Brick's Pulse Plug test thread
Old 05-10-2008, 10:36 PM
brick's Avatar
brick brick is offline
60mpg @ 6.29 YeV
Vehicles: '07 Prius
Intro:
Earlier this year, Wayne worked with the folks at Pulstar (www.pulstarplug.com) to arrange for a CleanMPG “Pulse Plug” test fleet, of which my 2007 Prius is a member. The goal is to put some plugs in the hands of experienced hypermilers across the country to determine whether or not the product lives up to their manufacturer’s claims. Specifically, they claim “pulse circuit…more peak power…additional cylinder pressure” blah blah blah “with fuel consumption and associated green house gases reduced by as much as 10%.” In the case of a Prius like mine, the manufacturer claims to have recorded a fuel economy gain of nearly 7% (OK, 6.72% if you want a silly number of decimal places) in controlled testing. But is the claim real enough to justify the purchase price of nearly $25 per plug? Good question!
Testing Methods:
It has been claimed, and I tend to agree, that the “real world” is a lousy place to test anything. Both man and nature can produce variables that could dwarf a 7% fuel economy change, including the following:
-Temperature swings
-Rain
-Wind
-Traffic
-Route changes
-The “nut behind the wheel”
Having spent more than two years dedicating my time behind the wheel to improving my own fuel economy, please believe me when I tell you that these factors are not trivial. My own car has delivered fuel economy in a range between 40 and 75mpg depending on the conditions and my behavior. The real range for all similar cars is more like 30mpg to 120mpg. (For 30mpg, we’re probably talking a caffeine addict in a Fargo winter driving three miles a day. For 120mpg, that’s basically what you get when the fuel economy professionals drive in big circles under ideal conditions for a very long time…slowly.) Suffice it to say that this is where “your mileage may vary” came from.
At this point, the smart consumer asks with a furrowed eyebrow “Then why bother?” Clearly, it’s going to be tough to see 6 or 7% difference when the possible range for a normal vehicle is that large. But the good news is that we can narrow the range by being very careful about how the test is conducted. We can also improve our ability to find meaning in the results by recording the things that commonly send a test sideways. So here’s a breakdown of how I plan to accommodate the variables that I think are most important:
Route: Obviously, if you drive up and down mountains one day and putter around a dead-flat town the next, your fuel economy will be different. This is why recording a single number for each tank of gas and declaring victory is a bad idea. One tank of gas for me could mean commuting for two weeks or taking a road trip to Atlanta. Or the difference could be as mundane as making more extra trips to the store for one tank than the other, which is more than enough to skew a result. To take care of this, I will only record data on my regular commute which is the exact same 21 mile (each direction) route every single work day. So every morning, I reset the trip computer before I light the engine and record the result when I park. Same thing on the way back. And if I make a stop or a detour, the trip doesn’t count. Works for me.
Driving habits: Maximum fuel economy! Experienced hypermilers can get ridiculously regimented in their daily routine, to the point of timing accelerations and decelerations down to a specific crack in the road. On my daily grind, that’s pretty much where I am. That doesn’t mean that I can make every trip perfectly identical, but repeatability is quite reasonable. (This will be supported or refuted by the data when it is available.)
Temperature: This is a huge one. The ambient temperature can make the difference between a high fuel economy result and a new personal best. Worse, it changes constantly! So the only thing I can do is record it. At the beginning and end of each recorded segment, the temperature will be recorded along with the fuel economy. I suspect we will see a visible relationship between FE and temperature that will be useful in analyzing the results.
Vehicle set-up: This is another big one. Tire pressure is an obvious variable, and I mitigate it by checking and adjusting once weekly. Checks will be made early in the morning, which should keep things reasonably consistent throughout the trial period. There are other things that could change over a longer period of time (like oil condition) so I’m not going to do just one round of on-off testing with the pulse plugs. Expect to see me do at least two full rounds, four weeks each (for a new 16 week test) without any changes or modifications to my equipment except for the spark plugs.
Weather flukes: There isn’t much that can be done about the weather except record it, so that’s what I’ll do. If the weather is anything but dry and calm I’ll make a note.
Traffic flukes: As with weather, observe and record. Anything off-normal for a segment can be noted, and the trip data thrown out if necessary.
So is something missing? Probably. I’ve already admitted that there’s no perfect “real-world” test and there isn’t much that can change that. But I think that I’m doing as well as anyone could do to produce a pretty good one. Time will tell if I’ve pulled it off!
