Yaris Sedan (auto)
I can't give you the kind of feedback you're asking for, but I can tell you that I bought a set of Nokian rSI's last year and got fantastic mileage and amazing traction with them. I will continue to buy Nokians until I have a bad experience, that's how impressed I am with them. It was the 2nd worst winter on Toronto's record for snow and ice and I literally could not make the ABS kick in when I tried. Only once all year did I lose any traction at all and ABS kicked in. One day in several inches of snow I was easily passing everyone the the tires just wouldn't slip and took the car where ever I pointed it. One day at a uphill redlight with a ridge of snow in front of my car left behind by the snow plow I pulled away from an Explorer which stuggled to get through the ridge. Amazing tires.
I consistently got over 44 MPG with these aggressive winter tires which are supposed to be somewhat LRR and are R rated and I was not driving as disciplined as I do now.
My personal opinion is you'll be very happy with the performance of your Nokians if they are made with the same quality as the ones I purchased last year.
  #4   Submit to Clesto Submit to Digg Submit to Reddit Submit to Furl Submit to Submit to Spurl
Old 10-24-2008, 07:21 AM
CapriRacer CapriRacer is offline
Vehicles: 1973 Capri - 3 of them, 1998 Taurus, 1987 E-150, 2005 Mercury Milan
OK, here's the deal:
ALL OTHER THINGS BEING EQUAL, an H rated tires will have more RR than a T rated tire. This is because an H rated tire will almost certainly have a cap ply, where a T rated tire will probably have just cap strips. This means the H rated tire will have more material in the tread area - and more material means more RR.
ADDITIONALLY, H rated tires tend to be designed for better handling, and the tread rubber compounds would be grippier and that also negatively impacts RR.
BUT, higher speed rated tires are also more capable, so the risk of a tire failure is lower with an H rated tire than a T rated tire.
But these are generalizations and you will find there are a lot of factors involved. You could get different results unless you pay attention to the details.
Reducing speed to save fuel nkc Fuel Economy 67 05-19-2008 06:45 AM
Lacey, WA Roadtrip (new pics) bestmapman General 12 05-09-2008 10:14 PM
The spin on tires and fuel economy atlaw4u In the News 9 05-07-2008 09:51 AM
My very own trip MPG calculator pdk Fuel Economy 7 04-16-2008 07:39 PM
Time to Label Tires for Rolling Resistance philmcneal Fuel Economy 7 04-10-2006 07:55 PM
