Go Back   CleanMPG Forums » Conventional Automobile Owners Community » General
General General conventional automobile discussion and overview including questions and concerns.
Carbon Build-up
Old 08-10-2008, 07:32 PM
Damionk's Avatar
Damionk Damionk is offline
DWL Lover
Vehicles: Honda Accord
Carbon Build-up
The '96 Honda Accord that recently came into my possession was checked by my brother, the mechanic in the family, said that there may be some carbon built up in the engine. I was wondering if there is a good way to get rid of it. Maybe something I can put in the tank. I don't want to have to take anything apart if at all possible. I asked my brother at the time he mentioned it and we both got distracted talking about something else. So, I will turn to the "experts" here.
Forget driving like a normal person, I would much rather drive like a sane person.
Old 08-10-2008, 11:16 PM
Right Lane Cruiser's Avatar
Penguin of Notagascar
Re: Carbon Build-up
My grandfather used to say you should take the car out onto the highway at a higher rate of speed to "blow out the carbon every once in a while."
I don't know if this has any real value or not...
- Sean
New? Start here!
Old 08-10-2008, 11:18 PM
Damionk's Avatar
DWL Lover
Re: Carbon Build-up
That's the exact same thing my fiancι's dad said today. But, I'm not sure I'm comfortable doing that with trying to save gas....maybe I would be better off taking that momentary hit to my FE. (Just thinking aloud on that last part.)
Edit:I did do a Google search and came up with a few things. One was something called seafoam. Most of the others mentioned a fuel additive that is designed to clean out carbon.
Old 08-11-2008, 12:15 PM
A024523's Avatar
A024523 A024523 is offline
Currently in Training
Vehicles: Toyota Tercel
Re: Carbon Build-up
Your mechanic meant the carbon build-up that occurs on the intake and exhaust valves, which causes them to not close completely, thereby not optimizing cylinder compression. Adding a good fuel system cleaner to a tank of gas ought to clean it up. Goto your local auto-parts store and specifically look for one that cleans valves. I need to do mine bi-annually, otherwise the build-up negatively effects my required smog inspection.
-Edwin
Best Tank = 601.7 miles @ 56.36 MPG
Old 08-11-2008, 01:37 PM
Damionk's Avatar
DWL Lover
Re: Carbon Build-up
My brother recommended that I use something called gunk...I think. I don't remember off the top of my head. He said just to spray it into the air intake when the engine is running.
Old 08-11-2008, 01:52 PM
A024523's Avatar
Re: Carbon Build-up
I can't help you there. The only product called "gunk" I have seen is an engine degreaser that is only used for the outside of the engine, not the inside, but he might be referring to some other producted by the same name?
-Edwin
Old 08-11-2008, 02:54 PM
Damionk's Avatar
DWL Lover
Re: Carbon Build-up
The same or similar. I can't remember off the top of my head right now.
Old 08-13-2008, 01:41 PM
benwynn benwynn is offline
Re: Carbon Build-up
I've used SeaFoam for that and it seemed to do an ok job. I had to replace a head in my subaru (was like that before I used the SeaFoam). But, I noticed that the carbon buildup on the valves wasn't as thick as it was on the head I replaced it with.
Old 08-13-2008, 07:15 PM
abcdpeterson's Avatar
abcdpeterson abcdpeterson is offline
Re: Carbon Build-up
that sounds like good advice. My Mazda Tribute just went over 100,000 and the mileage has been dropping. I think I will give that a try.
-Allen
Old 08-13-2008, 07:27 PM
JusBringIt's Avatar
Be Inspired
Re: Carbon Build-up
Seafoam is very good for cleaning out your intake, clearing up rough idle, and getting rid of carbon deposits.
Another more difficult technique is steam cleaning by spraying a gentle mist into the intake while the engine is running, not so much to cause hydrolock. Make sure its an amount that logically looks like it could become steam before it gets to the cylinders. Make sure the car is warm before attempting this.
Disclaimer:
Do this at your own risk as I am not responsible for any damage done to your vehicle if you attempt to steam clean.
Ricardo
Best Segment: 25.3mi@76.9mpg
Carbon Output Must Near Zero To Avert Danger, New Studies Say atlaw4u In the News 2 03-18-2008 03:58 PM
I will never voluntarily contribute to carbon offsetting friedlbug Emissions 34 02-11-2008 01:58 PM
DOE awards first three large-scale carbon sequestration projects. xcel Environmental 0 10-10-2007 09:17 PM
SUVs: Is that weight gross? Lower Fuel economy – More carbon output. xcel In the News 1 04-20-2007 07:00 AM
Americans try to shift into 'carbon neutral'. xcel In the News 3 12-06-2006 09:33 PM
