Dealer says ScanGauge ruined my PCM and I can't use ScanGauge anymore
  #31   Submit to Clesto Submit to Digg Submit to Reddit Submit to Furl Submit to Del.icio.us Submit to Spurl
Old 08-28-2008, 10:05 AM
msirach's Avatar
msirach msirach is offline
Vehicles: 2000 Insight,2010 InsightII,2008 Prius,2010 Prius Solar
Re: Dealer says ScanGauge ruined my PCM and I can't use ScanGauge anymore
First place I would look would be at the pcv valve and check the body or gasket for a leak.
  #32   Submit to Clesto Submit to Digg Submit to Reddit Submit to Furl Submit to Del.icio.us Submit to Spurl
Old 08-28-2008, 10:09 AM
Showbizk's Avatar
Showbizk Showbizk is offline
Vehicles: 04 WRX Sport Wagon; 08 Hyundai Veracruz
Originally Posted by Thumper View Post
While my issue with my new SGii was small,(needed a different cable for my Hyundai) the tech support person whom I talked treated me like I was his only customer or concern for that day. He was great! I got my new cable in two days from calling with no charge. They truly do value and have great customer service.
Thumper, I have an 08 Veracruz. Can you elaborate on why you needed a new cable? Is the OBD2 plug different? Was the original cable defective? I have an SGii in my WRX and would like to get only an additional cable so I can use the SGii in the Hyundai, too. Thanks!
  #33   Submit to Clesto Submit to Digg Submit to Reddit Submit to Furl Submit to Del.icio.us Submit to Spurl
Old 08-28-2008, 11:52 AM
Nikki Nikki is offline
Vehicles: Pontiac Vibe
Originally Posted by Markmysite View Post
Oops, yeah that might help ... It's a 2007 Pontiac Vibe, 5-speed, 1.8L engine, 10,000 miles on it now
I hope you get this problem resolved with your dealer. FYI I also have a 2007 Vibe [Toyota Matrix clone]. I plugged in the scanguage back in April and haven't had any trouble.
Nikki
  #34   Submit to Clesto Submit to Digg Submit to Reddit Submit to Furl Submit to Del.icio.us Submit to Spurl
Old 08-28-2008, 12:07 PM
Thumper's Avatar
Thumper Thumper is offline
Vehicles: 2003 Hyundai Elantra, 2001 Dodge Grand Caravan
Showbizk,
You should have no cable issues with an 08. Hyundai was non-compliant with the way the wired the vechicle side of the OBD plug. This was discovered and corrected some time in 2003. Only some of 2003 and earlier models were affected. I suggest calling Liner Logic to make certain, but I have not heard any issues with any Hyundai 2004 and later. Even some of the earlier models work fine without a different cable. LL told me that they just had to rearrange some pin postions in the standard cable for mine to work.
  #35   Submit to Clesto Submit to Digg Submit to Reddit Submit to Furl Submit to Del.icio.us Submit to Spurl
Old 08-28-2008, 01:06 PM
Ophbalance Ophbalance is offline
I thought they disabled some of the pins, not re-arranged? Oddly, they got it right for the 99 model as mine has never had any issues.
Matthew Williams
  #36   Submit to Clesto Submit to Digg Submit to Reddit Submit to Furl Submit to Del.icio.us Submit to Spurl
Old 08-28-2008, 02:43 PM
Thumper's Avatar
That may very well be. I have slept since I spoke to LL and my steel trap memeroy ain't what is used to be. LOL
  #37   Submit to Clesto Submit to Digg Submit to Reddit Submit to Furl Submit to Del.icio.us Submit to Spurl
Old 08-28-2008, 08:39 PM
Markmysite Markmysite is offline
No one guessed it.
So, the cause was a vacuum leak .... in the hydro-booster (power brake booster) of all things. After spraying the entire engine to try and find the leak, they finally heard it near the brake booster.
So, in this whole process my car got:
- A new ScanGauge unit (and solid proof they are a great company)
- 4 brand new fuel injectors
- New O2 sensors
- New PCM
- A free cleaning of my mass air flow sensor
- And a clean engine since it was fully sprayed with carb cleaner.... lol
  #38   Submit to Clesto Submit to Digg Submit to Reddit Submit to Furl Submit to Del.icio.us Submit to Spurl
Old 08-29-2008, 12:13 PM
Damionk's Avatar
Damionk Damionk is offline
Flying Blind
Vehicles: Honda Accord, Suzuki Esteem
I need to go to your dealer. I would probably leave with a new car.
Forget driving like a normal person, I would much rather drive like a sane person.
  #39   Submit to Clesto Submit to Digg Submit to Reddit Submit to Furl Submit to Del.icio.us Submit to Spurl
Old 08-29-2008, 02:15 PM
hazeldazel's Avatar
hazeldazel hazeldazel is offline
Vehicles: 2006 Honda Civic LX
i have an uncle that worked at GM until he retired, so all his sibs get the employee discount. After years of seeing the lemons that my mom and aunt have saddled themsevles with and poor service at GM dealer repair shops, I gotta say that I don't care how good the Volt is or anything that GM ever produces for that matter - I will never ever ever buy a GM car.
  #40   Submit to Clesto Submit to Digg Submit to Reddit Submit to Furl Submit to Del.icio.us Submit to Spurl
Old 09-03-2008, 10:25 PM
hobbit hobbit is offline
Vehicles: 04 prius
*Carb cleaner*?? They're supposed to use propane for that.
_H*
