Optimal Acceleration AT&MT - Gas only
Old 08-01-2008, 10:31 AM
Tweakfreak Tweakfreak is offline
I did some searching to no avail on this topic. I have a couple of theorys and was curious what others have come across.
AUTOMATIC
Information: With an automatic you are in battle with the shift schedule programmed in the PCM. There is where that car will not up shift anymore w/out additional throttle. For me I have a 2.0L DOHC Zetec mated with a 4EAT transaxle. The most minimal acceleration the car shifts around 2100 RPM.
Questions:
  • Are the minimum engine speed upshifts due to torque converter stall rate?
  • Does this hurt efficiency since a lot of fluid passes threw the TC w/ out providing forward motion?
  • Would a moderately quicker acceleration up to the same cruising speed be beneficial?
Theory: I feel that there is some balance between that absolute minimal acceleration and the point of open loop mode. A point where the torque converter is being used efficiently and FE reaps the rewards. I'm not sure if this is true but it kind of makes some sense.
MANUAL
Information: Of course the driver in this case and more control over engine speed and gearing.
Question:With a ability to upshift earlier, how early is too early?
Theory: This is vehicle dependent and of course its obvious that it needs to be something above idle. I'm just curious how much volumetric efficiency at very low RPM and very light throttle changes fuel economy on these kind of acceleration. Whats the general rule of thumb?
Thanks for the read,
Anthony
Old 08-01-2008, 10:37 AM
99HXCivic 99HXCivic is offline
Vehicles: 99 Honda HX MT, 93 Mazda MX6 LS V6 MT, 99 Dodge Grand Caravan Sport 3.3L
Re: Optimal Acceleration AT&MT - Gas only
There was a previous thread on acceleration and fuel economy. But I shift my 99 HX M/T at 4500 to 5500 rpm and still get good mpg.
1999 Honda Civic HX MT
1993 Mazda MX6LS V6 MT
1999 Dodge Grand Caravan Sport
Old 08-01-2008, 10:44 AM
PaleMelanesian's Avatar
Beat The System
I shift at or before 2,000 rpm. I pay more attention to the target gear - try to land in the 1000-1500 rpm range.
Andrew
Old 08-01-2008, 11:03 AM
Shan's Avatar
Shan Shan is offline
SGII Equiped FIT Driver....finally!
Vehicles: 2007 Honda FIT Sport 5 speed Manual
Andrew, I am assuming you do not bog the motor or rather flood the motor with fuel at that low of a shift?
I have tried shifting at 2k but the motor seems to bog and I am currently shifting a 2250(around there) like Larry which helped me reach my 60mpg goal.
Shawn
Slow and Steady Wins the Race.
Old 08-01-2008, 11:17 AM
Beat The System
2250 - That works. I TRY to keep it below 2000, but sometimes I do go that high.
If I'm really light on the throttle, it can gain speed from as low as 1000 rpm. That's low 20's mph in both your car and mine. I only go that low in certain places, of course. Any more throttle and it just rumbles more but doesn't move any faster. I figure that as long as it's not shaking, it's fine. I doubt flooding is a problem with fuel injection - I haven't had a bit of trouble with that.
Andrew
Old 08-01-2008, 11:27 AM
I think there are a couple more variables to take into account. Engine load, engine speed, brake specific fuel consumption, pumping losses and EGR(or in my case exhaust VCT). I need to understand the relationship between these things to develop a better theory.
Old 08-01-2008, 11:34 AM
Beat The System
Basically, at such a low rpm - 1000 or so - it only takes a feather touch on the gas to reach high load. Any more than that and you're not getting any more work done.
Andrew
Old 08-01-2008, 02:16 PM
nissynis's Avatar
nissynis nissynis is offline
NC Attorney
Vehicles: 2003 Mitsubishi Eclipse Spyder and 2002 Mitsubishi Montero Sport
FWIW, and this is surely car-specific, I upshift at about 1600 RPM. In my 5 speed, that drops me into the next gear at about 1100-1200 RPM. I'm only in each gear for a couple of seconds.
There definitely is some tradeoff, you are right. If you are nearly lugging, you can sit there forever trying to accelerate and only doing so slowly. This seems to me to eventually be inefficient, esp if the alternative is getting up to speed and then FASsing.
Nis
Bst tnk: 653mi/48.2MPG/193%EPA
BHAG: 50MPG tnk
Summer Challenge Dream Goal: 47 MPG
Old 08-01-2008, 03:17 PM
lnmcmahan lnmcmahan is offline
Econoclast
Vehicles: 2007 Honda Fit, 2002 Mazda MPV Landboat
I have been expermenting with this lately, but I have found that if I shift in lower than 1400, say, and keep my load below 80%, my pulse length is too long, and I wind up eating all the mpg gain I got on the previous glide. There is definitely a sweet spot between low rpm and shorter pulse length. I'm looking for it!
Larry
Old 08-01-2008, 03:21 PM
Beat The System
I know what you mean. I'm still not entirely sure where the sweet spot is, myself. I do know Wayne likes super-low rpm, and I can't touch his mpg.
Andrew
What America really thinks about high gas prices. xcel In the News 12 06-13-2008 08:24 AM
Teens Offer Tips for Saving Gas tarabell In the News 13 04-29-2008 03:27 PM
Driving on gas - but not gasoline. xcel In the News 0 02-01-2007 12:28 PM
More Alaska new-car buyers are choosing to go easy on the gas. xcel In the News 0 07-06-2006 09:09 PM
DOE-Funded R&D Will Help Producers Tap America's Deep Natural Gas Resources. xcel In the News 0 06-01-2006 08:38 PM
