Battery Died From P&G / FAS...
Old 09-23-2008, 03:09 PM
BudgetFitting's Avatar
BudgetFitting BudgetFitting is offline
FAS Convert
Vehicles: Honda Fit
Today, my car would not start and I was stuck in the intersection. This was a great time to get out and push to gain a few free points.
The car is 5 months old with 4,000 miles on it. The battery went dead, and I could not bump start since I was on an incline and could not get going down hill since it is a large 4 lane road with a cement divider.
AAA came out and jump started me, and told me the battery has only a 20% life left. For those who have not seen a Fit battery, it is tiny. The tow truck driver said it is the smallest car battery he has ever seen, even smaller than the prius (he said it looked like a motorcycle battery).
I coast over 2/3 of my driving miles, and always have my CD player on at a moderate volume, and I always have the air vent on (not the A/C). So, when I am P&G'ing all of these things are running off the battery, and since I only pulse for less than 10 seconds there seems to not enough time to recharge it (since I coast for over 20 seconds).
My question is this; how do you guys who P&G everywhere avoid dead batterys?
I know shutting off the CD player and air will help, but will it solve the problem so it does not do this to the new battery? I am just amazed how quickly the life of this battery went down.
Ryan
08 Honda Fit:
Best tank mpg- 65.8 MPG over 613 miles
Driving Without a Scan Gauge II
Old 09-23-2008, 03:32 PM
jhu's Avatar
jhu jhu is offline
Re: Battery Died From P&G / FAS...
do you have daytime running lights? do you live in the usa? if so, find some way to turn those off since they're not mandatory here (yet).
Old 09-23-2008, 03:42 PM
FAS Convert
Vehicles: Honda Fit
Nope, no daytime lights. I also almost never drive at night, so I basically never turn on my headlights.
The only drain is the CD player, air vent, and occasional blinker.
Ryan
08 Honda Fit:
Old 09-23-2008, 04:14 PM
fixedintime fixedintime is offline
Vehicles: Honda Accord - 5 speed manual
Add to that the breaks when you use them.
Save a dollar a gallon on gas - Hypermile
Old 09-23-2008, 04:39 PM
Right Lane Cruiser's Avatar
Penguin of Notagascar
Brake lights can be significant. If no one is behind you give the e-brake a try. Also, does your car have electric power steering? That could be drawing it down as well.
The Insight came with a miniature battery from the factory as well. It is almost a cube! I found it was weak when the temps finally got low enough that the car wanted to use the auxiliary starter motor but didn't have enough juice to do it. I replaced it with a larger (Civic) sized battery.
- Sean
New? Start here!
Old 09-23-2008, 05:15 PM
lightfoot lightfoot is offline
Reformed speeder
Ah yes I forgot, the Fit has EPS. Mike Dabrowski told me that the EPS on the Insight draws a lot of current (50A at times) according to his measurements. That may be your biggest problem. You might try disabling the EPS by pulling its fuse and seeing how you like manual steering. This can be done on the Insight.
Personally, these cars are so small I wish Honda would just set them up with manual steering and avoid all the fuss.
As for the trickle charger, I was thinking of that for protection for the battery. Leaving a lead acid battery discharged leads to sulfation, which can shorten the battery's lifetime. So topping it off at night may help with life.
As Wayne says, it won't help with the battery going dead in use, but at least you'll start the day with a fresh battery. If you get a larger capacity battery and you're lucky, it may last through your daily driving and then you can charge it up at night.
Old 09-23-2008, 07:35 PM
lnmcmahan lnmcmahan is offline
Econoclast
Vehicles: 2007 Honda Fit, 2002 Mazda MPV Landboat
BTDT! Twice!! PITA!!!
Doh! That the main reason, I bought the SG! First I don't run ANYTHING that draws any juice, not even the fan in 100F+ weather. Second, at night I monitor VLT on one of my guages, and do N-ice on coasting when it drops below 11.3. I also put it in gear and get off the brakes at stoplights, and turn off my headlights if there is someone in front of and behine me.
Larry
Old 09-23-2008, 08:10 PM
CitrusInsighter's Avatar
CitrusInsighter CitrusInsighter is offline
Vehicles: 2000 Honda Insight
When you P&G, do you usually bump start after your glide or key start? Eliminating many key-starts will save our batter quite a bit if you aren't already.
-Justin Fons
2000 Honda Insight 5 speed
MilwaukeeHybridGroup.com
Old 09-23-2008, 08:51 PM
Boston Man Boston Man is offline
Vehicles: 2006 Honda Civic LX Sedan A/T
Thats weird. I have the OEM battery in my 06 Civic and i listened to my radio with amp and sub woofer for ~10 minutes with the engine off. My car started up fine with no hesitation.
Old 09-23-2008, 08:56 PM
ksstathead's Avatar
Civic has bigger battery.
Also, were you in a FAS or parked? If the latter: No EPS draw. No CPU. etc. Much more current draw with engine on. Though the Fit battery would not last long w/ your sub...
FAS mod on my Insight highwater Technical 7 09-18-2009 09:19 AM
REVIEW: Hymotion Battery Plug-In Prius TheForce General 155 04-26-2009 12:31 PM
12V Battery Replacement GaryG Ford Escape Hybrid 6 10-16-2007 10:30 PM
A new month, a new article on Battery Technology Dogarm General 1 07-12-2007 10:57 AM
FEH HV Battery Conditioning GaryG Ford Escape Hybrid 0 09-22-2006 07:17 PM
