Go Back   CleanMPG Forums » Hybrid Owners Community » General
General General hybrid discussion and overview including questions and concerns.
Calculating fuel tank contents.
Tags:
Old 07-02-2008, 07:42 AM
pdw pdw is offline
While attempting to maxime mpg at each leg of a recent hypermiling excursion, the only way to figure precisely what's used up for each leg was to run small tank-portions empty each time.
This practise has exposed to me a difference between various fuel-grades that make positive FE difference; better fuel-grades, simply put, works much better with FASing a longstoke single cam engine with a 5speed like is in my 94 Saturn SL. For the event of miscalculation to coast up-to a pump, I carry a gallon-can with a measured amount of fuel stored safely in the spare tire compartment.
... found that when a filled tank gets warm it expands in various degrees thus leaving less volumeweight for a last-minute top-up etc to occupy despite a much higher volumeweight consumed; but also found that overnights can cool your tank which then often takes a lot more fuel volume to do that .... before leaving for Florida etc. This can be ellusive to precision fuel-measuring, going both ways ... sometimes (rarely) up to 10% more or less FE than expected just on that point alone.
Apparently, dieselfuel has the greatest weight-difference in comparing a WARM full-tank content to a COLD fill-up, the latter which yields significantly more distance.
Our VW diesel friends had discovered this expansion dilemma.... where the warmed-up fuel-fill, including that fuel still in the tank that has warmed up due to daytime or fuel-pump-return-heating prior to filling, robs that tankful of a number of lbs. This makes the last tank's FE look better .... and might make the next tank (esp if its results are with a cooler fill) look bad in the comparison.
Old 07-18-2008, 03:47 PM
pdw pdw is offline
Re: Calculating fuel tank contents.
I will weigh the contents and note the grade as well as the volume added enroute and its temperature.
That should cover for the main differences in tank contents.
Toyota's Prius-I, reaching for the hypermiler in all of us xcel Articles 15 08-17-2010 09:45 AM
smart cdi (diesel) hypermiler from Vancouver Canada smartzuuk Start Your Journey Here 2 07-03-2008 02:39 PM
World record distance on a single tank of fuel broken! xcel Fuel Economy 76 08-29-2006 12:08 PM
One Very Concerned Scientist. xcel In the News 0 08-01-2006 01:05 AM
Memorial Day Travelers can save 38% of their gas bill with 6 simple economy tips. xcel Fuel Economy 9 05-26-2006 09:21 AM
