I am surprised nobody has mentioned installing a manifold vacuum guage. These cheap devices used to be common and give you an instant and accurate indication of your fuel usage and teach the correct driving techniques on the job. There have also been simpler devices that take the same information and indicate when to shift a manual transmission, but they miss a lot of important signals.
By PanamaJohn | Aug 5, 2006 10:35:03 AM |
Request Removal
___________________________________________
Hey I have always wondered whether larger than recommended tires would help increase your MPG. Will it? Thanks.
By tmccarty | Aug 5, 2006 7:07:23 PM |
Request Removal
____________________________________________
I get 43 miles per gallon on my Impala instead of 30 mpg by coasting, driving at 55-60 mph. Also I get a lot of honking from irate drivers.
By jaihariom | Aug 5, 2006 7:46:34 PM |
Request Removal
_________________________________________________ Good points all. I mounted full-size tires on my 02 Ford Ranger. Theyve 5 more circumference thus, I get 1 more mile every 20 on the odo. Compensating for that and adding in the increase, I find Im getting 24.5 mpg on this 6 cyl truck instead of the original estimated 20 highway mpg. A lot of older cars trucks are under-tired and would fare better at the pump if they used the largest tires applicable.
By geoanon10 | Aug 5, 2006 8:03:18 PM |
Request Removal
Crappy article. The writer is not very intuitive about emgines etc. Btw shutting off your engine to coast is a thing you may try once, just to get the thrill of a locked steering wheel in a moving vehicle - super dumb! I do not believe the claims, certainly not by the techniques described. I drive as efficiently as possible albeit not slow, I hardly ever touch the brakes, and I get 28 mpg in my 94 Accord. PanamaJohns vaccuum gauge idea is better than anything in the feel-good article.
By cxk2 | Aug 5, 2006 8:52:51 PM |
Request Removal
People have been writing pointless, increase your mileage tips since 1973. Try to be intelligent for once. Try to be clever. If your ideas fall into either of these two categories, 1 Murder is a bad thing obviousness or 2 You might get shot for doing this but..., then just go home and separate your recyclabes. You will do the world a lot more good than you will by pissing away profitable advertising space by publishing useless crap like this (
Delta Flyer note: Have I seen you on a forum?).
By tvsfrank | Aug 5, 2006 9:00:36 PM |
Request Removal
__________________________________________________
Interesting suggestions that I think people here in Chicago really need to read. The most basic idea here, not using excessive brake and gas, is something my Dad taught me when I was learning to drive. People in the midwest are absolutely clueless on even this idea they are big fans of speeding up just to slam on their brakes. I would love it if someone would do a study on how driving tactics affects traffic--I am absolutely convinced its responsible for a lot of the traffic here.
By deibelt | Aug 5, 2006 9:04:01 PM |
Request Removal
lotza crappo--i do not drive a japanese rice-burner, nor do i intend to--the practical way to get the most from each gallon is to pay attention to road conditions: dont race up to a red light and then slam on the brakes--no jack-rabbit starts from the traffic light--be sure the air filter element is clean--are your tires properly inflated??--dont expect big savings if you are driving 250 horses under the hood--close the windows and set the air conditioner at a reasonable temperature such as 75 degrees--keep your speed at 70 miles an hour or less, but dont play games with shutting off engine--use downhill to your advantage by coasting whenever practical--dont spend 20,000 dollars on a hybrid thinking you will save big bucks on fuel--truth is youll never recoup your purchase price unless you keep the new car at least 10 years, if the car lasts that long--remember, the hybrid battery costs very big bucks to replace when it no longer can hold a charge--use cruise control whenever possible with a setting of no more than 2,000 rpm if your car has a tach and you are out on the interstate--dont believe the epa ratings--good luck, and remember: theres plenty of gas left out there waiting to be refined--remember the experts in the early seventies telling us that we are running out of petroleum--yeah right!!
By rencarl | Aug 5, 2006 9:44:48 PM |
Request Removal (
Delta Flyer's note: How many beers do they allow readers have while they post? )
Our minds should be applied to more useful challenges than any of this trivia.
By caroleannetax | Aug 5, 2006 11:44:25 PM |
Request Removal
Actually, driving behavior is a large factor in not just fuel economy, but many of the daily beltway backups. Drivers here do not seem to make the gas pedal to fuel economy connection. Oh, and the guy with the Ranger pickup has me chuckling. You drive a large pickup truck, and are weighing in on fuel economy? Do you have diet coke with your hot fudge sundaes, too?
By robert7ii | Aug 6, 2006 6:34:46 AM |
Request Removal
Previous poster writes, Our minds should be applied to more useful challenges than any of this trivia. Must be a Hummer driver . . .
By robert7ii | Aug 6, 2006 6:36:28 AM |
Request Removal
Let me include this link as Edmunds seems to have actually *tested* what they promote: which finally lays to myth that tire underinflation hurts gas mileage significantly. Excuse me now while I drive down the road and turn off the engine !!!?????.
