2014 Kia Optima Hybrid Pricing, Options and Specifications
Discussion in 'New Automobile Specifications' started by xcel, Sep 7, 2014.
    2014 Kia Optima Hybrid Manufacturer’s Suggested Retail Pricing
    Column1Column2Column3Column4Column5
    ModelEngineTransmissionMSRPChange from
    Optima Hybrid LX2.4L Hybrid I4Six-Speed A/T$26,500-$555
    Optima Hybrid EX2.4L Hybrid I4Six-Speed A/T$31,500- $495
    Current Delivery and Handling: $800, up $50 from the 2011 MY
    2014 Kia Optima Hybrid Standard and Optional Equipment
    ExteriorEquipmentLXEX
    Dual body-color remote mirrorsS--
    16" tires with alloy wheelsS--
    17" tires with alloy wheels--S
    Acoustic Laminated Glasses (Front Doors)OS
    Chrome/body-color door handlesSS
    Solar glassSS
    Projection headlampsSS
    HID headlamps--S
    LED tail lampsSS
    LED front positioning lightsOS
    LED fog lights--S
    Outside mirrors with turn signal indicatorSS
    Power folding outside mirrorsSS
    Heated rear glass with timerSS
    Panoramic sunroof--O
    Virtual engine sound systemSS
    Headlamp anti-fog functionSS
    InteriorEquipmentLXEX
    USB/auxiliary input jacksSS
    BluetoothSS
    Wheel-mounted audio/Bluetooth/CC buttonsSS
    Tilt and telescopic wheelSS
    AM/FM/CD/MP3/SiriusXMSS
    Infinity surround-sound audio with 8 speakers--S
    Voice-command NAVI with SiriusXM Traffic and rear-camera display (n/a with UVO)--S
    UVO system, Infinity w/ external amp and sub, HD, rear-camera displayOS
    Rear view cameraOS
    Push-button start with Smart keySS
    PWs with driver's/passenger's one-touch auto up and downSS
    PDLs with remote keyless entrySS
    Dual-zone auto climate with ion air filtrationSS
    Rear A/CSS
    Heated steering wheel--S
    Illuminated glove boxSS
    Cooling glove boxSS
    Chrome accent front cup holdersS--
    Illuminated chrome accent front cup holders--S
    Mood lamp--S
    Sunglasses holderSS
    Auto-dimming rear-view with Homelink and CompassO--
    Carpeted floor matsSS
    BSM w/ RCTA--O
    Rear parking assist system--O
    Electronic parking brake--S
    Trunk Hinge CoverSS
    Cloth seat trim S
    Leather seat trimSS
    Sport seat leather trim (black seats)--S
    8-way power driver's seat with lumbarOS
    4-way power front passenger seat--S
    60/40 split-folding rear seatsSS
    Seat back pocketSS
    Heated front seats--S
    Heated rear seats (hi/low setting)-- S
    Air-cooled front seat--S
    Memory driver's seat and mirror--S
    Leather-wrapped wheel/gearshift knobSS
    White leather seat trim with piping--O
    Convenience Package -- LX Only -- ($1,100)
    • 8-way power adjustable driver’s seat
    • UVO2 eServices with rear camera display
    • LED front positioning lights
    • Laminated front door windows
    Panoramic Sunroof -- EX Only -- ($1,500.00)
    Technology Package -- Requires Panoramic Sunroof -- ($700)
    • Blind Spot Detection with Rear Cross Traffic Alert
    • Back-up Warning System
    White Interior Package -- Requires Panoramic Sunroof and Tech Pkg. -- ($400)
    • White leather seat trim with piping
    • Black high-gloss console upper cover
    • Black high-gloss power window switch panel
    2014 Kia Optima Hybrid Dealer Installed Accessories
    • Rear Bumper Appliqué ($75.00)
    • Cargo Net ($50.00)
