Red Triangle
Discussion in 'Toyota Prius Family' started by Suzan OBrien, Jul 31, 2016.
Tags:
  1. Suzan OBrien
    Suzan OBrien New Member
    The red Triangle does not show at start up, which I have read that it should. It does show briefly when I stop in the Brake position of the transmission. I have been using that at stops and lights to save my brakes. 120,000 miles on the od. and still have about 30,000 worth of pads left. Wondering if I haven't shot myself in the foot following advice that this 'wont hurt it'.
    2006 Prius
    Suzan
  2. brick
    brick Answers to "that guy."
    There's no need to use engine braking (the "B" mode of the transmission) in normal driving. It provides no benefit unless you're descending a very long, steep grade. As for the warning light, the only thing you can do is have it scanned for codes.
    RedylC94 likes this.
  3. ksstathead
    ksstathead Moderator
    All B mode is doing is taking some of the regen energy and spinning the engine with it instead of putting it back in the batteries.
    Better off in D on a Prius.
  4. S Keith
    S Keith Well-Known Member
    Check your oil.
  5. Mendel Leisk
    "B" mode on the shifter is for use on extremely long downgrades, where there's a possibility of the hybrid battery getting so full that the car won't charge it further, and there is STILL a lot more downhill to go. In short: coming down ski hills. In normal around-town driving, there is no reason to use B, it reduces charging, mpg, causes the car to rev high, and so on.
    But, it's not clear that your use of B mode is behind the red triangle appearing. I would first check the engine oil level, top up if necessary, then get the car to a Toyota dealership, have them look it over, check for stored codes.
  6. BillLin
    I'm reading quite literally, so the red triangle is only appearing momentarily, and you're questioning the LACK of the red triangle in the power on self test, right?
    All the B-mode discussion is interesting and useful, but probably not of significance to the above question.
  7. S Keith
    Did you check your oil? I'm not kidding.
