Scangauge IGN value
Old 05-25-2008, 12:06 AM
xcel's Avatar
xcel xcel is online now
Re: Scangauge IGN value
Hi Al:
___I do not bother looking at Load via SG in the Prius’ anymore because the number is swinging around like Tarzan on a vine. IG14 and TPS at 18 w/ SoC at 58.5% or higher SoC (confirmed Dan’s tips wrt that!) when you can hold it and RPM’s in the 1,200 to 1,300 range. For downhill’s, if your SoC is < 60, move to an IG15/TPS 17 at 150 – 200 mpg + vs. WS. Above 60, hold WS until you near 60% and add a little regen to move yourself comfortably above 60 + again if it is availed to you?
Old 05-29-2008, 12:38 AM
hobbit hobbit is offline
Vehicles: 04 prius
Okay, as a possibly helpful exercise I threw together a page
showing the ACTUAL throttle position over a range of reported
TPS values -- hooked up the laptop/scantool and sat it on the
inverter, set up a small tripod straddling the engine and
radiator brace and held the spring fitting open to the right
values while firing away. *Almost* got all the pix lined up
the same, but midway through there was a minor bump to the tripod.
I would say the throttle doesn't get what I'd call "substantially
open" till about 60%, and I don't think anyone EVER sees that
in a Prius.
_H*
New Prius - "Super Highway Mode" Technique (SHM). Dan 2004 - 2009 Toyota Prius-II 166 04-17-2009 11:28 PM
CleanMPG Reviews the ScanGauge II xcel Reviews 19 06-25-2008 02:21 PM
IGN +6 in S1? New Prius Hack? Dan 2004 - 2009 Toyota Prius-II 15 05-19-2008 09:14 AM
A few quick notes on the Prius-II from a non-Prius-II owner … xcel Toyota 67 09-05-2007 08:34 AM
Scan Gauge II FAQ. xcel ScanGauge 0 09-11-2006 10:31 PM
