Sun to Electricity vs Sun to H2 - NREL World Record Now at 16.2% for Solar H2 Production
Discussion in 'In the News' started by xcel, Apr 13, 2017.
    [​IMG] One way or the other, the sun is the answer but …
    [​IMG]Wayne Gerdes – CleanMPG – April 13, 2017
    The world may be upside down today but H2 and its production process' is one possible answer to a clean transportation future.
    Scientists at the U.S. Department of Energy's (DOE) National Renewable Energy Laboratory (NREL) recaptured the record for highest efficiency in solar hydrogen production via a photoelectrochemical (PEC) water-splitting process.
    The new solar-to-hydrogen (STH) efficiency record now stands at 16.2 percent, topping a reported 14 percent efficiency in 2015 by an international team made up of researchers from Helmholtz-Zentrum Berlin, TU Ilmenau, Fraunhofer ISE and the California Institute of Technology. A paper in Nature Energy titled Direct Solar-to-hydrogen Conversion via Inverted Metamorphic Multijunction Semiconductor Architectures outlines how NREL's new record was achieved. The authors are James Young, Myles Steiner, Ryan France, John Turner, and Todd Deutsch, all from NREL, and Henning Döscher of Philipps-Universität Marburg in Germany. Döscher has an affiliation with NREL.
    Direct solar-to-hydrogen conversion via inverted metamorphic multi-junction semiconductor architectures
    The record-setting PEC cell represents a significant change from the concept device Turner developed at NREL in the 1990s.
    Both the old and new PEC processes employ stacks of light-absorbing tandem semiconductors that are immersed in an acid/water solution (electrolyte) where the water-splitting reaction occurs to form hydrogen and oxygen gases. But unlike the original device made of gallium indium phosphide (GaInP2) grown on top of gallium arsenide (GaAs), the new PEC cell is grown upside-down, from top to bottom, resulting in a so-called inverted metamorphic multijunction (IMM) device.
    This IMM advancement allowed the NREL researchers to substitute indium gallium arsenide (InGaAs) for the conventional GaAs layers, improving the device efficiency considerably. A second key distinguishing feature of the new advancement was depositing a very thin aluminum indium phosphide (AlInP) "window layer" on top of the device, followed by a second thin layer of GaInP2. These extra layers served both to eliminate defects at the surface that otherwise reduce efficiency and to partially protect the critical underlying layers from the corrosive electrolyte solution that degrades the semiconductor material and limits the lifespan of the PEC cell.
    Turner's initial breakthrough created an interesting new way to efficiently split water using sunlight as the only energy input to make renewable hydrogen. Other methods that use sunlight entail additional loss-generating steps. For example: Electricity generated by commercial solar cells can be sent through power conversion systems to an electrolyzer to decompose water into hydrogen and oxygen at an approximate STH efficiency of 12 percent. Turner's direct method set a long-unmatched STH efficiency record of 12.4 percent, which has been surpassed by NREL's new PEC cell.
    Before the PEC technology can be commercially viable, the cost of hydrogen production needs to come down to meet DOE's target of less than $2/kg of H2. Continued improvements in cell efficiency and lifetime are needed to meet this target. Further enhanced efficiency would increase the hydrogen production rate per unit area, which decreases hydrogen cost by reducing balance-of-system expenditures. In conjunction with efficiency improvements, durability of the current cell configuration needs to be significantly extended beyond its several hours of operational life to dramatically bring down costs. NREL researchers are actively pursuing methods of increasing the lifespan of the PEC device in addition to further efficiency gains.
    While an alternative configuration where the device isn't submerged in acidic electrolyte and instead is wired to an external electrolyzer would solve the durability challenge, a techno-economic analysis commissioned by DOE has shown that submerged devices have the potential to produce hydrogen at a lower cost.
    The latest research was funded by the Energy Department's Fuel Cell Technologies Office in the Office of Energy Efficiency and Renewable Energy.
    The solar capture area necessary to produce 1 metric ton of H2 per day with this process is approximately equivalent to 5 football fields at an efficiency ratio of ηSTH = 15%. A 25% solar capacity factor, reasonable for a 2-D tracking system in the Southwest U.S., and 98% plant operating capacity factor are assumed. At hydrogen production rates of 1.702 x 10-6 kg/m2 for a ηSTH = 15% device, 20400 m2 of capture area, the area of about five regulation size National Football League fields (each 110 m x 49 m) are required for 1 metric ton of H2/day.
    1 metric ton of H2 (1,000 kg) allows 200 H2 FCVs with 5 kg tanks to be filled per day.
    The wrench in the works - Solar to Electricity
    A caveat to this is that 5 football fields of straight 20 percent efficient solar panels would produce.
    A quick consumer case study reveals SunPower’s Consumer Home panels are 22.5 percent efficient w/ an overall avg. of 20.6 percent and an expected life of 40-year today. The brands latest lab cells have been verified by the NREL to output over 24 percent efficient today.
    On an industrial scale, consider U.C. Davis’ recent 16 MW SunPower system located on a 62 acre site produces approximately 33 million kWh/year or 90,400 kWh/day. Breaking this down to kWh/ft2 in order to compare against the Solar to H2’s lb efficiency calculations 5-football fields to refuel 200 cars per day looks like this.
    2017 Toyota Mirai – 312 miles range from onboard 5-kg storage tanks
    2017 Tesla Model S 100D – 335 miles range from 100 kWh of onboard battery storage
    PV to H2
    According to the NREL report, 5-football fields of Solar to H2 Cell area is necessary to fill 200 (three hundred and twelve miles range) Mirai's. A football field of 360.8 ft x 160.7 ft size) * 5 or 290,000 sq. ft. is required for 1,000 kg H2 to fill 200 Toyota Mirai’s/day. The power necessary to compress, transport, and store is not included. Along with the H2 costs, the solar area needed for refueling just 200 cars is extraordinary. 3- to 5-minute fills are perfectly aligned with today's consumer expectations however.
