Factory Grill Block
Discussion in 'Subaru' started by dobsont, May 15, 2015.
  1. dobsont
    dobsont "How's your mileage?"
    The 2015 outback has a factory grill block. It opens and closes based on sensor data. I don't know much about it yet.
    But how about that!?
  2. EdwinTheMagnificent
    I wonder how well it works with crusty , frozen snow.
  3. ILAveo
    ILAveo Well-Known Member
    That'll block your grill too.
  4. NeilBlanchard
    If it gets hot enough to need the grill open, it will probably melt the snow and ice?
    By the way, the e-Golf has an active thermally controlled shutter in the lower grill, and the upper grill is blocked off.
  5. RedylC94
    Grill shutters are common nowadays on such luxurious cars as the Nissan Versa Note.
  6. Mendel Leisk
    Had a look with Google images: I like that someone's still designing grill that are semi-sensible.
    I've seen pictures of the revamped Prius v grill. It's cheering me right up, knowing what Toyota's going to foist on the next gen Prius: the bucktoothed catfish look. ;(
  7. brick
    brick Answers to "that guy."
    Manufacturers are really starting to take thermal management seriously. Mine dosn't have any fancy shutters, but it does have an electric water pump that doesn't even activate until the engine starts to warm up. It's pretty cool. The difference between winter and summer FE is a lot smaller than I'm used to.
