The SGII Xgauge Database
Tags: , , , , ,
Old 06-04-2008, 10:46 AM
kmactavi's Avatar
kmactavi kmactavi is offline
Vehicles: 2001 Jetta TDI 5MT
I thought it would be helpful to have a compilation all of the useful XGAUGE documentation and codes in one spot. We can keep building this database, so feel free to list any XGAUGES that you use, but aren't listed here (with the exception of trip gauges or gauges covered in the vehicle specific PDF, see Documentation section). If you try one of these gauges, please post whether it worked/didn't work, or any modifications you made.
Thanks to everyone who posted a gauge on various forums (TDIclub, cleanMPG), because I stole it and put it here.
INTRO
  • Don't forget to save after entering a gauge!
  • TXDs starting with 68 6A F1 are for non-CAN (VPW, ISO, KWP) BUSes, CAN BUSes work differently (see Documentation section). All gauges listed are non-CAN unless otherwise specified.
  • CONF?: field will note if this gauge has been confirmed to work (we can also include the make/model it worked on).
  • ->NAM: field is just a suggested name.
GAUGES
[font="Courier New"]GENERAL
GAUGE: BOOST (TURBO)
CONF?: YES - 2001 Jetta TDI
UNITS: PSI
->TXD: 68 6A F1 01 0B
->RXF: 04 41 85 0B 00 00
->RXD: 28 08
->MTH: 00 91 00 64 FF 71
->NAM: BST
NOTES: THIS WORKS FOR TDIs, NOT SURE ABOUT GAS TURBOS, IT USES MAP. REPLACE FF 71 (14.3 PSI) WITH 2'S COMPLIMENT OF LOCAL ATMOSPHERIC PRESSURE IN PSI (YOU CAN ADJUST THE NUMBER SO BOOST IS 0 AT IDLE). MATH IS #*145/100-143 (CONVERTS KPa -> PSI), SUBTRACTS ATM PRESS IN PSI
GAUGE: HORSEPOWER (GAS)
CONF?: YES-INSIGHT, ...
UNITS: HORSEPOWER
->TXD: 00
->RXF: 40 00 80 00 00 00
->RXD: 00 00
->MTH: 00 0A 00 17 00 00
->NAM: HPW
NOTES: THIS IS FOR GASOLINE VEHICLES ONLY, MATH IS #*10/23
GAUGE: HORSEPOWER (DIESEL)
CONF?:
UNITS: HORSEPOWER
->TXD: 00
->RXD: 00 00
->MTH: 00 0A 00 24 00 00
->NAM: HPW
NOTES: THIS IS FOR DIESEL VEHICLES ONLY, MATH IS #*10/36
GAUGE: INSTANTANEOUS MPG
CONF?:
UNITS: MPGus (OR LPK OR MPGuk DEPENDING ON SETTINGS)
->TXD: 00
->RXF: 80 00 00 00 00 00
->RXD: 00 00
->MTH: 00 01 00 01 00 00
->NAM: iFE
NOTES: OTHER TRIP GAUGES ARE SIMILAR, MODIFY TXD ACCORDING TO SG MANUAL
GAUGE: OPEN/CLOSED LOOP (HEX)
CONF?:
UNITS: N/A
->TXD: 68 6A F1 01 03
->RXF: 04 41 05 03 80 00
->RXD: 28 08
->NAM: O/C
NOTES: DISPLAYS IN HEX,
1: Open, not yet warm
2: Closed, normal
4: Open, due to high load
8: Open, system failure
10: Closed, but something's wrong
GAUGE: OPEN/CLOSED LOOP (ON/OFF)
CONF?:
UNITS: BOOLEAN
->RXF: 04 41 25 03 00 00
->RXD: 2D 01
->NAM: O/C
NOTES: DISPLAYS WHETHER "OPEN, DUE TO HIGH LOAD" IS ON/OFF
GAUGE: Manifold Air Flow
UNITS: g/s (0 TO 655.36)
CONF?:
->TXD: 68 6A F1 01 10
->RXF: 04 41 45 10 00 00
->RXD: 28 10
->NAM: MAF
NOTES:
FOR LEAN BURN HONDAS...
