| 2004 - 2009 Toyota Prius II Hatch Everything and anything relating to the Second Generation Toyota Prius Hatch. |
Prius over a curb
04-24-2008, 01:21 PM
KiloTanked in post 153451
Prius over a curb
I have been invited to present on the Prius in the morning and was just told that they want to drive it into the gym. I'll have to navigate a standard US curb. Has anyone driven a Prius over a curb (intentionally) without bottoming out?
Can anyone think of some ramps or something to help out (maybe at walmart or autozone)? I'm not concerned about getting the front wheels over, my main concern is getting the rear wheels over without bottoming out the under carriage in some way half way from the front wheels to the back.
Thoughts, Suggestions?
11011011
PS: Sorry for cross-posting, I needed a wide exposure.
MPG Centurion- Hybridfest 2007- Prius II-26mi @ 106 MPG (sg2)
Dan <11011011>
04-24-2008, 01:40 PM
Rosie the Riveter Redux
Vehicles: 2007 Prius
Re: Prius over a curb
Dan,
I have some ramps that I bought at Advance Auto Parts that I use for oil changes.
http://www.advanceautoparts.com/default.asp
There's one in Cypress. They are kinda pricey......$40 IIRC?......but they will be all the ramp you need. I actually bought 'em initially for the doggone EBH.
I don't have experience with curbs, but my guess is that scraping would be involved.
04-24-2008, 01:41 PM
Penguin of Notagascar
Can you get to it using a standard sidewalk? If so, would you be able to use one of those slopes down to the road intended for wheelchairs?
If not, consider approaching from a wide angle rather than head on -- so that you get one side up and then the next side up. That should help reduce the possibility of scraping the underside because of the angles...
- Sean
New? Start here!
04-24-2008, 01:43 PM
Get a pair of 2x6s from the lumberyard, lay them over the curb as a long & cheap ramp, and you're set.
04-24-2008, 01:48 PM
I was afraid that a 2x6 would buckle under the weight of the car. Each one would be supporting maybe a lot of weight.
Both of these help me get the front wheels over, but I still have to make it from my front axle to my back axle without the under-carriage bottoming out. Think I'd need a 4 foot ramp at least.
11011011
Dan <11011011>
04-24-2008, 01:55 PM
Here's the problem as I see it:
making a long enough ramp to elevate the back axle (and under-carriage).
11011011
Dan <11011011>
04-24-2008, 01:56 PM
Hypermiling Ironman
Vehicles: 96 Ranger 5MT, 98 Ranger AT, 92 Ford Van AT
if you have a 4" curb to go over, 3 2x6s will do fine: 2 high at the curb and 1 high in front of the 2. If its a taller curb, still will be ok. And they'll take the weight just fine laying flat on the ground... heck we drive dumptrucks up curbs that way.
Ok seen your sketch, how high is the curb. Hmmm... what is min ground clearance on car? if taller than curb shouldnt be a problem
04-24-2008, 02:10 PM
Dan, my ramps are high and long enough to potentially do the job and avoid your problem anyway. They are probably 1 foot x 4 feet? Don't quote me on that.
The ramps I have are not metal. They are pretty tough and durable, but any contact with the Prius is likely to do more damage to the ramps.
Here they are:
http://www.partsamerica.com/productd...egoryCode=3400
Pretty close to my size prediction...........
04-24-2008, 02:18 PM
Beat The System
Use 2x6's set lengthwise and stacked. The loading will be completely flat against the ground and the extra length will avoid belly-scraping.
Andrew
04-24-2008, 02:52 PM
Hypermiling Ironman
Andrew, looks good, that will be a good solid base, and depending on height of curb, probably longest board maybe 4'?
