Week of July 16 to July 22 (Nat’l Avg $2.877)
Discussion in 'The Daily Grind' started by Gord, Jul 16, 2018.
  1. Gord
    Welcome back to the grind :D
    The national average gas price has crept up 1.2¢ since last week to $2.877 - this time last year it was only $2.252 so it's 27.8% (+62.5¢) dearer.
    Diesel is unchanged at $3.169. It's 29.7% (+72.6¢) more expensive than this time last year. Diesel is at a 10.1% premium to regular.
    E85 is up 1.8¢ to $2.432 - a year ago it was still below $2 at $1.961 so 24% dearer.
    _____________________
    No commute for me until Thursday - car pooler out on business
    My car now has 22201.1 miles on the clock after 3 years and 4 days of ownership!
  2. EdwinTheMagnificent
    Thanks , Gord. Today , 75 deg F , no wind. This is the warmest morning so far this year.
    15.4 miles , fcd = 92.5 x .93 = 86.02 MPG. Tanks is at 409.1 miles , 75.89 MPG.
    I have to go to the courthouse in Cook County this Thursday , never a great day for MPG. Ugh.
    I wish I only had to drive as many miles as you , Gord !
    Gord and BillLin like this.
  3. PaleMelanesian
    63 / 5.4 - work this morning
    Tank is at 51.0 / 139 mi. Was 54.7 before the weekend. Still above F.
    Gord, EdwinTheMagnificent and BillLin like this.
  4. PaleMelanesian
    Feed store at lunch. Hot. Windows down.
    59.7 / 5.0
    add 200 lb
    50.7 / 5.0
    Tank is up a bit to 51.3 / 149 mi, still above F.
    EdwinTheMagnificent, Gord and BillLin like this.
  5. Gord
  6. Die2self
    Had to hit the store on Friday Night and my wife had headed to Northwest Arkansas (NWA) to pick up the kids from camp on Saturday morning. So I got the misfit out.
    61.5 / 4.4 miles (90F heat index of 101F - and Winds from the South at 5) This is at 7 PM.
    48.8 / 1.5 miles (from store to Gas station to fill up gas can for Mower)
    44.8 / 3.0 miles (back home - 89F/100F S@4)
    tank:
    1.15 gals converted
    52.1 miles
    ~45.1 MPG
  7. Carcus
    Carcus Well-Known Member
    I thought it was only 1 mpg per hundred pounds?
    BillLin and Gord like this.
  8. EdwinTheMagnificent
    Nice ride , Gord ! If I had THAT , I could probably average xx.x MPH. :)
    Today , 70 deg F , wind SE 3-6. 15.4 miles , 82.68 MPG.
    Tank is at 441.5 miles , 76.07 MPG. Tonight , Wednesday and Thursday will
    be challenging for me. I have to drive at inconvenient times to improbable
    places after work. I might "only" get around 70 MPG actual. I will do my best to
    keep this tank up. Right now it's close to my PR tank MPG , but there's a long way to go.
  9. BillLin
    Different directions may affect outcome.
    EdwinTheMagnificent and Gord like this.
  10. PaleMelanesian
    Wind, uphill/downhill, traffic, my own inconsistency, etc. It's so hard to pin anything down with so many variables. I just looked it up, 6 mph tailwind then headwind.
    51.6 / 5.2 - home last night
    66.7 / 5.1 - this morning
    Tank is at 51.6 / 160 miles and right on F.
  11. RedylC94
    That would make no logical sense. It's more likely to be a roughly constant number of gallons per mile per hundred pounds than a constant number of miles per gallon.
  12. Carcus
    What I posted — probably not too logical.
    The ol’ rule of thumb is 1% to 2% mpg loss for every 100 pounds of added cargo.
    / somebody should write an mpg app, so you can plug in your car’s epa city / highway and all the variables for a given trip
    // Toyota should write it— prolly sell a few more Prius
  13. EdwinTheMagnificent
    Yesterday's trip home hurt. 39.0 miles, two stops ( dinner,movie ) ,
    unfamiliar roads, highway most of the way home. 68.35 MPG.
    This morning , better: 61 deg F , no wind , 15.4 miles , 80.26 MPG.
    Tank is down a bit : 496.1 miles , 75.52 MPG.
  14. RedylC94
    So if you load 10,000 to 5000 pounds on a heavy truck that gets 10 mpg empty, its mpg would drop to zero?
  15. BillLin
    You're lucky your passenger tolerates your efficient driving. :D
    Sounds like Carcus has a rule-of-thumb that may well work in some limited situations and with limited vehicles upon which the rule was derived.
    Hey, if you stuck 10 tons on (might not all fit *in*) any of my past ICE vehicles, I'd probably get zero MPG as well. :D
    Gord likes this.
  16. PaleMelanesian
    53.6 / 5.2 - home last night, car was 96F in the shade since lunch.
    69.9 / 5.1 - this morning. Sooo close!
    Tank is up to 52.1 / 170 mi and right on F.
  17. EdwinTheMagnificent
    Well , I met her there , so all my driving was solo. But this girl HAS been a passenger before and knows what to expect.
  18. NeilBlanchard
    This would depend on the car, and where you put the weight - if you add all the weight in the very back, and the rear of the car is lowered, then there will be a lot of change to the aero drag. Also, the proportion of added weight to the total weight of the car - a lighter car would be more affected by a given added weight, vs a heavier car.
  19. Gord
    Car pooler on a business trip so on my own, 61°F, crosswind N4, net uphill to BP garage (got £5/$6.60 off thru AMEX offer :D):
    45.7 / 5.2
    Tank Stats
    Miles on tank: 603.9 miles
    GallsUS: 12.2
    Calc. MPG : 49.49 MPG
    Calc. Range: 68.3 miles (allowing for extra in tank)
    FCD Range: 40
    FCD MPG : 51.8 MPG (4.65% over-report)
    UG MPG : 48.43 MPG (2.14% under-report)
    No. of trips: 30
    Average trip length: 20.1
    Average speed 28mph
    Driving time on tank: 21hrs 34mins
    Days since last fill: 26
    Commuting: 76.3%
    Ave. Temperature: 68.9°F - Hottest ever!
    Ave. no. of people in car: 2.39
    Pmpg for the tank: 118.1
    60.7 (FCD 64.0 :)) / 16.7 - dream run :cool:, worked hard on this leg even with a detour to miss out queue at start of traffic light section.
    New tank at 60.7 / 16.7 / Range 610 . Guess gauge F««««|««««E . UG at 60.4 / DTE 800 :rolleyes:
    PaleMelanesian and BillLin like this.
  20. EdwinTheMagnificent
    Today , 65 deg F , wind W 0-3. 15.4 miles , 79.98 MPG.
    Tank is at 528.5 miles , 75.61 MPG.
