New Member w/ questions
Tags: , ,
Old 05-01-2008, 09:33 PM
Blue Genie's Avatar
Blue Genie Blue Genie is offline
Vehicles: 1996 Honda Accord 2.2L auto,
I just joined and have been doing my first 'test tank' of gas. So far, so good. I have not checked the mpg yet but I was averaging 25-26 mpg combine hwy and city. I have a 1996 Honda Accord, automatic, 2.2l non-Vtech. I have not changed the oil yet but tires are inflated to full psi.
Couple of questions,
-My honda calls for 5w-30 oil. Is it safe to use 0w-20, 5w-20?
-Can I shift into neutral during coasting w/o turning the engine off safely?
Any other suggestions on how to maximize an automatic's FE would be appreciated. Thanks!
Old 05-01-2008, 10:46 PM
bomber991's Avatar
Re: New Member w/ questions
You should be able to shift into neutral while rolling with the engine on just fine. Thats called a NICE-on coast. When you shift back into drive you want to rev-match. That is, take note of what rpm you're at before you go into N, and then before you go back into D, press the gas some to get the rpms back to what they were before you went into N, and then go back into D.
One way to easily maximize your FE would be to simply keep the speeds down. Try and stay under 55 to 60mph. For example, in my car the difference between 32mpg and 28mpg is the difference between 60mph and 70mph.
Just be sure to read, and then re-read the "beating the EPA" article under the article tab on the left side of the screen.
-Justin
Old 05-02-2008, 01:26 AM
Elixer Elixer is offline
Vehicles: 2004 Ford Focus LX
Read the basic hypermiling article on the right side of the startpage and then reread it a few times. Automatic transmissions can do just about everything a manual can do except many of them cannot FAS without causing damage to the transmission over time. Get your tire pressures up, and practice some good predictive driving, DWB, DWL, Nice-On coasting. Once you have those down then you can start pulsing and gliding.
Old 05-02-2008, 08:50 AM
PaleMelanesian's Avatar
Beat The System
Read the owner's manual. See what it says about flat 4-wheel towing. It probably says something like "below 35mph and less than 50 miles". In that case, any time around town you're fine to FAS, but not on the highway. Leave it running, but still use Neutral to coast.
I'm running synthetic 5w20 in mine.
Andrew
Tire geometry / pressure questions lyekka General 3 04-09-2008 07:33 PM
Texas Green Expo - Hybrid & Hypermiling discussion by CleanMPG member. Chuck General 5 05-24-2007 09:11 PM
Diesel car, lots of questions jeffklein Start Your Journey Here 11 02-27-2007 10:10 PM
Question(s) about Insight RE92's lindermant General 7 08-01-2006 10:52 AM
