Re: ScangaugeII and FAS
Hi WhatIsChazaq:
___You are set to hybrid mode correct? Also, when you key to IG-II, you leave it in IG-II. Verify the ICE shut down as it takes a little bit for the data stream to inform the SG-II that the ICE was shut down. The Accord can take up to ~ 5 seconds with most a bit quicker.
