Optimum Speed/RPM on Civic
Old 04-29-2008, 11:04 AM
KrazyDawg KrazyDawg is offline
Vehicles: 2008 Toyota Yaris LB AT 3dr
I have a 1995 Honda Civic Auto 1.6L VTEC. What speed would give me the best mileage? I've heard anywhere from 45-55 as typical and some rare exceptions at 65. At 65, I get 2500 RPM, 60 MPH = 2400 RPM, 55 MPH = 2200 RPM, 50 MPH = 2000 RPM. I've been slowly accelerating and noticed if you push on the gas pedal too hard, the car will shift up to 3000 RPM (probably when VTEC kicks in). Likewise, less than 2000 RPM doesn't seem ideal if you step on the gas pedal too slowly. I've been trying to keep it between 2000-2500 RPM. Since the car can't use a ScanGauge, I've had to guess at what works.
Old 04-29-2008, 11:11 AM
PaleMelanesian's Avatar
Beat the System
Re: Optimum Speed/RPM on Civic
Keep the rpm low. Learn the car's shift points. If it shifts at 45 into top gear, get it up to 46 or so and let up on the gas. It'll shift, and then you can get back on it in the higher gear. "fake-shift"
I use a fairly heavy acceleration rate, but my manual will allow that without downshifting. Since you're driving an auto, just keep it as low as possible. I'd say below 2,500 while accelerating.
For cruising, the lowest speed that will hold top gear will give you the best numbers. Don't give it enough gas to shift down, but just a touch less than that.
I've done 34 mpg in my Odyssey (V6 auto) using these ideas, along with neutral-coasting. It's rated 21 combined.
Andrew
88.3 mpg commute 72.8 mpg / 946 mi tank
100 mpg commute 90.2 mpg / 1191 mi tank
Old 04-29-2008, 11:52 AM
JusBringIt's Avatar
Be Inspired
usually a few mph over the lowest speed possible in the highest gear yields the best fuel efficiency. you will probably get the best efficiency at 50 mph, but you can do what one of our members did and just do a few tanks at 50, a few at 55 and a few at 60 and find the trend. i will guess that at 50 mph you get the best efficiency. my car is in top gear at 41/42mph, but my highest efficiency level is at 50mph. this is sometimes listed in the manual.
Ricardo
Best Segment: 25.3mi@76.9mpg
Old 05-01-2008, 03:04 AM
Compaq888's Avatar
Compaq888 Compaq888 is offline
Vehicles: 1999 Honda Civic 5spd
it's weird that you use a "fairly accelaration rate"...and yet you got 50+mpg..
can you tell me your shift points for every gear...?
mine are
into 2nd at 10mph
into 3rd at 15mph
into 4th at 20mph
into 5th at 25mph
Goal of 50MPG
Old 05-01-2008, 09:22 AM
Beat the System
2nd as soon as possible, probably 2-3 mph
3rd at 10
4th at 15-20
5th at 30+
I'm very intentional about my acceleration rates. I want to keep the engine in a low-rpm, high-load position. If you keep the rpm that low, you won't really be accelerating very fast anyway.
This Autospeed article explains.
The best BSFC is the red area centred around 2000 rpm and three-quarters load.
I try to keep in that area as much as possible, and when I'm not, the engine is off. Pulse & Glide.
Andrew
Old 05-01-2008, 08:35 PM
Compaq888's Avatar
3rd at 10
4th at 15-20
5th at 30+
That's very interesting! but i don't think my 4th is going to like 15mph...anything under 20 and it has problems..
lol I remember when I bought the car...if I put it put it into 5th below 32mph it would barely move and almost stall...
I replaced the pcv, some hoses that looked bad, air filter, spark plugs, spark plug wires and now i can put it into 5th at 25mph wihout problems..
Goal of 50MPG
Old 05-02-2008, 10:32 AM
Since my car is a 4 speed automatic I should only have 3 shift points right (2nd 3rd and 4th)? It seemed like my car had 4 shift points when I felt the car give a little jolt every time it shifted.
Old 05-03-2008, 11:15 PM
pumafeet10 pumafeet10 is offline
Vehicles: 1997 Honda Civic HX
PaleMelanesian ... How are you getting such good mileage???? Are you using a scangauge? if you are what are your values on the gauge cuz i have a 2000 cx hatch and probably a lighter car and i am def not getting the mileage id like to be getting! i am def doing something wrong. Most of my highway driving is a 19 mile strip from my house to scholl going 65( spped limit) i get up to speed slowly and my tps is low and gph is low ... sorry not trying to thread jack
Old 05-04-2008, 12:01 AM
warthog1984 warthog1984 is offline
For an Auto, what's the best acceleration rpm? 2k won't accelerate much at all and the shift doesn't seem to happen until 2600-2700rpm, so vtec-e engages sometimes.
I'm confused.
Old 05-04-2008, 09:16 AM
Beat the System
Let me restate my numbers. After i posted that, i realize they're a bit low.
1st: just to get started
2nd: from <5mph
3rd: from 10-15
4th: from 20
5th: from 30-40, depending on needs and terrain
For auto, just play with it. keep it as low as possible within the shift ranges built into your car.
Andrew
CleanMPG Reviews the 2007 Honda Civic 2.2L iCDTi Turbo Diesel xcel Reviews 31 07-21-2011 01:57 PM
STYLE RECLAIMED: How the Civic got its groove back: tigerhonaker Honda 4 12-21-2008 07:48 PM
CleanMPG Previews the 2004 Honda Civic Compressed Natural Gas powered GX xcel Reviews 0 11-12-2007 12:17 AM
Honda's Civic Cooling. xcel In the News 3 03-16-2007 04:22 PM
Honda getting its groove back with Civic tigerhonaker Honda 0 05-31-2006 08:37 PM
