Month of February 2021 (Nat’l Avg $2.422)
Discussion in 'The Daily Grind' started by EdwinTheMagnificent, Feb 1, 2021.
  1. EdwinTheMagnificent
    Today , still in the Civic. 37 deg F in Elk Grove ,
    snow is ( slowly ) melting. 16.3 miles , no highway ,
    fcd = 43.9 MPG. Car actually glides now that it is above freezing.
    BillLin and Gord like this.
  2. Gord
    Last night, motorway route with a small detour to avoid a queue, 47°F:
    45.7 / 22.0
    To work this morning, motorway route, another good run, 48°F:
    50.4 / 21.5
    Tank up 0.4 at 45.2 (FCD 47.6) / 258.5 / Range 395 . Fuel gauge F__««|««««E . UG up 0.4 at 47.9 / DTE 389
    Lost pip 2 (of 8) at 220 miles
  3. RedylC94
    When it was below freezing, I recall gliding without the wheels rotating, usually unintentionally.
    EdwinTheMagnificent, BillLin and Gord like this.
  4. EdwinTheMagnificent
    That has happened to me.
    Today , in the Prius. Despite a fair amount of snow melting yesterday , I
    got stuck in the driveway. I had plenty of momentum , but I missed the snowbank
    by a good three tire widths (12") , and had to do a little digging. I'm not firing on
    all cylinders at 4:00 AM. Also , it's difficult to see out of the Prius when backing up.
    38 deg F in Elk Grove , and a nice tailwind all the way ! 35.1 miles ,
    fcd = 61.6 x .943 = 58.1 MPG. Not summer or even spring numbers , but
    better than a poke in the eye with a sharp stick. Taking the scenic route home ,
    so I expect 65-67 fcd.
    RedylC94, Gord and BillLin like this.
  5. Gord
    Tuesday night, motorway route, milder 57°F:
    47.1 / 21.8
    To work Wednesday morning, motorway route, even better run, mild 55°F:
    50.7 / 21.7
    Tank up 0.4 at 45.6 (FCD 48.0) / 302.0 / Range 345 . Guess gauge F___«|««««E . UG up 0.6 at 48.5 / DTE 354
    Lost pip 3 (of 8) at 281 miles
  6. EdwinTheMagnificent
    Today in the Prius again , tomorrow also.
    22 deg F in Naperville and Elk Grove.
    35.1 miles , fcd = 59.5 x .943 = 56.1 MPG.
  7. Gord
    Last night, motorway route, 59°F:
    49.5 / 21.4 - pretty good for a home run, a slow driver behind me (40 in a 50psl) meant I could do loads of long glides on the final section before home.
    To work this morning, motorway route, 43°F:
    48.7 / 21.7
    Tank up 0.3 at 45.9 (FCD 48.4) / 345.1 / Range 290 . Guess gauge F___«|««««E . UG up 0.3 at 45.9 / DTE 317
  8. EdwinTheMagnificent
    Today , 23 deg F in Naperville , 22 in Elk Grove.
    35.1 miles , fcd = 61.5 x .943 = 58.0 MPG.
    97 miles remaining on this tank. Probably enough to
    go to work Tuesday then drop the car at my mechanic afterwards.
