2007 Mazda3 4 and 5-door sedan
Discussion in 'New Automobile Specifications' started by xcel, Sep 6, 2007.
    Engineering:
    Displacement (cc): 1,999 (4-door only)/2,260 (4 and 5-door)
    Horsepower @ rpm (SAE net, Rev 8/04): 148 T2B5 – 144 PZEV/156 T2B5 – 151 PZEV
    Torque (lb.-ft. @ rpm): 135 T2B5 – 132 PZEV/150 T2B5 – 149 PZEV
    Redline (rpm): 6,500
    Bore and Stroke (mm): 87.5x83.1/87.5x94.0
    Compression Ratio: 10.0:1/9.7:1
    Valvetrain: 16V-DOHC
    Multi-Point Fuel Injection
    Front-Wheel Drive
    CARB Emissions Rating: LEV-2 or PZEV
    Federal Emissions: Tier II/Bin3 or Tier II/Bin5
    100,000-Miles-or-More Tune-Up Interval*
    Transmissions:
    Gear Ratios
    5-Speed Manual Transmission
    1st: 3.307 2nd: 1.842 3rd: 1.310 4th: 0.970 5th: 0.755 Final Drive: 4.105
    Reverse: 3.166
    4 (2.0L only) and 5-Speed Automatic Transmission (available)
    1st: 2.816/3.620 2nd: 1.497/1.925 3rd: 1.000/1.285 4th: 0.725/0.933 5th: NA/0.692 Final Drive: 3.683/3.683 Reverse: 2.648/3.405
    Body/Suspension/Chassis:
    Unit-Body Construction
    Independent Multi-link Rear Suspension
    Stabilizer Bar (mm., front/rear): Unknwn.
    Electro-Hydraulic Power Assist Steering (EHPAS) Rack-and-Pinion w/ Variable Assist Steering
    Steering Wheel Turns, Lock-to-Lock: 2.9
    Steering Ratio: 14.6:1
    Turning Diameter, Curb-to-Curb (ft.): 34.1 ft.
    Power-Assisted Ventilated Front Disc/Solid Rear Disc Brakes (in.): 10.9/10.4 (2.0L only)/11.8/11.0
    Wheels: All-Season Tires: 195/65R15 H - 205/55R16 H - 205/50R17 V
    Compact Spare Tire
    Interior Measurements:
    Headroom w/out Sunroof (in., front/rear): 39.1/37.4 - 39.1/38.4 (5-door)
    Headroom with Sunroof (in., front/rear): 38.1/37.0 - 38.2/38.3 (5-door)
    Legroom (in., front/rear): 41.1/36.3
    Shoulder Room (in., front/rear): 54.9/54.0
    Hiproom (in., front/rear): 53.8/52.5
    Cargo Volume (cu. ft.): 11.5/ 17.1 (5-door)
    Passenger Volume (cu. ft.): 94.3/95.3 (5-door)
    Seating Capacity: 5
    Exterior Measurements:
    Wheelbase (in.): 103.9
    Length (in.): 177.4/177.4/176.8 (5-door)
    Height (in.): 57.7
    Width (in.): 69.1
    Track (in., front/rear): 60.2/59.6
    Curb Weight (lbs. MT/AT): 2780/2811 (4-door) - 2,906/2,930 (2.3L 4-door) - 2,959/2,983 (5-door)
    Weight Distribution (%, front/rear, MT): 60/40
    Weight Distribution (%, front/rear, AT): 60/40
    5-Speed Manual (City/Highway): 24/32* – 22/29*
    5-Speed Automatic (City/Highway): 23/31* – 22/29*
    Crankcase (Qt.): 4.5 US w/ oil filter replacement
    Coolant System (Gal. MT/AT): 1.9 US.
    Fuel (gal.): 14.5
    * 08 EPA FE specs.