UPDATE:
Preliminary results are in! I’ve recorded four weeks’ worth of data for each set of plugs. I have to say that it didn’t turn out quite the way I expected. Here’s a simple plot of morning segment fuel economy:
If you look at the blue dots (FE and starting temperature on stock plugs) it’s pretty clear that FE and temperature are well correlated. That FE goes up with temperature is no surprise to anybody around here. And overall the same is true of the pulse plug data. But what’s with all the noise? I started to get odd FE numbers as soon as the Pulse plugs went in and after a month things never evened out. The same thing happened with the afternoon segment:
By now I’m sure you’ve had a look at the charts and noticed something more interesting: FE with the Pulse plugs got noisy, but it did not increase. Two or three segments in warm weather were a bit better than the others but the distribution indicates, if anything, worse fuel economy overall. So to me the conclusion is very simple: The Pulstar “Pulse Plugs” do not live up to the claims. At best, they deliver the same fuel economy as stock spark plugs. But they cost $25 each ($100 for a humble 4-cylinder) and are supposed to last only 50,000mi (stock irridium plugs are good for 100,000mi.)
So what’s next? If I take any more data it will have to be morning segment only since we’re getting into serious A/C season here in SC. Some afternoons I have to run climate control, sometimes I don’t, and any numbers from those conditions would be pretty worthless. I will be paying attention to see if the FE stabilizes, though. The most irritating part of this experiment was having FE start to vary for no discernable reason. It makes me wonder just what these spark plugs really do.
Tim
Old 05-10-2008, 11:02 PM
msantos's Avatar
msantos msantos is online now
Eco Accelerometrist
Vehicles: 2006 HCH, 3x2007 Prius, 2010 Prius
Re: Brick's Pulse Plug test thread
Hummm... very interesting plugs and equally interesting claims of performance (FE especially). I would not mind doing a review on them either at some point...
Lets see: $24.94 for each plug and I need eight (8) of them for my HCH-2... for a grand total of $200.
Cheers;
MSantos
Old 05-11-2008, 01:02 AM
xcel's Avatar
xcel xcel is online now
Hi Tim:
___I cannot wait to see the results
___By the way, nice initial write-up too!
Old 05-11-2008, 01:36 AM
hobbit hobbit is offline
Vehicles: 04 prius
I think to have a good controlled test you'd have to be
A-Bing them in and out of the car almost weekly, and waiting
to average everything out over a year's worth of data
collection. That's the only way to handle weather, subtle
changes to your own style over time, and the other things
that can creep in. Average those away and hopefully you'd
have a clean signal on whether the plugs help or not.
_H*
Old 06-13-2008, 01:31 AM
koreberg koreberg is offline
Vehicles: 1995 Honda Del Sol Si(6.5" ride height), 1990 Honda Crx Si, 2007 Honda Odyssey Touring
Any news on these things, i've been waiting for a while to see some tests from someone who I can have some sort of trust level, beyond manufacture claims.
Diesel or Hybrid? I don't want to choose!
Old 06-13-2008, 08:02 AM
brick's Avatar
60mpg @ 6.29 YeV
Vehicles: '07 Prius
Yeah, I completed a round of testing earlier in the week. I've been trying to make sense of the data and should be able to post something this weekend.
Tim
Old 06-14-2008, 06:53 PM
brick's Avatar
60mpg @ 6.29 YeV
Vehicles: '07 Prius
Updated with data. Verdict: NO IMPROVEMENT TO DATE.
**EDIT**
And yes, I realize the charts didn't upload very well. I'll fix the axis labels later.
Tim
Old 06-16-2008, 02:16 AM
kwj's Avatar
kwj kwj is offline
I hypermiled this
Thanks Tim. I think everyone appreciates what you've done with this product. I wonder if they were less expensive, if they might be worth it. One would always wish to recouperate any investment over what a normal plug would cost, but if I hear you correctly, that return on the investment isn't panning out for you - yet.
Outside the lab, controlling variables is hard. But the product would have to work out in the real world too. Again, thanks, and we look forward to your final conclusions.
Perhaps others can think of ways to conduct additional tests. I can't.
Old 06-16-2008, 02:22 AM
sailordave sailordave is offline
Vehicles: 2003 Chevy Malibu 3.1L V6(mine) 1996 Mazda Protege 1.5L (wife)
I was also curious about these plugs until I saw the price. What you said about lab and real world also goes for many other things. Just because something works great in a lab doesn't mean it does the same outside the lab. Can't count the number of times we've had to have a talk with engineers about why their plans don't work in reality. Most of the time these are engineers who never turned a wrench in their life.
Old 06-16-2008, 07:50 AM
brick's Avatar
60mpg @ 6.29 YeV
Vehicles: '07 Prius
Fortunately this was a "sponsored" test in that the manufacturer provided the plugs, so the return on my investment ($0) is turning out just fine. But if I had spent $100 I think I would be pretty upset by now. It will be interesting to see how the other testers make out with theirs.
Tim
Beating the EPA - The Why’s and How to Hypermile xcel Articles 104 09-07-2009 06:18 PM
New side impact crash test results: Impala, Avalon are top large car performers. xcel In the News 0 06-19-2006 05:37 PM
