when I coast in my 2004 honda civic...
Discussion in 'Start Your Journey Here' started by mpgdad, Apr 6, 2008.
  1. mpgdad
    mpgdad Well-Known Member
    Its an automatic.
    I am getting about 32mpg at this point.
    I just inflated the tires to mid 40's.
    I just changed the oil to mobil 1 synthetic.
    When i coast i try to put the car in neutral. Its fine except when I take it out of neutral and put it back in drive. The car seems to have a slight jolt(foot is not on accelerator).
    Its a subtle jolt but its there. Should I avoid putting the car in neutral when coasting?
  2. JusBringIt
    JusBringIt Be Inspired
    This jolt may or may not be bad depending on your transmission. Mine had done that at times but b/c it's a learning transmission it's been mostly eliminated. you are engaging a gear, so it is gonna feel a little bit off when you engage an auto from neutral. I would consult with the manual or any info available from someone knowledgeable on the transmissions from your platform to see if that's ok to put your car in neutral. I've been doing it for a year on my car. no issues thus far.
  3. shifty35
    shifty35 Well-Known Member
    Blip the throttle before shifting into drive. The "jolt" will diminish the closer you are to the proper RPM upon re-engagement.