GAUGE: Lean Burn
UNITS: N/A
CONF?: Yes
->TXD: 686AF10115
->RXF: 044105150000
->RXD: 2808
->MTH: 000100020000
->NAM: LBN
NOTES: (For lean burn equipped hondas)
If the value for LBN = 0 you are in lean burn.
If the value is higher than zero, you are not in lean burn.
FOR FORDS...
GAUGE: GEAR RATIO (FORD)
UNITS: #:1 (RATIO)
CONF?: YES-FORD F150 2005, ...
->TXD: 07 E0 22 16 3B
->RXF: 04 62 45 16 06 3B
->RXD: 30 08
->MTH: 00 64 00 3F 00 00
->NAM: GRT
NOTES: CAN BUS
FOR THE FEH...
(See vehicle specific link for more)
Corrections to LL Gauge coding:
GAUGE: Cylinder Head Temp
UNITS: Degrees F
->TXD: 07 E0 22 16 24
->RXF: 04 62 05 16 06 24
->RXD: 30 10
->MTH: 00 02 00 01 00 00
->NAM: CHT
NOTES:
FOR THE PRIUS...
Also See: XGauge (CAN-bus) for Dummies
A message from Dan...
Originally Posted by Dan View Post
Here's a dump of some of the gauges I've found for the Prius. Per the notes the "gps" gauge works on the TCH as well. I have a case convention I hold to. Builtin gauges are all caps, Published gages are lowercase with the first char capped, Discovered gauges are all lowercase.
I've also corrected "Bta" since there is a known error in the previous version. I've also offered up both "Soc" and "soc". Since "Bta" and "Soc" conflict (can't be displayed together), there is a need for non-conflicting versions.
GAUGE: STATE OF CHARGE
CONF?: YES
UNITS: % TOTAL CHARGE
->TXD: 07 E3 21 CE
->RXF: 05 61 86 CE 00 00
->RXD: 30 08
->MTH: 00 0A 00 02 00 00
->NAM: Soc
NOTES: (PRIUS) %
GAUGE: BATTERY VOLTAGE
CONF?: YES, BUT FAILS OF "UPGRADED" SCANGAUGES (3.15*)
UNITS: VOLTS
->TXD: 00 33
->RXF: 01 00 02 3B 00 00
->RXD: 20 10
->NAM: Btv
NOTES: (PRIUS) HV BATTERY VOLTS
GAUGE: BATTERY CURRENT
CONF?: YES
UNITS: +/- AMPS
->TXD: 07 E3 21 CE
->RXD: 38 10
->MTH: 00 01 00 0A F3 33
->NAM: Bta
NOTES: (PRIUS) HV BATTERY AMPS
GAUGE: BRAKE PEDAL POSITION
UNITS: % OF TOTAL DEPRESSION
->TXD: 00 38
->RXF: 01 00 82 30 00 00
->RXD: 30 08
->MTH: 03 E8 00 80 00 00
->NAM: bps
NOTES: (PRIUS) XX.X % DEPRESSION
GAUGE: ENGINE TEMP (NOT COOLANT)
UNITS: DEG C
->TXD: 00 31
->RXF: 01 00 02 39 00 00
->RXD: 10 08
->NAM: etc
NOTES: (PRIUS) °C TEMP OF ENGINE
GAUGE: KILOMETERS PER HOUR
UNITS: KPH
->TXD: 00 BC
->RXF: 01 00 42 B4 00 00
->RXD: 38 0C
->MTH: 03 E8 04 00 00 00
->NAM: kph
NOTES: (PRIUS) XX.XX KPH
GAUGE: GAS PEDAL POSITION
UNITS: % TOTAL DEPRESSION
->TXD: 02 4C
->RXF: 01 02 82 44 00 00
->RXD: 40 08
->NAM: gps
NOTES: (PRIUS / CAMRY HYBRID) XX.X % DEPRESSION
GAUGE: TARGET RPM
UNITS: REVOLUTIONS PER MINUTE
->TXD: 03 C0
->RXF: 01 03 02 C8 00 00
->RXD: 20 10
->MTH: 00 01 00 08 00 00
->NAM: rpm
NOTES: (PRIUS) TELLS ENGINE TO REV. PREDICTIVE RPM
UNITS: % OF TOTAL BATTERY CAPACITY
->TXD: 03 C3
->RXF: 01 03 82 CB 00 00
->RXD: 20 10
->NAM: soc
NOTES: (PRIUS) PASSIVE CA N REQUEST
GAUGE: BATTERY TEMP (UPPER READ)
UNITS: DEG C
->TXD: 03 C3
->RXF: 01 03 02 CB 00 00
->RXD: 30 08
->NAM: buc
NOTES: (PRIUS) °C MAX FOR THE 5 MS CYCLE
