XGauge (CAN-bus) for Dummies...
Tags: , , , ,
Old 06-27-2008, 06:22 PM
Dan's Avatar
Dan Dan is offline
KiloTanked in post 153451
EDIT:
Ok... I feel pretty stupid but I finally get it now. I've been trying for weeks to get my head around what XGauge was doing. Took WFEC and the revelation that we were flying blind without Battery Amps on the Prius to focus my efforts.
Well here's what I found. First let qualify that this is CAN-bus only. Since I'm a Prius Pilot that's all I've been focused on. So what I've found out is that there are two types of CanBus requests. Passive (snooping the bus) and active. Passive is kinda like ease-dropping on a conversation... the data is just there. Passive is like asking a direct question and expecting a direct answer.
Now after doing a bit of digging there is lots of data out there for the taking... Here's what I "think" we can get:
Passive
L/R GForce = TXD { 0x002A }
F/B GForce = TXD { 0x002B }
Steering degrees L/R = TXD { 0x002D }
Brake engagement % = TXD { 0x0038 }
Speed (decameters / hour ) = TXD { 0x00BC }
Gas pedal position = TXD { 0x024C }
Battery Temp = TXD { 0x03C3 }
Ignition timining = TXD { 0x052E }
EV button (on/off) = TXD { 0x0521 }
Gas Fill Level = TXD { 0x05AC }
Active
Battery SoC = TXD { 0x07E321CE }
Battery Temp = TXD { 0x07E321CF }
MG 1/2 RPM = TXD { 0x07E221C3 }
MG 1/2 RPM = TXD { 0x07E221C4 }
Now there is some other stuff like Headlights (on/off) and stuff like that that I'm not that interested in, but this data all looked pretty cool. I haven't gotten that deep into it so don't pepper me with Q's yet, but please help my "Teach Dan XGauge" thread.
If you look for the Passive commands and you can't find them, it's because the passive TXD is derived by taking the ID, left padding it with zeros and XOR'ing it wish 0x0008. Now all this is Attila Vass data, so I don't know if Ron has already tried and failed to get these to work, or if he just figured, no prius driver in his right mind would be interested in how many lateral G's he pulls in a turn. I'm obviously not in my right mind
GForce sensor is the first one I want to try to get working!
Now once I get the TXD working we can work on the rest... Here's my current reference set:
Attila Vass Can Dump (Excel)
2way's XGauge Coding walkthru
PriusChat XGauge Coding walkthru (Passive Can)
Prius Tech Info
PriusChat Known SGII Glide Bug
11011011
Dan <11011011>
Old 06-27-2008, 07:54 PM
bestmapman's Avatar
bestmapman bestmapman is offline
Vehicles: 2007 Prius
Re: XGauge (CAN-bus) for Dummies...
Great thread dan. Can we also write to the can bus. What I am thinking is, can we command engine off when in Neutral. Thus having a glide above 42 MPH.
Drivin slow in the FAS lane.
Old 06-28-2008, 01:41 AM
Dan's Avatar
Dan Dan is offline
Alright... First new XGauge is tested and Verified.
EV Button ( On / Off )
TXD: 05 21
RXF: 01 05 22 29 00 00
RXD: 31 01
MTH: 00 01 00 01 00 00
NAM: EVb
What you'll see on your Gauge is
EVb ON
EVb OFF
And the fun part... It's real-time. No polling delay since it's packet sniffing. I leave it as a homework assignment to decode the logic I used to arrive at the XGauge coding.
11011011
Dan <11011011>
Old 06-28-2008, 11:45 AM
TheForce's Avatar
TheForce TheForce is offline
Vehicles: 2006 Toyota Prius
Looks like your doing what I had planed to do. I just got my SG yesterday. After working with the RAW can-view data and the can-decoder software I'm now familiar with the raw CAN hex data and I know how to convert it.
I'm Not familiar with the way the xgauge does the converting yet. I think I will need an example of how you get from Vass's info to what the SG displays. I'm sure its simple.
I'm really interested seeing the Gforce in real time.
2006 Prius Barcelona #7. Pickup 2006/01/02
For a list of my mods visit http://www.jaygroh.com
Old 06-28-2008, 12:48 PM
Dan's Avatar
Dan Dan is offline
Look through the refereces I listed in the OP and all the XGauge stuff is pretty well explained.
Here's the next dump of XGauges. These are blind codes (untested) so I don't know which work:
Battery Temp (Max)
TXD: 03 C3
RXF: 01 03 02 3B 00 00
RXD: 38 08
NAM: BTc
Battery Temp (Min)
TXD: 03 C3
RXD: 30 08
NAM: BTc
Left / Right GForce
TXD: 00 2A
RXF: 01 00 02 22 00 00
RXD: 10 10
MTH: 00 01 00 01 FE 00
NAM: LRg
Front / Back GForce
TXD: 00 2B
RXF: 01 00 02 23 00 00
RXD: 10 10
NAM: FBg
Alignment (stear left / right)
TXD: 00 2D
RXF: 01 00 02 25 00 00
RXD: 10 10
NAM: Slr
Break Pedal Position
TXD: 00 38
RXF: 01 00 02 30 00 00
RXD: 30 08
MTH: 00 64 00 80 00 00
NAM: BPs %
11011011
Dan <11011011>
Old 06-28-2008, 01:04 PM
TheForce's Avatar
I just tried out the G force setting while sitting still and here is what I seen.
LRg stays at about 3 but if I shake the car the number jumps around a bit.
FBg stays at 1 even when I shake the car.
I will be leaving for work in about an hour and I will report back with my trip results.
Old 06-28-2008, 01:17 PM
Dan's Avatar
Dan Dan is offline
Yeah, it's just a flat hex value. I haven't scaled it to actuall GForce. It should go way positive on a hard left and way negative on a hard right.
11011011
Dan <11011011>
Old 06-28-2008, 01:19 PM
Dan's Avatar
Dan Dan is offline
OK.. got another two coded up but untested....
Speed down to the hundredth place. I always disliked the fact that the speedo doesn't have a decimal point. Well now it does. The MTH was tricky on this so I'll actually be surprised if I got it spot on with the first attempt.
kph xx.xx
TXD: 00 BC
RXF: 01 00 42 B4 00 00
RXD: 38 10
MTH: 03 E8 04 00 00 00
NAM: kph xx.xx
mph xx.xx
TXD: 00 BC
RXD: 38 10
MTH: 08 D8 0E 93 00 00
NAM: mph xx.xx
Dan <11011011>
Old 06-28-2008, 04:09 PM
TheForce's Avatar
Gforce does work. Only problem is that the SG display rate is way too fast. You might have to divide the data by something to get it to slow down or to get an actual 0.00 gforce value.
Old 06-28-2008, 04:19 PM
Dan's Avatar
Dan Dan is offline
All these passive commands are gonna refresh wicked fast. Can't be helped... that's how many canbus packets are flooding the bus. You could do some creative binary shift operations to clip off the last 4 bits or something. That should slow the jitter.
11011011
Dan <11011011>
So, should I stop taking the bus? bomber991 The Daily Grind 26 06-07-2008 10:24 PM
Napa's School District Receives CA's First Plug-In Hybrid School Bus. tarabell In the News 0 08-09-2007 05:53 PM
Vail's hybrid bus goes into service. xcel In the News 1 11-27-2006 12:48 PM
District among first to get PHEV bus. xcel In the News 2 09-12-2006 08:57 AM
DaimlerChrysler Delivers California’s First Diesel-Hybrid Bus to San Francisco. xcel In the News 0 07-01-2006 11:27 PM
