Effect of air temperature on fuel economy?
Old 07-24-2008, 08:48 AM
Smile-n-Nod Smile-n-Nod is offline
Vehicles: 2013 Hyundai Elantra GLS
How much does air temperature affect FE? I usually get slightly better mileage (26 mpg vs. 24 mpg) on my morning commute at 80 degrees than the return trip in the evening at nearly 100 degrees. However, my morning commute usually has a slight tailwind and my evening commute usually has a noticeable headwind.. If wind were not a consideration, how much should my mileage vary with air temperature?
--Brett
Old 07-24-2008, 08:56 AM
PaleMelanesian's Avatar
Beat the System
Re: Effect of air temperature on fuel economy?
I find that as well. The best temperatures for my and my car are 75-85F. It starts to taper off above that. Below that, it doesn't just taper, it falls off. There's another huge drop when you get below 40.
Andrew
88.3 mpg commute 72.8 mpg / 946 mi tank
100 mpg commute 90.2 mpg / 1191 mi tank
Old 07-24-2008, 11:41 AM
fixedintime fixedintime is offline
Vehicles: Honda Accord - 5 speed manual
I would not rely on using the same route in two different directions to evaluate the effects of temperature on FE. There are just too many other variable that come into play. The light timing, the turns you make, the way the hill come into play, and how heavy the traffic is, are just a few variables.
Save a dollar a gallon on gas - Hypermile
Old 07-24-2008, 01:14 PM
Beat the System
I've been tracking this for 1 1/2 years, recording every single trip in the car. I have 683 data points.
75-85 degrees is best.
above 85 is next best.
below 75 is third best, tapering down to about 45.
below 45 is simply bad.
Andrew
Old 07-24-2008, 02:32 PM
scottgriz scottgriz is offline
Vehicles: 2000 Nissan Sentra GXE 1.8L 4-Speed Auto
I have been tracking air temp and mileage over the past 3 weeks. I only have my data on paper right now, but a quick look at it clearly shows a correlation between air temp and FE. Some of my best days were in the high 80's. As for what temp is best, I will defer to Andrew with his 683 data points. Impressive.
Old 07-24-2008, 02:58 PM
Beat the System
Of course, it's all specific to my car. It does include summer, winter, and now another summer in progress. The high temperature (90+) numbers are still suspect, but I'll have a chart to post soon.
Andrew
Old 07-24-2008, 09:19 PM
SilentLou SilentLou is offline
Vehicles: 99 Civic HX (50+mpg), 96 Ford Ranger 4l-V6 4X4 (25mpg)
I have seen a big dropoff in power and fe both around 85-90F and usually over 100F, but have not seen this since early summer. Humidity may be the other factor, higher humidity means less dense air but may have other effects besides air density.
I noticed one time when the dropoff occurred that the sgII indicated the engine was running OPEN LOOP instead of CLOSED LOOP. I believe OPEN LOOP means the O2 sensor is no longer used for feedback to control the fuel mixture. If that is the case, that could explain the dropoff.
Old 07-25-2008, 08:38 AM
voodoo22 voodoo22 is offline
Cheaper than the bus
Vehicles: Yaris Sedan (auto)
Our Yaris seems to use less gas the warmer the temperature, but even just below 25 celsius it seems to start using a lot more gas.
Old 07-25-2008, 09:01 AM
kwj's Avatar
kwj kwj is offline
I hypermiled this
Interesting. I've been keeping a close eye on my coolant temperature, striving to keep it as high as I can without the coolant fan operating. I tend to get my best MPGs at this temperature. However, I've not monitored air temperature. It would seem these should have a positive correlation for my car, Yes?
Old 07-25-2008, 06:41 PM
ascribe2thelord's Avatar
ascribe2thelord ascribe2thelord is offline
Recreational Hypermiler
Vehicles: 2010 Hyundai Sonata
For me the best temperature is about 80 degrees ... comfortably warm. Suddenly I am reminded of a Pink Floyd song.
Above 95 degrees I start getting an itch in my back that tells me to turn on the A/C. Over 100 degrees and I can't go more than a few miles without turning the A/C on. It's just unbearable. You can try drinking a lot of cold water to postpone turning on the A/C, but you still have to turn it on after 10 miles or so. Fortunately my commute is only about 8 miles, but on really hot days I still resort to using the A/C. August is coming.
Even when you turn off the compressor for going up hills and other high engine load situations, the A/C taxes your FE. Good news though, I just got a front end alignment and repaired a loose wheel ... that should mean 30+ mpg for the rest of the summer, even with A/C.
I think I may break 33 mpg again with this next tank.
Better Air Filter = Better Fuel Economy? SnowFire Fuel Economy 7 06-07-2008 01:15 PM
Sun Roof's effect on fuel economy herschen Fuel Economy 15 04-25-2008 01:51 PM
Fuel Economy: Then and Now. xcel In the News 13 03-31-2007 09:47 AM
Ford Eco-driving Tips Can Increase Fuel Economy By 25 Percent. Valleyforge In the News 8 03-02-2006 03:57 PM
