Tire Life Survey
Old 08-13-2008, 06:36 AM
greendriver's Avatar
greendriver greendriver is offline
Vehicles: 2007 Honda Civic Auto (L5)
Tire Life Survey
I just replaced the tires on my wifes Accord. They had 92k miles on them. I checked the tire pressure regularly and kept them at 32 psi. I've read a bunch of posts on tire's lasting longer if you put more air in them(max sidewall) but I am still skeptical. (35 years of old habbits are hard to break)
I thought a survey with actual mileage might help me change my old ways.
Please take 30 seconds to participate. Results will be posted here.
http://greendrivingtips.com/?page_id=131
Thanks,
-John
Best Tank on 03/08/13 = 481 miles/10.45 Gal =46.03 MPG
Old 08-13-2008, 11:56 AM
A024523's Avatar
A024523 A024523 is offline
Currently in Training
Vehicles: Toyota Tercel
Re: Tire Life Survey
I just made my input. You you haven't seen this already, here a poll done here a few months ago on PSI alone...
http://www.cleanmpg.com/forums/showthread.php?t=10881
PS - I recently upped mine to 50 PSI (max sidewall is 44)
-Edwin
Best Tank = 601.7 miles @ 56.36 MPG
Old 08-13-2008, 12:18 PM
ksstathead's Avatar
Our mileage is low and getting lower, so I can only give my impression:
Since jacking up psi and reducing average speed & agressiveness, I can no longer detect wear. Before, life stunk (40Mish) and middle of tread was wasted.
Tacoma has 44M with original tires. Should do 60M. Guesstimate 90M if had inflated properly the first 5 years of its life. Now at 35psi (max sidewall).
Old 08-14-2008, 05:09 AM
Thanks for your input Edwin. I missed that link. Good info.
-John
Old 08-14-2008, 05:14 AM
Good point about how slowing down can increase tire life. Wonder if flying around corners the way I do now is gonna wear out the outside though!
-John
Old 08-14-2008, 12:26 PM
A024523's Avatar
John, It has not the case for folks doing this the longest, like Wayne himself. I suspect a slight increase in center wear above max PSI may offset the increased outer wear via "death turns", but most folks here don't think there is any tendancy for center wear.
By the way, there is a wealth of knowledge on zillions of threads from the past, so I recommend also doing searches, because virtually every imaginable issue has been addressed before many times over. Good luck!
-Edwin
Old 08-15-2008, 05:40 AM
Yes, I have done many searches here on this excellent forum and I thought a survey would be a good place to get real life stats on one page.
I have posted the results to date just below the survey. http://greendrivingtips.com/?page_id=131
For those oposed to clicking on an external link here is what we have so far.
Tire Brand (5 Values)
Goodyear (0) 0.00%
Michelin (2) 40.00%
Pirelli (0) 0.00%
Bridgestone / Firestone (1) 20.00%
BFGoodrich (0) 0.00%
Nitto (0) 0.00%
Continental (1) 20.00%
Dunlop (1) 20.00%
Yokohama (0) 0.00%
Kelly-Springfield (0) 0.00%
Other (0) 0.00%
Air Pressure (5 Values)
Manufacture recommended (1) 20.00%
Max Sidewall (2) 40.00%
Greater than Max sidewall (2) 40.00%
NA (0) 0.00%
Mileage (5 Values)
Less than 50 K (2) 40.00%
50-60 K (1) 20.00%
60-70 K (0) 0.00%
70-80 K (1) 20.00%
80-90K (1) 20.00%
90-100 K (0) 0.00%
Greater than 100 K (0) 0.00%
NA (0) 0.00%
Comments:
Tire Brand Bridgestone / Firestone
Air Pressure Max Sidewall
Mileage 70-80 K
Comments Another 40k left in them!
Tire Brand Dunlop
Air Pressure Greater than Max sidewall
Mileage 50-60 K
Comments good wear pattern and still life left in all four tires
Tire Brand Michelin
Air Pressure Manufacture recommended
Mileage 80-90K
Comments Good wear
-John
Driving Under Pressure (full article) lamebums Articles 31 04-03-2011 08:55 AM
Is This Man Cheating on His Wife? Pravus Prime Off-Topic 12 08-16-2007 12:42 PM
Tire firms fight pressure-monitor rule. xcel In the News 2 02-19-2007 09:28 AM
Tire Pressure Monitoring Technology Can Save Your Life - If You Know How To Use It. xcel In the News 2 11-22-2006 08:48 PM
Regular Tire Care Can Improve Gas Mileage and Maximize Vehicle Safety. xcel In the News 7 04-26-2006 09:17 PM
