Bump Starting and Engine/Tranny Damage??
Tags: , ,
Old 06-23-2008, 01:36 PM
lnmcmahan lnmcmahan is offline
Econoclast
Vehicles: 2007 Honda Fit, 2002 Mazda MPV Landboat
Re: Bump Starting and Engine/Tranny Damage??
Originally Posted by Siaharok View Post
What are the opinions regarding potential damage to the car from bump starting? I recently bought a new Honda Fit, and I am hesitant to bump start it (although I've already tried the technique described here). Can anyone ease my fears?
Thanks in advance.
Is this a manual transmission FIT. I have a 2007 FIT, and I bump start it constantly. Although most of the time I can hardly feel the "bump."
Larry
Old 06-23-2008, 01:48 PM
Siaharok's Avatar
Siaharok Siaharok is offline
Thanks for the input. Yes, mine is a 5 speed manual. Like you, I hardly feel the "bump" when I use the techniques that basjoos described. But with a new car, I want to be sure that I'm not doing any damage.
Old 06-23-2008, 02:31 PM
BailOut's Avatar
BailOut BailOut is offline
My favorite holiday is Earth Day!
Vehicles: 2007 Toyota Yaris Liftback
Welcome to CleanMPG, Siaharok. I can tell you that while bump starting does indeed cause a bit of mechanical resistance, which is how this starts the engine, there is much less force applied than shifting at high RPM and/or under heavy acceleration.
Also keep in mind that a hypermiler does not typically shift roughly at all, so when combined with our light acceleration and otherwise easy-going handling of the car, even if you bump start dozens of times per day you are still putting less wear and tear on your vehicle than the typical Fit driver does.
The folks that do indeed need to worry about premature clutch and transmission wear are those that "drive it like they stole it".
- Brian
My commute
Share the Road
Old 06-23-2008, 10:16 PM
Siaharok's Avatar
Thanks for that, Bailout. It puts things in perspective. And I'm glad to hear it, because I'm really enjoying bump starting my Fit.
Old 06-24-2008, 03:33 AM
psychojuggalo17 psychojuggalo17 is offline
sorry, im new, but im guessing bump starting is only ok with manuals? if not how would u bump start with an auto(considering u only have 1,2, n D to play with....)
Old 06-24-2008, 09:11 AM
nissynis's Avatar
nissynis nissynis is offline
NC Attorney
Vehicles: 2003 Mitsubishi Eclipse Spyder and 2002 Mitsubishi Montero Sport
Wow, I've been doing the bump start wrong for weeks. I bet I'm not the only one. I think I had been "dumping", because I'd been restarting the car by letting out the clutch all the way, bringing the RPMs up to about 2200, then depressing the clutch and choosing the right gear.
Yesterday and today, I'm letting out the clutch with a quick pop, and then, probably only about halfway or so. Then I'm immediately pushing it back in. There is a strange delay between the pop and the tach needle lifting off of 0, and it only goes to about 1200 or so. Then I am safe to put it in the best gear.
To the experts: does it sound like I'm doing it right now?
Nis
Bst tnk: 653mi/48.2MPG/193%EPA
BHAG: 50MPG tnk
Summer Challenge Dream Goal: 47 MPG
Old 06-24-2008, 09:20 AM
PaleMelanesian's Avatar
Beat The System
Sounds about right. The strange delay may mean you need to pop it up a little higher. At this point it's a matter of finesse and learning your car.
Andrew
Old 06-24-2008, 09:26 AM
BailOut's Avatar
Hello, psychojuggalo17. Yes, this only works with manual transmissions. Automatic transmissions cannot be bump started.
- Brian
My commute
Share the Road
  #19   Submit to Clesto Submit to Digg Submit to Reddit Submit to Furl Submit to Del.icio.us Submit to Spurl
Old 06-24-2008, 09:53 AM
basjoos's Avatar
basjoos basjoos is offline
Thanks in advance.
I have 473,000 miles on my transmission with the original clutch and I've been bump starting for years.
aerocivic.com
  #20   Submit to Clesto Submit to Digg Submit to Reddit Submit to Furl Submit to Del.icio.us Submit to Spurl
Old 06-24-2008, 10:43 AM
nissynis's Avatar
NC Attorney
Wait, did you say "473,000 miles"? Is the clutch the only OEM part left?
Nis
BHAG: 50MPG tnk
