85 vs. 91 Octane (4350ft elevation)
Old 07-28-2008, 11:57 AM
MPG MPG is offline
Banned
Vehicles: 1996 Toyota Tercel 1.5L Manual
Hello all, I filled up today with 91 octane fuel. I have heard some people say you will get better fe, and some say you get worse fe.
I know that if you car does not require premium fuel and you run it you will not gain any performance, and all your doing is wasting money.
But the question is which octane fuel will give you the best fe?
Thanks, MPG
Old 07-28-2008, 12:50 PM
worthywads worthywads is offline
Vehicles: 2005 Toyota Tacoma
Re: 85 vs. 91 Octane (4350ft elevation)
85 would be the correct answer if your car doesn't require premium.
At your elevation (a little lower than me) your effective cylinder pressure is much lower than sea level and therefore we can get away with 85 vs the lower altitude 87.
Old 09-14-2010, 05:45 PM
RoadTrain RoadTrain is offline
Vehicles: 2002 Buick Regal GS, 1994 Chevrolet Caprice Wagon, 1983 Chevrolet Camaro Z28
Your car can't perform better in any way with higher octane unless the ECU is tuned for it. A higher octane will allow for more advanced timing, but if the ECU doesn't dial that in, it is a waste of $$
RoadTrain
Old 09-15-2010, 02:44 AM
some_other_dave's Avatar
some_other_dave some_other_dave is offline
Vehicles: 2012 MINI Cooper
Many cars these days require no lower than XX octane (varies depending on the car), but will actually give you better performance if you use a higher grade of fuel. Some of those will give you better fuel economy if you use the higher-grade stuff, but some will not. There doesn't seem to be a lot of rhyme or reason to which do and which do not, sad to say.
A very few of the people who report improvements report that the improvements are actually worthwhile, as they get a higher gain than the extra cost of the fuel. Most who report improvements seem to gain less than the extra cost of high-grade fuel.
If you have instrumentation on your car (like an SG II) and a good repeatable test set, I'd say try each and see what the results are. Your car just might like the 91, or it may not make any difference. You might even see a slight decrease in FE...
-soD
SwiftFuel - a drop-in gasoline replacement, 104 octane, 15-20% better FE, $3 a gallon Kevin108 General 5 09-25-2008 02:14 PM
Fuel Octane? 1996ToyotaTercelDX General 4 07-03-2008 02:03 PM
What my manual says about octane ratings bomber991 General 27 06-20-2008 10:43 AM
running higher octane in a low octane spec engine for improved FE? Chris D. Fuel Economy 19 05-05-2008 01:15 PM
Federal Report on Using 93 Octane Gas, Instead of 87 Octane Gas tigerhonaker Fuel 8 09-11-2006 11:49 AM