By tkrotchko | Aug 6, 2006 12:12:16 PM |
Request Removal
I notice the post filters out URLs. Go to google and look for tire underinflation does not hurt fuel economy. Ill try to be tricky with the link to see if that sticks. /advice/fueleconomy/articles/106842/article.html
By tkrotchko | Aug 6, 2006 12:14:20 PM |
Request Removal
By tkrotchko | Aug 6, 2006 12:29:54 PM |
Request Removal
Re forced auto stop. Not only is it unwise, its illegal in MD and VA to do so removing motive power from a moving vehicle.
By rzeman | Aug 6, 2006 9:30:17 PM |
Request Removal
Living in a country where gas prices are over 5$ per gallon I am glad to see that people in the US are catching on on saving energy. Regarding the hypermiling techniques Id like to add the following: I think you have to keep the big picture in mind also. If for example your gas saving causes the tires to wear faster, that in the big picture is just as bad since fuel will be burned to manufacture tires. Aspects I was missing were aerodynamics like open windows and roof racks not to mention bullhorns and flags and turning off air condition, hifi amplifiers and other electrical devices not needed.
By e.fernbach | Aug 7, 2006 12:02:07 AM |
Request Removal
Slowing down really does help. About 2 gallons on the trip from NoVA to Philly. My gas-guzzler 1994 Lincoln got about 19.5 MPG/highway with my normal habits I once got it up to 26 MPG after slowing down. I stay on the far right lane and dont go above 65 60 in a 55 zone.
By get00smart | Aug 7, 2006 12:34:28 AM |
Request Removal
Great article! Ive been doing this for years with my Honda Civic Hybrid had an 03, now I have an 06. I average about 48 MPG and its not unusual to hit 50-53 MPG with the A/C on. In heavy traffic, this can go much higher because of the AutoStop feature. Also recommended pretend as though theres a raw egg between your foot and the gas pedal. It will cause you to gently apply pressure instead of using a hard throttle. Modern hybrid tires are harder than most cars, less rolling resistance, so I would keep those tires at the normal pressure. Some hybrids use a special motor oil, I wouldnt mess with that either. Keep cargo weight to a minimum. If you dont need to carry a lot of stuff for ordinary trips, then remove it from the car. Wax on, Wax off , less wind resistance. The new spray waxes are easy to apply and only takes a short amount of time. Nice thing about small cars, less surface area . Look for opportunities like hills and banked curves to maximize coasting and to keep the battery charged. With practice, youll know exactly when to let off the throttle, charge the battery and still have enough power to make it up a hill at a suitable speed. I LOVE my hybrid!!!
By harothberg | Aug 7, 2006 2:51:43 AM |
Request Removal
After reading the other posts, the Civic Hybrid does include a manifold vacuum guage. Its a toggle on the temp display. It has a fancier name though . Good recommendation. Turning off the car while driving, not good... we use to do it as kids to hear the muffler backfire from unspent gases. It was stupid then, and still is. Finally, for the folks that say it isnt worth the extra money. I disagree. The longer the Mid-East is in conflict, the more gas will go up. And, I would rather pay the extra money to companies that are on the cutting edge, to help them improve this technology, or develop something better?, than to see my hard earned money going to terrorist states. Driving a hybrid is patriotic, unless you want to continue to fund terrorist regimes. Does anyone remember where most of the 9/11 hijackers came from? Need I say more?! Besides, whats wrong with conserving? Are we that selfish not to want to leave our children a better future, or do we feel weve got to use everything up before someone else does? What a spoiled, selfish society we have become...
By harothberg | Aug 7, 2006 3:09:17 AM |
Request Removal
I have owned a 2000 Honda Insight since they first came out. Mine was the first hybrid registered in Florida, and it is now getting rather long in the tooth, with 131,000 miles on the odometer. I still use it every day and three weeks ago I got a speeding ticket in South Carolina for stupidly going 85 in a 70 mph zone -- I wasnt in a hurry or anything, but if you dont watch the speedometer like a hawk you creep up to 90 mph because the car is so smooth, quiet and stable at speed that youre always pulling back on the reins. But I averaged 63 mpg on that trip from Orlando to Washington, D.C. WITH THE A/C BLASTING the whole way. With the climate control turned off, I have routinely beat the EPAs estimate of 70/61, with my best trip being one of 51 miles between Orlando and Cocoa Beach where I obtained 106.7 mpg driving with a deliberately light foot. I would have gotten about 135 mpg except I got caught in stop-and-go rush hour traffic in Cocoa and Merritt Island along the way. I am dismayed that Honda will discontinue the Insight after the 2006 model year. I really love mine and would have chosen to replace it with another new one when it finally gives up the ghost, which it seems to be nowhere near. I have heard rumors of its demise every year since 2003 and, although I hope that this too is just a rumor, this time I think it may be true, alas! I also have a 2005 Toyota Prius, which is MUCH harder to get up to its EPA rating but the things practically a limousine so I can tolerate only getting in the high 40s and low 50s for all that luxury -- the high-end audio, the voice-activated NAV console, the spiffy keyless entry and ignition, the very professionally dealer-installed leather seats, the HID headlights, the comfy seating for five, the whole nine yards
