Go Back   CleanMPG Forums » Conventional Automobile Owners Community » Honda
Honda The Power of Dreams - Discussion about Honda and Honda automobiles.
How to maintain A Honda Accord for maxium Fuel Economy--Advice Much Needed!
Tags: , , , ,
Old 09-07-2008, 09:45 PM
Pierce's Avatar
Pierce Pierce is offline
Vehicles: 1993 Honda Accord DX
Hello Everyone,
Recently, I've come into owning a 1993 Honda Accord DX.
With the great hypermiling techniques everyone's been sharing here at this wonderful site, I've been able to get around 35.1 mpg despite the 2008 EPA estimate being 22 mpg.
However, I feel strongly I can do much better, like you all easily have. Here's where I really need help;
My parents and I have decided to take the car to our mechanic in town for a tune up. Now what exactly should I ask the mechanic to check, repair, or replace that would result in assisting me in preserving or hopefully attaining a higher or healthy fuel economy.
Here's what I know to ask to get done;
Replace Filthy Air Filter
Rotate/Align Tires
Install Engine Block heater
Replace transmission fluid
Replace/Check Engine Oil with lowest viscosity synthetic oil allowed.
So, what else should I ask to get checked, repaired, replaced or looked at in order to improve my economy while getting my engine tuned up while at the mechanic?
Please post soon! My Accord's appointment is creeping up soon!
Old 09-08-2008, 12:52 AM
CitrusInsighter's Avatar
CitrusInsighter CitrusInsighter is offline
Vehicles: 2000 Honda Insight
Re: How to maintain A Honda Accord for maxium Fuel Economy--Advice Much Needed!
Welcome to CleanMPG Pierce!
I hope you have enjoyed what you've seen so far. 35.1 mpg is pretty good for a car of that age. What engine size and transmission do you have in that? If its a 4 cyl auto, then you're doing great.
Its great that you're being proactive in maintaining your car, all of the things you mentioned have the potential to help your mileage, however your mechanic might not have access to a block heater for your vehicle depending on where you're located. If you're not in Canada or the northern US, your mechanic might not know where to find one, and even if he can, he may try to talk you out of it. It will certainly save you fuel and reduce your emissions, but the economic payback is harder to justify.
Also, depending on the mechanic, he may tell you that in an older car, synthetic oil is a bad idea if the car's had conventional all its life. I can't argue with that since I'm not an engine oil expert, but again, its your car and you should work with your mechanic. Also be sure to replace the oil filter with a good quality synthetic media filter, not a cheap Fram POS.
It sounds like you've covered the basics already, but perhaps someone more mechanically knowledgeable can chime in with something else more in depth.
-Justin Fons
2000 Honda Insight 5 speed
MilwaukeeHybridGroup.com
Old 09-08-2008, 06:53 AM
Ophbalance Ophbalance is offline
Administrator
The car should have a manual stating the intervals to check/change fluids and such. If it's not been done, you should really have the valves adjusted every... 30k? 60k? I forget. I had a 93 EX at one time with a stick. Sadly, it was sold to pick up a 4x4 Escape. I'd also look at replacing the O2 sensor as well, but it would depend on the mileage.
Matthew Williams
Old 09-08-2008, 08:23 AM
PaleMelanesian's Avatar
Beat the System
Check the timing belt. If it hasn't been replaced, it's due. My civic's manual calls for replacing it every 90,000 miles. If it fails, bad things can happen.
Andrew
88.3 mpg commute 72.8 mpg / 946 mi tank
100 mpg commute 90.2 mpg / 1191 mi tank
Old 09-08-2008, 08:39 AM
shifty35's Avatar
shifty35 shifty35 is offline
Once again, here is the short list...
Spark plugs
Plug wires
Distributor cap
Distributor rotor
Verify brakes not dragging at all
Proper alignment
Parking brake properly adjusted
Wheel bearings in good condition
Tires in good condition / properly (over)inflated
That should just about take care of the basics.
Ben
Old 09-08-2008, 09:31 AM
Administrator
There was no distributor in the 93? It was a coil pack setup, if memory serves.
Matthew Williams
Old 09-08-2008, 10:09 AM
Damionk's Avatar
Damionk Damionk is offline
DWL Lover
Vehicles: Honda Accord
I have recently gotten a '96 Accord Anniv edition (one generation after yours). The car does do good for hypermiling. I have only been able to get 34 MPG because my fiancι drives the car too. Is your Accord an auto or manual transmission. If its an auto you're doing better than me.
Forget driving like a normal person, I would much rather drive like a sane person.
Old 09-08-2008, 03:33 PM
Pierce's Avatar
First off, I'd like to thank everyone for the warm welcome and quick replies. I'm definitely going stick around here. I thought I'd never get so much good information so rapidly.
