What X-Gauge best for Highway MPG's
Old 08-04-2008, 07:26 PM
sandman's Avatar
sandman sandman is offline
Vehicles: 2008 Toyota Prius
Need some input: What is the best X-Gauge to watch and hold to obtain best highway mileage..The three I have read about TPS, IGN, and GPS also might throw RPM's in the mix..I Drive 87 miles each way to work with about 80% highway..I got the P&G down and get some pretty Impressive Numbers until I get to Interstate then my MPG starts to drop.. I usually set the C.C. at 64mph most of the way. I do turn it off on some big downhill segments and glide.. I would love your guys take on this..I almost forget I drive a 2008 Prius..
Old 08-04-2008, 07:42 PM
xcel's Avatar
xcel xcel is online now
Re: What X-Gauge best for Highway MPG's
Hi Sandman:
___64 mph is beyond where the best your Prius has to offer can be found. On the backsides of hills and overpasses, Warp stealth. Accel’s, keep below 2,300 R’s (tach). 45 – 53, (SoC above 58.5%, IGN and TPS or gps). Below 40 mph, you can throw the book at it once you have surpassed S4. Battery Current would be useful below 40 as well. Best thing is to bring coolant temp up to 161 degrees F (coolant temp), perform an idle check at an appropriate spot in your commute and you are golden.
The SGII Xgauge Database kmactavi ScanGauge 95 04-30-2013 09:32 AM
Welcome to the new Scan Gauge I and II HW and Support forum. xcel ScanGauge 67 08-19-2009 09:55 PM
First tank with scan gauge... bksny Fuel Economy 6 07-11-2008 02:05 PM
Scan Gauge frozen? GreenVTEC ScanGauge 4 06-20-2008 04:10 PM
Vacuum gauge and shift points. koreberg Fuel Economy 7 12-18-2007 07:17 PM
