Filters
Old 04-23-2008, 11:55 AM
chad_55 chad_55 is offline
Filters
There seems to be a lot of different opinions on what automotive filters are the best to improve gas mileage. I use STP brand oil & air filters from AutoZone. Can I get some opinions on this?
Old 04-23-2008, 11:58 AM
PaleMelanesian's Avatar
Beat The System
Re: Filters
I highly doubt an oil filter will improve or harm MPG. The difference will be how well they filter. I use SuperTech.
Air filters don't really matter if you're driving for efficiency. The surface area is more than adequate to flow all the air we need. Standard paper filters clean the air the best, proven by multiple lab tests.
Andrew
Old 04-23-2008, 12:03 PM
JusBringIt's Avatar
Be Inspired
Re: Filters
stay away from fram oil filters, everything else should be good. for air filters, I use a washable/reusable filter that makes it easier to breathe, whether you choose warm or cold, that is up to you.
Ricardo
Best Segment: 25.3mi@76.9mpg
Old 04-23-2008, 12:10 PM
xcel's Avatar
xcel xcel is online now
Re: Filters
Hi Chad:
___Just like Andrew, a SuperTech oil filter because it is HQ and inexpensive (adds nothing to FE) and a std. Fram air filter. Just make sure the Air filter is not dirty (yearly replacement) and you have maxxed your FE where that item is concerned.
Old 04-23-2008, 12:14 PM
Beat The System
Re: Filters
Bobistheoilguy (BITOG) did a comprehensive air filter test. Here it is. His findings are that even the highest-flow (K&N) flows barely better than the lowest-flow paper filter. Also, the dirt collected downstream of all the high-flow filters is scary! It's a long read, but good information.
MetroMPG tested K&N vs oem paper for mileage. Here. OEM actually gave him better mpg.
Also, according to this post at BITOG, oil filters with brands STP, Supertech, mobil 1 and others are all from the same maker. Pick a cheap one from the list.
Andrew
Old 04-23-2008, 06:03 PM
Douglas in CT Douglas in CT is offline
Newbie Hypermiler
Vehicles: Scion xb (2005)
Re: Filters
According to my research on Oil Filters:
- Buy WIX Oil filters
NOTE:
WIX Oil Filters are also Privately Labeled for NAPA as NAPA GOLD.
Old 04-26-2008, 11:35 AM
kwj's Avatar
kwj kwj is offline
I hypermiled this
Re: Filters
The best filters are the ones you replace frequently. Air filters probably don't get changed as often as recommended. As to MPG increases, the oil you use probably has more of an effect than the filter you use. A good filter will keep your engine oil cleaner to a point, but typical motor oils get inundated with things a filter won't remove, so change the oil as recommended. Oil Filters are inexpensive, change them at each oil change. As to brand, everyone has an opinion, but some are really better than others. Choose ones that filter out smaller particles. I've used Fram filters for many years. They've given me good service, as all my vehicles see in excess of 150,000 miles and still pass hydrocarbon emissions tests
Old 04-26-2008, 11:49 AM
Re: Filters
I'm a sucker for the Mobil One filters even though I'm still pissed at Mobil for changing to a not really synthetic cheapo oil in their Mobil I.I still use Mobil I, but I'm still pissed at them;I hold a grudge. Pep Boys offers a DIY special 5 qts Mobil I + filter for $30-not bad.
Charlie
K&N Filters jimepting Technical 8 06-04-2008 11:50 AM
Oil Filters May Make a Difference Chuck General 18 12-04-2007 12:42 PM
Sparks Plug gap and Air filters Springer03 Fuel Economy 7 08-21-2007 11:28 PM
Diesels clean up their act for U.S. xcel In the News 0 07-14-2006 06:41 PM
Cabin air filters Texashchman Honda 4 05-23-2006 10:13 PM
