Confused About DWL
08-13-2008, 11:12 AM
Vehicles: 2001 Isuzu Rodeo 6 cyl automatic
Confused About DWL
I'm confused about the technique for DWL. Do I want to maintain a specific throttle position, 6 for instance, or do I want to maintain a steady fuel economy by slight variations of the throttle? I have a six cyl auto with ScanGauge. (I have read, and re-read, and re-read Beating the EPA).
Thanks a lot,
Nanci
08-13-2008, 11:16 AM
Be Inspired
Re: Confused About DWL
DWL is slowly relieving the pressure off the throttle and generally maintains about the same maybe slightly lower fuel economy. maintaing a steady throttle position will give very different results
Ricardo
Best Segment: 25.3mi@76.9mpg
08-13-2008, 11:27 AM
Hi Nanci:
___If you do not have a SG, you will maintain throttle position. With a ScanGauge, you can get a little more out of your ride by maintaining FE while climbing, cresting and reaccelerating with gravity back to somewhat steady state.
___There are more variants depending on how steep to initial slope is, the approach angle and speed, the elevation delta from initial to final and what kind of terrain is beyond the finish of the hill or overpass..
08-13-2008, 12:04 PM
Vehicles: 2003 Hyundai Elantra, 2001 Dodge Grand Caravan
I won't speak for Nanci, but those two explanations helped me.
Thanks!
Stan
08-13-2008, 12:31 PM
Be Inspired
I'll clarify a little bit extra. If you're not going over steep hills and there are slight variances on your terrain (slight inclines on declines), maintain your throttle position, this will give you the best economy.
For steeper hills, you can usually drop off pressure as you come closer to the point where your car is about to downshift..
Ricardo
08-13-2008, 12:34 PM
DWL Lover
Vehicles: Honda Accord
What about hills where you're car wouldn't downshift?
08-13-2008, 12:48 PM
Be Inspired
as long as you dont downshift maintain throttle, or just pulse if you can do so in your top gear to get a glide on the other side of the gradient.
Ricardo
08-13-2008, 03:36 PM
Vehicles: 1998 Mercury Mystique
On steep grades I do this right up to the point where the car is about to stall and then I have to downshift (manual 5sp). That usually occurs at just under 30 mph in 5th gear.
08-13-2008, 05:43 PM
Thanks you guys! I didn't get to really work on it on the way home since there was a monsoon and I had to just drive and try to see the road, but this only took me down about one mpg, even with the lights and wipers and defrost and standing water...
08-13-2008, 06:05 PM
Be Inspired
Well with what you drive that's a bout a 5% hit off your average.
Ricardo
