Scangauge reads .08 GPH when ICE is off
Old 04-17-2008, 01:52 PM
mintsk8er's Avatar
mintsk8er mintsk8er is offline
Vehicles: 1997 Saturn SW2
I'm not sure if this is just a calibration issue... shouldn't gph read 0.0 when the engine is off no matter if the SGII is calibrated or not? I haven't gone through enough gas to accurately calibrate it yet but I'm confused as to why it would show that. Is that normal?
EDIT: I mean't .08 gph
Ryan
Mintsk8er's Vehicle Mileage Log
Old 04-17-2008, 02:04 PM
CarlD CarlD is offline
Vehicles: 2005 Ford Escape Hybrid
Re: Scangauge reads .8 GPH when ICE is off
It may be that the car is no longer sending data and the 0.8GPH is the last value that was received. My FEH key must be in the RUN position to get any data from the network.
Old 04-17-2008, 02:05 PM
2way 2way is offline
Electromagnetic Wave [:-h
Vehicles: 2002 Toyota Celica GT-S/6 1996 Toyota Avalon XLS
It will read the last valid value out of the ECM, in many cases.
Yep, normal.
Old 04-17-2008, 02:09 PM
mintsk8er's Avatar
Ok, sounds reassuring I suppose, but my idle gph with the enigne on is always above .32 gph sometimes in the .4x range. Doesn't that sound high for a Saturn?
One other thing: When I'm in a fas (with the key in "run" position), it stays at .08 gph also... which means my MPG is some where in the 400's or so at around 35 mph, shouldn't it be going up to the max (9999 mpg)?
Ryan
Old 04-17-2008, 02:14 PM
mintsk8er's Avatar
Actually, you know what, thats impossible because it read .08 gph when I first plugged it in to the car before I even turned it on. So theres no way it could have been notified by the enigine of a "previous value". Unless of course my car's computer is outputting the previous value from it's memory... any ideas?
Ryan
Old 04-17-2008, 02:28 PM
PaleMelanesian's Avatar
Beat The System
Something is way wrong here. I'm not sure I can get my GPH that high if I try. Double-check all the settings - engine size, speed offset, fillup offset, fuel cut threshhold... You might do best to restore defaults and re-setup everything.
Andrew
Old 04-17-2008, 02:32 PM
mintsk8er's Avatar
ok hold up here. I think it's .08.... not .8 sorry.
And .32 - .4x
lemme change that...
But, still I think somethings not right. Sorry for that mistake, I've probably confused everyone by now.
Ryan
Old 04-17-2008, 02:50 PM
Beat The System
Ah, that's normal, then. Mine reads .3 and sometimes .2 when warmed up.
Check the DFCO cutoff point, maybe. My sg is older and doesn't have that, so I can't be sure.
Andrew
Old 04-17-2008, 03:07 PM
mintsk8er's Avatar
I don't know if my car has dfco. Would someone else know if a 97 sw2 does? When I take my foot off the gas pedal gph remains at about what my idle fuel consumption is.
Ryan
Old 04-17-2008, 03:21 PM
Beat The System
2 things going on: Does your car have DFCO, and how is the SG reporting it. At best, it's just reporting an estimate.
First one - Do a coast-down test in gear with the ignition on. Then repeat the same test in gear with the ignition off - leave it off. If the results are similar, you do have Decel Fuel Cutoff. If the ign-on coasts farther, it's still injecting fuel.
Second: check the Scangauge manual for adjusting how it reports this.
Andrew
Toyota's Prius-I, reaching for the hypermiler in all of us xcel Articles 15 08-17-2010 09:45 AM
CleanMPG Reviews the ScanGauge II xcel Reviews 20 04-07-2010 12:16 AM
Texas-Sized Antartic Ice Shelf Thinning Chuck In the News 1 03-29-2007 08:50 PM
Scan Gauge II FAQ. xcel ScanGauge 0 09-11-2006 09:31 PM
Using the ScanGauge to assess pump calibration brick ScanGauge 2 09-07-2006 05:42 PM
