July 4th - Planes to Remember...
Discussion in 'Off-Topic' started by xcel, Jul 3, 2016.
  1. PaleMelanesian
    5757 - That's my favorite P-38, Glacier Girl!
    S Keith, BillLin and xcel like this.
    Hi Andrew:
    Have you seen that one in person? Looks like a great restore!
    And how about an origami based F/A-18 Hornet?
    Mendel Leisk, S Keith and BillLin like this.
  3. PaleMelanesian
    I haven't seen her, sadly. I've been following the story since early on, still buried in the ice in Greenland.
    The Republic A-10 "Warthog".
    PaleMelanesian, S Keith and BillLin like this.
  5. S Keith
    S Keith Well-Known Member
    One of the BEST aircraft ever made. Aircraft designed around the GAU-8 30mm Gatlin gun. I get a little misty eyed anytime I see a picture or hear it's designation spoken...
    xcel and BillLin like this.
  6. S Keith
    It's massive firepower was also considered ungentlemanly. The goal (at least of those doing the fighting) was to shoot down planes not kill pilots - part of the camaraderie of all who fly. Unfortunately, the "Jug's" 8X .50 caliber machine guns could vaporize a target if hit at the convergence point.
    Lastly, due to the combination of its powerful engine and its weight, it could achieve extremely high dive speed. Some early models were lost due to flutter induced at high dive speeds.
  7. xcel
    Hi S. Keith:
    Thanks for the P-47 Thunderbolt's detail!
  8. xcel
    Something you probably did not want to see in the sky over the Pacific if you were in a Zero...
    PaleMelanesian and BillLin like this.
  9. some_other_dave
    The air intakes look wrong somehow. That may be a later development?
    Ah, nope. Wikipedia says that the "chin intake" I am used to seeing started with the P38J, and the above is an earlier one.
  10. PaleMelanesian
    Same plane as above - Glacier Girl. Sadly, you can count all the operational P38's on your fingers.
  11. xcel
    The first U.S. plane - the F-86 Sabre - to take on and beat the MIG-15.
  12. xcel
    Anyone remember the F-104 Starfighter? It could not turn worth a damn but it was fast - mach2 + fast - as hell!
  13. xcel
    Another one of those beautiful WW-II Vought F4U Corsairs in flight.
  14. xcel
    Another cool shot of the Vought F4U Corsair.
  15. xcel
    Not the Blackbird but still flying 61 years after its first flight on Aug. 1st, 1955. The Lockheed U-2.
  16. Mendel Leisk
    Plane Resurrection (on Netflix for one) is a good watch.
  17. some_other_dave
    There were a couple of those (U2s, though technically they were ER2s then) that used to fly out of Moffett when I worked there the first time. It was amazing watching them take off--they'd get about halfway down the LONG runway and then tilt back to about 45 degrees and UP they would go! You could see the little orange dot of the jet exhaust after the rest of the plane was no longer visible, and the sound was very present for a long while after that.
    Evidently they had to do a lot of coordination with the local ATC (SF Bay Area is a very busy airspace!!) and had about a three-minute window. All traffic was cleared out above them, and if they didn't make the window they had to scrub and re-schedule. They would basically just go straight up and through the "layer cake" to altitudes where passenger aircraft don't fly.
    A guy I knew who used to fly them said it was pretty intense. At the altitudes they flew, the speed of sound (decreases with altitude) was just barely faster than the stall speed of the aircraft (which doesn't change as much with altitude). So they had about a 5 MPH window to keep the airspeed in, for hours and hours and hours.
    -soD
  18. xcel
    Hi Dave:
    Excellent detail on the U2! The pilots had a word for that small window between ripping the wings off and stall but I forgot what it was called?
    The next one shows a Spitfire and an F-22 Raptor.
    I have never seen this one before.
    Mendel Leisk and BillLin like this.
  19. xcel
    A Raptor shot taken from an angle I have not seen before!
  20. BillLin
    But is it real or cgi? Hard to tell sometimes. :)
    Edit: Doesn't it look like someone's been doing vertical flights out of the clouds ahead?