For the record, here's my car;
A 1993 Honda Accord DX. And yes, it's an automatic 4 cyl. Oddly, however it was around 70k miles, and was gently used according to a private mechanic we showed it to secretly during our test drive. It is my first car ever, and I'm a new driver. I'm 18. I do live in New Jersey. I REALLY wanted a manual transmission (especially for max. MPG!), however my father, who is a strict manual transmission driver for over 40 years didn't think I was quite ready yet for an MT. Sigh.
Today, new tires were purchased for the Accord and installed. Now for hypermiling purposes, what should I inflate these tires to? They read 35 psi, however, I'm worried this might harm my tires. Should I worry? Also the new tires, which are Michelin Rainforce All Season MX4's, that we've replaced the older tires with good in the rolling resistance department?
Citrus,
How do you feel about the electric oil heaters that contain heating elements and replace the dip stick? Will those in improve my inital mpg with temperature lower than 40F? (Or around?)
And Shifty, should I ask to replace the spark plugs, plug wires, distributor cap, and distributor cap outright? (Can I actually do this my self?) What type of these products should, I, person who wants to hypermile extremely well, ask for? (Ex: A hypermiler prefers the lowest vescosity version of synthetic motor oil as opposed to non-synthetic standard thickness motor oil.)Why is it important to keep the Parking brake properly adjusted, wheel bearings in good condition for mpg?
Damionk,
What exactly do you mean by "good for hypermiling"? Does this mean that the car can attain a high MPG rating? Or this car can easily can exceede the EPA estimate compared to other cars?
What does mean when the breaks "drag"?
My parents said they will replace the timiong belt. However, will it's replacement help improve mpg?
Finally, do we need to cover anything else in terms of keeping the Accord in shape for maximum FE?
I really want to keep this car in the best condition possible, inside and out. Thanks for everyone for helping me coast down this "new road" in my life.
Old 09-08-2008, 04:15 PM
Pierce's Avatar
Also, here's my hypermiling goal.
Here's where I'm currently at:
35 MPG. However my car isn't tuned up and is going to the local Mechanic Soon. I also do not use the A/C or electrical devices such as the radio or speakers what so ever.
I do find the automatic transmission to be both a blessing and curse. Since I accelerate extremely slowly after I allow the car "move itself" in a non-nuetral fashion, I can "coax" the AT into shifting gears up until I reach 4th gear at my optimum speed 40 mph at 1500 rmp. (Lower RPM at highest gear=Best MPG correct?)
Since my commute to my community college is a total of 32.4 miles (round trip) and is 97% highway based, with little traffic lights I find it easier to maintain higher than average mpg. While driving 40 mph in 4th gear at 1500 RPM. Virtually, the entire trip is based on just on 31 miles of straight highway roads with a posted speedlimit of 55~50 mph.
My goal is to reach this two days:
46~47 MPG in the 93' Accord.
My logic?
On Friday, I bought 2.9 gallons of gas for $10, when my take was bare.
This filled my gas guage up to the half full line. After my commute (32.4 mi), I only had 75% of the gas left. This monday evening I have only 50% of the gas left (Current gas guage picture right above.). Hopefully if this trend cotinues, I'll get to "E" on Wednesday after communting a total of around 129.6 miles on 2.9 gallons. Again I say, hopefully.
Any advice for my plan?
Old 09-08-2008, 05:37 PM
some_other_dave's Avatar
some_other_dave some_other_dave is offline
Vehicles: 2012 MINI Cooper
Brakes "dragging" mean that the pads are rubbing a little bit against the rotors. It's like applying the brakes just a little tiny bit all of the time--or most of the time. You can imagine that even the smallest amount of that isn't good for your FE.
Wheel bearings that are in poor shape will also put some drag on the wheels, almost as if you were applying the brakes the tiniest amount. Still not great for FE.
A new or old timing belt "should" not change the amount of drag on the engine. However, having one break will result in either an engine that doesn't run at all, or an engine with mashed and mangled valves. (Not sure which of those two states the Accord engine is more likely to wind up in; my CRX would have mangled valves or worse.)
It sounds like the basics have all been covered above. If you're getting new tires, look to see if you can get ones with low rolling resistance. There is a list available somewhere here on the site that shows some relatively LRR tires, though it is a little bit old now.
-soD
The heat is on. xcel In the News 3 04-13-2008 11:25 PM
DCX Chairman Dieter Zetsche Urges Americans to Rethink Diesel. xcel In the News 0 01-23-2007 06:03 PM
Fed, State, and Corporate hybrid purchase incentives. Yesterday, today, and tomorrow. xcel Articles 2 12-04-2006 10:17 AM
Consumer Guide's Real World Fuel-Economy Champions. xcel In the News 10 10-03-2006 10:13 PM
Memorial Day Travelers can save 38% of their gas bill with 6 simple economy tips. xcel Fuel Economy 9 05-26-2006 09:21 AM
