Rebuilt the boattail
Discussion in 'My Ride' started by basjoos, Sep 27, 2007.
  1. yab13e
    yab13e Active Member
    It looks really cool, especially from the back. How did you make the rear hatch? Also is it Lexan? Thanks.
  2. basjoos
    basjoos Well-Known Member
    The glazing is Lexan and is attached to a frame attached to the hinges used by the original hatch.
  3. 93Hatch
    93Hatch Well-Known Member
    How much mpg did you gain with the boattail?
  4. basjoos
    About 6mpg.
  5. 93Hatch
    So realistically I could get > 50 mpg in my 93 Hatch with no body work, right?
  6. xcel
    Hi 93Hatch:
    ___Which 93 Civic do you own and yes, it should be possible to hit 50 mpg with a little work on your side of the fence if that auto is capable …
  7. PaleMelanesian
    Yes. You'll have to work a little harder with the auto, but it's within reach. Mine's a manual, but it's heavier than the early 90's models, and it's the heavier 4-door. I consider it a bad day if I'm as low as 50.
    Edit: and I have the bigger 1.6L engine, to your 1.5.
  8. basjoos
    Get a SuperMID (a scangauge-like device for OBD1 (pre-1996) vehicles) so you can get a real-time display of what mileage your car is actually getting as you drive down the road so you can fine tune your hypermiling techniques. They are $150 from Yoshi, who makes them (he's a CleanMPG member, you can PM him) .
  9. 93Hatch
    I assume that the SuperMID will not work on my 2000 Accord? It would be nice to get a scan tool that would work on either vehicle.
  10. Maxx
    Maxx He who posts articles
    Basjoos - Have you done any aero work to the undercarriage? For some reason I was thinking about this on my ride to work today ("I wonder if that guy with the funky civic has undercarriage panels?")... Anyway, if not, you could probably pick up 2-4 mpg.
  11. basjoos
    I have smooth underbody panelling that covers the entire underside of the car except for a small gap around the muffler (with a fairing behind the flat back of the muffler). Also wheel spoilers ahead of the front and rear wheels, double side skirts between the front and rear wheels (outer side skirt even with the outer edge of the tires, inner side skirt even with the inner edge of the tires), and a mini-boattail behind each rear wheel. The effect of aero mods is accummulative, the contribution of each mod may be small, but the sum of all of the mods together is substantial.
  12. jzed
    jzed New Member
    Great project!
    Two questions...
    1) Do you have problems passing state vehicle inspections with your aero-mods?
    2) Are you going to aero-mod that RV? (Only half joking)
  13. shifty35
    shifty35 Well-Known Member
    Bas, any chance of getting pictures of the underbody work?
    I'm thinking about working some panels up for the Insight, as well as blocking the upper air dam with a carved foam block (or similar).
    The Insight has fairly good underbody work but the whole exhaust is exposed in the center channel - I imagine this is for cooling purposes, but there's no way that exhaust gets that hot.
  14. basjoos
    jzed - Fortunately my state dropped state vehicle inspections in the early 90's. That RV mainly serves as a guest cottage and is rarely driven, so I haven't had much incentive to aero mod it yet.
    shifty 35 - Since it has low ground clearance, it is difficult to take a good photograph of the bottom of my car, but those that I do have are posted on my photobucket site:
    http://smg.photobucket.com/albums/v417/MikeMariettaSC/80MPG Honda Civic/
  15. kc8enb
    kc8enb Member
    wow bit too out there for me but the rear really reminds me of a auburn boattail speedster. i like your new hatch design. your structure for the rear looks quite strong.
  16. basjoos
    I guess when the Aptera becomes a common sight on the highways, the appearance of my car won't come across as quite so unconventional.
  17. kc8enb
    kc8enb Member
    i had to look up what an Aptera was. looks nice, same day they will be more common. btw what was your underbody skin and how did u deal w/ it around the engine/axles? also did u do a warm air intake? sry for all the noob questions
  18. basjoos
    The underbody is made of coroplast, with aluminum flashing nearIt covers the entire underside of the car except for where it flairs into the exposed underside of the muffler. the exhaust system. I didn't build a warm air intake, but the grill block effectively increases the intake air temp.
    There's nothing new or avent garde about the design of my car, most of its aero is 70 year old technology. This Maybach was running the Autobahn back in 1939.
  19. kc8enb
    kc8enb Member
    max props when i have my grandmother and father emailing me pics of your car sayin "this guy gets over 70mpg, u do something similiar" lol