    2016 Toyota Mirai
    A future solution but very expensive fuel and car.​
    PV to Electricity
    A 62 acre U.C. Davis/SunPower site that is now operational equates to 2.7 million sq. ft. and produces 90,400 kWh/day. This is enough energy to charge just over 900 Tesla Model S P100s/day with 100 kWh’s from flat to full each day. The problem being how to store that electrical power – more batteries for on-site storage at approximately $150/kWh – and the time it takes the consumer waiting for a complete full charge of 1 + hour.
    2017 Tesla Model S P100D
    The P100D is certainly more attractive and much quicker than a Mirai/Clarity, but at almost twice the take home price depending on lease vs purchase, Fed and State incentives, this leaves most consumers out of the electric space.
    Early Conclusions
    Although still a ways off from the future target goal of $2.00/kg production or all in $3.00/kg incl. production, transportation, compression, and storage vs $15/kg at the H2 station today, this is one of the means by which we could eventually arrive at the H2 society. Sometime well into the future that is.
    The real battle for our personal future transportation dollars will be the 3 to 5 minute refueling for expensive $75 of H2 at today’s $15/kg rates for 300-miles range FCV range or 1-hour plus 100 kW Level3 fast charging for 100 kWh at $12 at $0.12/kWh (nationwide avg.) electricity cost for a similar 300 plus miles BEV range. I am not including Southern Calif. and the ridiculous $0.40/kWh rates after the basic 384 kWh threshold has been exceeded. 100 kW Level3 chargers are not in anyone's homes yet let alone few are on the road sans Tesla Super Chargers and all cost more than just a $0.12/kWh basic rate when including the charger costs.
    NeilBlanchard, ALS and BillLin like this.
  2. NeilBlanchard
    The lower cost of the Chevy Bolt EV puts the EV side of this comparison even more positive.
    The miles per solar panel for EV's vs FCEV ratio is excellent: 301,500 / 62,400 = 4.83 : 1
    That's (335 x 900) / (312 x 200) = 4.83
    EV's can drive almost FIVE times farther on the same energy vs FCEV's.
    BillLin and xcel like this.
    Hi Neil:
    FCVs can be filled in 3 to 5 minutes. They have a huge problem with upfront and refueling costs, H2 refueling infrastructure, longevity, and TCO due to depreciation.
    EVs have a problem with upfront and charging costs, charging time, range, longevity, and TCO due to depreciation.
  4. BillLin
    Cost is no object for some people, but time is important to everyone. Perhaps H2 will be the fuel for the rich.
    Trollbait and xcel like this.
  5. Trollbait
    Trollbait Well-Known Member
    Part of the depreciation is due to the generous incentives pulling the price for new down. Another factor is the quick improvement rates seen in cost and range. Then there is the uncertianity on the batteries condition with age. There is already small businesses cropping up that refurbish/repair hybrid battery packs though, the incentives will end, and the improvement rate will level off. So high depreciation is should work itself out in time, and come to a rate approaching current ICE cars.
    FCEVs have all those factors to some degree, plus the fuel cell stack and fuel tanks. Fuel cells had short lives in early concepts. That might be solved, but still requires time for consumer confidence to build. High pressure fuel tanks have limited service life, and require annual inspects, under DoT regulations. Going by a photo of the fuel flap, the Mirai tank has a life of maybe 15 years since manufacture. 25 year CNG tanks are available, but hydrogen is a more aggressive gas, and the pressure is 3 to 4 times what CNG is stored at.
    Making hydrogen isn't the hurdle in the US, it is the big cost for the infrastructure. It might have a chance when fuel cells replace the ICE for the range extender on a plug in. Get a majority of miles driven on the grid electric, and we won't need as many hydrogen stations. The hiccup is that you have a large battery and heavy, bulky hydrogen tanks viaing for precious space on a car frame.
    I think fuel cell cars will come to pass, but only once they switch to some type of liquid fuel.
    PEC making of hydrogen has its own future. Panasonic is developing a two cell system in which one cell splits the water, and the second combines the hydrogen with atmospheric CO2 to form small organic compounds that have commercial uses. Formic acid is what they are focusing on first.
  6. xcel
    HI Trollbait:
    The FCV and BEV incentives are there because of the sky high price of the car(s) and how they lack compared to non-electrified drivetrain counterparts. Without, they will not move into the consumers drives.
    The FCVs longevity is now out over 100k miles but not quite where they need to be. Just like the BEV.
    BEVs have the same problem.
    Interesting to hear about the Panasonic initiatives.
  7. Trollbait
    The incentives are needed, but they won't be there forever. Once gone, their influence on depreciation will start to fade. The gen2 Volt got a large price cut while improving its all around package and performance. Hopefully, we will continue to see such price drops when the incentive ends.
    The problem in packaging BEV batteries arises when simply doing a conversion of an ICE platform, and be avoided when designing for them.. The skateboard format involves little loss of cabin space while moving the car's center of gravity to a better spot for performance and ride. Battery packaging is more difficult in a PHEV since you have the ICE with all its support systems. Hydrogen tanks have less flexibility than batteries when it comes to packaging.
    The 3 to 5 minute refueling time is a plus for hydrogen, but the standard under which that is possible can allow fill times as high as 15 to 20 minutes. Handling pressurized gases will never be as easy as with liquids. Selling it as it is will lead to disappointed customers the first time they refuel at a station low on pressure.
