Which four functions do you set your ScanGauge to?
ScanGaugeAnything ScanGauge related is open for discussion here.
View Poll Results: Which four functions do you set your ScanGage to?
Re: Which four functions do you set your ScanGauge to?
I have a Fiesta and an UltraGauge. I have long-term MPG, short-term MPG, gph, and engine temp (because the Fiesta does not display this), engine load %, and gallons remaining in the tank. So I guess that is 6 things.
MPG, CHT, SOC, and LFT. I'm watching my LFT while in transition to E0 gasoline. Once that stabilizes, I think I will switch it to current trip average MPG.
LOD........DailyMPG
S.Trim......AFR
plus my car's factory instant MPG gauge. I sometimes switch to coolant temprature in winter time vs. Short term fuel trim. my fuel trims are always 0 but sometimes they really go negative in winter which means my car is running too rich, so i keep off the throttle to save gas, even though my AFR is reporting stoich (wrong because o2 sensor is still cold). I also use horsepower because my engine is most efficient when making 35 horsepower and the scangauge horsepower figure is very accurate in closed loop.