GAUGE: BATTERY TEMP (LOWER READ)
UNITS: DEG C
->TXD: 03 C3
->RXD: 38 08
->NAM: blc
NOTES: (PRIUS) °C MIN FOR THE 5 MS CYCLE
UNITS: VOLTS
->TXD: 03 C5
->RXF: 01 03 02 CD 00 00
->RXD: 20 10
->NAM: btv
NOTES: (PRIUS) 3CD PID READING
GAUGE: EV BUTTON STATUS
UNITS: BOOLEAN
->TXD: 05 21
->RXF: 01 05 22 29 00 00
->RXD: 31 01
->NAM: evb
NOTES: (PRIUS) EV BUTTON ON OR OFF
GAUGE: ENGINE COOLANT TEMP
UNITS: DEG C
->TXD: 05 25
->RXF: 01 05 82 2C 00 00
->RXD: 18 08
->NAM: wtc
NOTES: (PRIUS) XX.X °C
GAUGE: GAS GAUGE
UNITS: % FULL THE CURRENT TANK IS
->TXD: 05 AC
->RXF: 01 05 82 A4 00 00
->RXD: 18 08
->MTH: 00 64 00 04 00 00
->NAM: gas
NOTES: (PRIUS) XX.X % FULL
GAUGE: CURRENT AVG. TRIP MPG
CONF?: YES
UNITS: MPG
->TXD: 00
->RXD: 00 00
->MTH: 00 00 00 00 00 00
->NAM: cfe
NOTES: CURRENT FE
GAUGE: DAILY AVG. MPG
CONF?: YES
UNITS: MPG
->TXD: 01
->RXD: 00 00
->NAM: dfe
NOTES: DAILY FE
In the L5 Review thread there was some complaints that the L5 pack causing SOC readings to bounce. I theorized that they are polluting the CANbus with their own data. Here are 4 gauges that I hope will filter out the flicker. The Sts and pts will still show both values, but I hope the Sls and pls gauges will only show the L5 data (I hope). What I need is a dump of traction battery response to the 0xCE pid and the 0x3CB to find something unique to key off of. Without that I can't filter out the L5 data... but then again... I think that was the point.
GAUGE: Solicited Traction SOC
CONF?: Yes, confirmed
UNITS: Percentage of Full charge
->TXD: 07 E3 21 CE
->RXD: 30 08
->NAM: Sts
NOTES: Solicited / Active gauge, so first char upercase
GAUGE: Passive Traction SOC
CONF?: Yes, confirmed on SG FW version "3.15" only not "3.15*"
->TXD: 03 C3
->RXD: 20 10
->NAM: pts
NOTES: Passive gauge, so first char lowercase
GAUGE: Solicited L5 SOC
->TXD: 07 E3 21 CE
->RXF: 05 61 86 CE 09 00
->RXD: 30 08
->NAM: Sls
NOTES: Solicited / Active gauge, so first char upercase. RXF is looking for '00' in byte nine. For the traction battery this is the LSB for the battery current which would always (99.61%) read non-zero.
GAUGE: Passive L5 SOC
->TXD: 03 C3
->RXF: 01 03 82 CB 08 00
->RXD: 20 10
->NAM: pls
NOTES: Passive gauge, so first char lowercase. RXF is looking for '00' in byte eight. For the traction battery this is the temperature reading of the battery. It will only read 0 celcius, when it really is 0 celcius in the battery conpartment.
GAUGE: WHAT GAUGES DO YOU USE THAT AREN'T LISTED?
->TXD:
->RXF:
->RXD:
->MTH:
->NAM:
NOTES:
DOCUMENTATION
VEHICLE SPECIFIC CODES
http://www.scangauge.com/support/pdfs/XGAUGE.pdf
XGAUGE PROGRAMMING
http://www.scangauge.com/support/pdfs/XGaugeCoding.pdf
SGii /w XGAUGE MANUAL
http://www.scangauge.com/support/pdfs/SGMan5_0.pdf
OBDii PIDS (WIKIPEDIA)
http://en.wikipedia.org/wiki/OBD-II_PIDs
XGAUGES FOR FEH THREAD
http://www.cleanmpg.com/forums/showthread.php?t=5747
Canadian Hypermiler
Beating the EPA
Start Here!
