Tighten your battery cables!
Discussion in 'Ford Hybrids' started by 08EscapeHybrid, Oct 7, 2014.
  1. 08EscapeHybrid
    08EscapeHybrid Moderator
    Had a scare the past couple days... The other day I started the FEH, and it was idling really rough, but it evened out after a minute, and all was well. Today I got the "Check Brake System" and "Regenerative Brakes Disabled" messages several times. Then, I tried to reboot the computer by restarting at a traffic light. FEH would not restart and the damn Theft light was flashing when the light turned green.
    I was certain all this pointed to a failing 12v battery. I stopped by the parts store I bought the battery from (The 3 year free replacement period will be up in a couple months). They load tested it, and said it tested fine. :( I was beginning to think I had serious problems. I drove home, and decided to watch the volt reading on my scangauge... Definitely low voltage. It would jump anywhere between 12.2 and 13.6.
    When I arrived home, I pulled out my trusty voltage meter, and went to get some readings to see if I can figure out what's going on. I go to wedge the probes in the battery terminal clamps... and I notice the Negative terminal is very loose. I grab a socket set, tighten it up, then let the FEH idle in the driveway for 30 mins to make sure the battery has a full charge, and I haven't had any repeat problems.
    We've just started having cold nights, and I think with the temperature fluctuations, the terminal worked loose. I recommend everyone go out there and double check their battery terminals this time of year to avoid the panic I had today.
  2. Mendel Leisk
    Maybe wasn't tightened properly, back when it was installed? Good tip.
  3. EdwinTheMagnificent
    I swapped the battery from my car to my daughter's car to get it to my mechanic so he could replace her alternator. That's when I noticed my battery cable clamps were a bit loose and damaged from over-tightening. I wasn't really happy about that , because the only person who has touched the battery was my mechanic, a guy I thought was competent.
    When I get my snows put on , I think I will have new clamps installed at that time.
  4. 08EscapeHybrid
    Not a chance. I replaced it myself. I think after nearly 3 years, and the temperature fluctuations we've had recently had loosened it up.
