| 2000 - 2006 Honda Insight I Everything and anything relating to the first generation Honda Insight. |
Insight CVT Problem
View Poll Results: Have you had probems with your CVT?
CVT repairs were completed under warranty?
0 |
0% |
CVT repairs were completed under the recall?
0 |
0% |
The repairs been done under 100,000 miles?
0 |
0% |
The repairs been done over 100,000 miles?
0 |
0% |
08-27-2008, 11:39 PM
Insight CVT Problem
A friend recently had his 01 Insight with 165,000 miles tuned-up. Shortly after it started missing and the transmission started growling. It threw a code (didn't have the number) that showed "all cylinders misfiring." I would like to think that the shop knocked a vacuum line or electrical lead off and caused this. It was a local "reputable" independent shop. He is about 150 miles away so phone info is all I have.
He took it to a Honda dealer in St. Louis and they changed the fluid in the trans. They said metal particles were in the oil. They also said the misfire codes were caused by the transmission problems???
Has anyone had similar problems?
Has anyone had CVT repairs under warranty or the recall?
08-28-2008, 03:50 AM
Reformed speeder
Re: Insight CVT Problem
They weren't worried about where in the trans the metal particles came from? And whether that part might need replacement?
08-28-2008, 06:15 AM
Administrator
Don't the plugs in that car need to be indexed? Could that cause the misfire?
Matthew Williams
08-28-2008, 07:46 AM
Yes, they want to replace it. They will give him a 10% discount and the price would only be $4323.  He is searching for a used one.
08-28-2008, 07:50 AM
I stressed to check and make sure the proper plugs were in it. The Honda shop surely checked them. I don't believe they would misfire. The efficiency would be affected though.
08-28-2008, 07:57 AM
Reformed speeder
And people worry about the cost of replacement batteries??? I recall that Honda knocked the price for Insight (and Civic?) hybrid batteries down to $1500-$2000 recently?
08-28-2008, 11:02 AM
Honda changed their CVT fluid shortly after the CVT Insight's release. If it wasn't changed during the first 165,000 miles... I can see some damage being done.
Ben