Old 06-04-2008, 02:51 PM
hobbit hobbit is offline
Vehicles: 04 prius
Re: The SGII Xgauge Database
This is great, my only snide comment is that this is something
that should be maintained at the linear-logic site. Or at the
very least pointed to from there, so people interested in the
unit don't have to search all over the place for "street knowledge"
on this stuff.
_H*
Old 06-04-2008, 03:09 PM
kmactavi's Avatar
I partially agree with that, and I think that Linear Logic has done a fairly good job of documenting Xgauges in the vehicle specific gauges PDF I have linked to. However, we can't really expect them to update this every time one of their users comes up with another gauge. That's why a user maintained list could be more current, and can include gauges that aren't 'officially verified' by Linear Logic. Just to make this clear, this is in no way trying to be an official list, just a thread to point a new user to when they wonder about what XGauges are available. (And for people who are trying to get gauges working)
Kirk
Canadian Hypermiler
Beating the EPA
Start Here!
Old 06-11-2008, 07:52 PM
-mr. bill -mr. bill is offline
Vehicles: 2006 Honda Civic Si
Curious. I'm wondering if anyone else has monitored both MAF and GPH in a Honda.
On mine, either there is a huge coincidence of conversions from grams/second of air to deci-gallons per hour of gasoline, OR Honda reports GPH*0.1 for MAF pings. (The only time they diverge is during fuel cut.)
-mr. bill
Old 07-15-2008, 07:26 AM
Bykerboi Bykerboi is offline
Vehicles: 2008 Toyota Matrix XR
Hello to all; purchased a ScanGaugeII yesterday and looking for programming for an '08 Toyota Matrix
Old 07-15-2008, 09:53 AM
kmactavi's Avatar
Hi Bykerboi, welcome to the site!
I'm pretty sure the Matrix uses CAN protocol, you can check this on the SG after you have it set up. For CAN protocol, the TXD values for the above codes need to be modified, read the XGAUGE PROGRAMMING PDF in the Documentation section above.
Be sure to check out the links in my signature for driving methods to improve your MPGs.
Kirk
Canadian Hypermiler
Beating the EPA
Start Here!
Old 07-15-2008, 06:10 PM
fanamingo's Avatar
fanamingo fanamingo is offline
Vehicles: 2007 Honda Civic (AT), 1999 Mercury Sable (AT)
@kmactavi, thanks for the resource. It's a good idea. You might want to link to XGauge (CAN-bus) for Dummies..., which has a number of XGauges specific to the Prius.
@-mr. bill, it sounds like you have MAF working as an XGauge. What communication protocol does your car use? My Civic LX uses CANLF, and I can't get any of the XGauges to work.
Old 07-15-2008, 11:28 PM
JusBringIt's Avatar
Be Inspired
hpw works on 99 dodge avenger
Ricardo
Best Segment: 25.3mi@76.9mpg
Old 07-16-2008, 06:56 AM
kmactavi's Avatar
Thanks Fanamingo, it's been added.
Kirk
Canadian Hypermiler
Beating the EPA
Start Here!
Old 07-27-2008, 12:13 PM
mtgeekman mtgeekman is offline
Vehicles: Mazda Miata, Honda Insight
from a post on the Insight Central forums.
To Monitor Lean Burn, type in:
TXD 686AF10115
RXF 044105150000
RXD 2808
MTH 000100020000
NAM LBN
and save
This is just watching the O2 sensor and dividing the value returned by 2. To get actual voltage coming from the sensor you would need to change MTH to 000100C80000. This will divide the value by 200 (normally you multiply by .005)
This has been tested on my insight, along with others.
sgII increased my mpgs..i think? JusBringIt General 7 04-25-2008 11:20 AM
SGII issue whtdvl ScanGauge 6 03-05-2008 05:39 AM
SGII Wild Fluctuations Laker ScanGauge 7 02-21-2008 04:16 PM
Help! SGII losing data during FAS - even in hybrid mode! WriConsult ScanGauge 4 06-04-2007 09:37 PM
