2017 Civic Sedan 1.5t 6mt steady states
Discussion in 'Honda' started by Carcus, Dec 12, 2016.
  1. Carcus
    Carcus Well-Known Member
    It's too bad Honda only ran this car (EX-T 6mt) for two years (2017, 2018 in very limited production). I think the only way to get the manual plus turbo is in an Si starting in 2019 (approx 10% hit in epa fuel economy).
  2. EdwinTheMagnificent
    What's wrong with the base 2.0 engine on a 10th gen Civic ?
    I'm interested in buying one. I found a nice CPO 2017 LX 6MT.
  3. seftonm
    Nothing wrong with it. A little less efficient than the 1.5T, but it's a simpler engine and might be more reliable in the long term because of that. Port injection instead of direct injection, and no turbo.
  4. EdwinTheMagnificent
    Thanks , Mike. I also drove a 9th gen Civic with 5MT and I loved it , but they wanted too much $$$.
    I like the turbo engine , but I'm moving towards lower technology. Port injection is great , no turbocharger is
    also great. I'm going for a test drive today in a few hours.
    litesong likes this.
  5. litesong
    litesong litesong
    Always had non-turbo-charged cars. Had a nice 450 six speed 1980 Suzuki motorcycle, which I took on Highway 395, north of Burns, Oregon, up to Pendleton, Oregon. Got very wiggly & slow going, but I loved the country & its far distant vistas. The cycle shifting was easy & sweet, but I knew I never wanted to do the journey with a manual shift car. Now days with the turbos that are designed for economy, I think I would have enjoyed a turbo-charged manual shifter on wiggly 395 to gain extra pull on corners with gears giving lower rpms to reduce shifting. During the time I had a CVT Dodge Caliber, I always hoped I could get back to wiggly Highway 395 again, because of the CVT smoothness. It never happened.
    But, yeah. A turbo manual shifter on wiggly 395 would be nice to reduce un-ending shifting. Guess you could use a 400HP manual shifter to reduce shifting. But..... ugh to 10 or 15MPG (lower?).
  6. EdwinTheMagnificent
    I drove the car , and it was great ! But I felt that the salesman was lying or hiding some things , so
    I ended negotiations and walked out. I'm still looking for a car , but not in any hurry.
  7. EdwinTheMagnificent
    I found a 2014 ( 9th gen ) Civic 5MT with 80K miles.
    The EPA numbers are 28 city and 36 highway.
    The gearing is definitely lower than the 10th gen car (28/40)
    but I'm old school and think that five forward gears are enough.
    There will not be a lot of miles on the highway anyway. If I get
    50 MPG highway ( and I will ) I won't be too unhappy.
    I will test-drive it soon.
  8. litesong
    litesong litesong
    Very much agree with your last statement. I even skip gears with our 5 speed Accent. As I have done on our Hyundai Accent & our Elantra, try to increase the drive wheel tires’ diameter by as much as 8%. Your rpms will reduce, give the car higher MPG, absorb bumps better, & give better smoothness. Also, if you choose a wider tread, as well as larger tire aspect, car handling & cornering will improve.On our Accent, 205mm tires replaced standard 175mm tires. Car track width increased by over an inch. Braking, road bends, & corners are sweet, now.
  9. EdwinTheMagnificent
    litesong , does the larger diameter tire give you an
    odometer/speedometer error ?
  10. litesong
    litesong litesong
    Sure. Just remember 56MPH is 60MPH. Simple as pi is more than 3.14159.