    • Cargo Tray ($80.00)
    • Auto-dimming rear-view mirror with Homelink and Compass ($350.00)
    • Mud Guards ($95.00)
    • Wheel Locks ($55.00)
    2014 Kia Optima Hybrid Engineering
    Engine Type: I-4
    Displacement (cc): 2,359
    Engine hp@rpm: 159@5,500
    Engine Torque (lb.-ft.@rpm): 154@4,500
    Bore and Stroke (in): 3.46” x 3.82”
    Compression Ratio: Atkinson Ratio of 13:1
    Valvetrain: DOHC CVVT (Continuously Variable Valve Timing)
    Multi-point fuel injection
    Hybrid Type: Full parallel
    Battery Type: Lithium Polymer
    Battery Capacity (kWh): 1.43
    Battery Output (kW): 47
    Battery Voltage (V): 270
    Battery Weight (lbs.): 91
    Battery Capacity (Ah): 5.3
    EV Operation Limit: 62 mph with higher speeds capable downhill
    Hybrid Motor hp@rpm: 47 hp@1,630 – 3,000 rpm
    Net hp: 199
    Hybrid Motor Torque (lb.-ft.@rpm): 151@0 - 1,630
    Net Torque (lb.-ft.@rpm): 235
    Front-Wheel Drive
    CARB Emissions Rating: SULEV-II
    Federal Emissions: Tier II/Bin3
    Transmission
    Gear Ratios of the 6-Speed Automatic Transmission:
    1st: 4.212
    2nd: 2.637
    3rd: 1.800
    4th: 1.386
    5th: 1.000
    6th: 0.772
    Final Drive: 3.320
    Reverse: 3.385
    RPM @ 60 mph (calculated)
    LX with P205/65R16 Tires: 1,951 rpm
    EX with P215/55R17 Tires: 1,981 rpm
    Body/Suspension/Chassis
    Unit-Body Construction
    Multi-link Rear Suspension
    Stabilizer Bar (front/rear): 24 mm/15 mm
    Electric Power Steering (EPS) steering column mounted, Rack-and-Pinion
    Steering Wheel Turns, Lock-to-Lock: 2.94
    Steering Ratio: 15.3:1
    Turning Diameter, Curb-to-Curb (ft.): 35.8
    Power-Assisted Ventilated Front Disc/Solid Rear Disc Brakes (in.): 11.8/11.2
    Wheels:
    16 x 6.5-in. alloy wheel (LX Hybrid)
    17 x 6.5-in. alloy (EX Hybrid)
    Low Rolling Resistance All-Season Tires:
    With P205/65R16 Tires (LX)
    With 215/55R17 Tires (EX)
    Spare Tire: Inflator Kit std.
    2014 Kia Optima Hybrid Interior Measurements
    Headroom (in., front/rear): 40.0/37.6
    Legroom (in., front/rear): 45.5/34.7
    Shoulder Room (in., front/rear): 57.3/55.7
    Hiproom (in., front/rear): 54.7/54.5
    Cargo Volume (cu. ft.): 10.78
    Passenger Volume (cu. ft.): 102.2
    Seating Capacity: 5
    2014 Kia Optima Hybrid Exterior Measurements
    Wheelbase (in.): 110.0
    Length (in.): 190.7
    Height (in.): 57.1
    Width (in.): 72.0
    Track (in., front/rear)
    LX: 63.0 in./63.0 in.
    EX: 62.8 in./62.8 in.
    Ground Clearance (in.): 5.1
    Curb Weight (LX/EX lbs.): 3,496/3,622
    Weight Distribution (%, front/rear): 59/41
    Cd: 0.26
    2014 Kia Optima Hybrid EPA Mileage Estimates/Capacities
    Hybrid LX (City/Highway/Combined mpgUS): 36/40/38
    Hybrid EX (City/Highway/Combined mpgUS): 35/39/37
    Crankcase (qt.): 5.3
    AT transmission fluid (qt.): 6.98
    Coolant System (qt.)
    Engine: 6.97
    Hybrid Electronics: 2.39
    Fuel (gal.): 17.2
    2014 Kia Optima Hybrid Colors
    Exterior:
    Snow White Pearl
    Aluminum Silver
    Smokey Blue
    Aurora Black
    Interior:
    Beige
    Black
    2014 Kia Optima Hybrid Warranty
    10-year/100,000-mile limited powertrain
    5-year/60,000-mile limited bumper to bumper basic
    5-year/100,000-mile anti-perforation
    5-year/60,000-mile roadside assistance
