Flat Grill Block
Discussion in 'Toyota Prius Family' started by Sabby, Sep 18, 2013.
  1. Sabby
    Sabby Member
    The last two years I have used the foam pipe grill block in the lower section of our Gen III Prius. Has anyone used a flat vinyl or canvas material to form the grill block?
    Do you have any pictures of your installation and attachment method? Thanks
    Almost time for the block to go on!
  2. ksstathead
    ksstathead Moderator
  3. Sabby
    Sabby Member
    I just gave it a try with a bra type of set up that is flat on the face of the car. It goes on quickly with some Velcro and tucking it behind the license plate holder and the lower spoiler. It is a heavy duty black shelf liner material that I got at Lowes.
  4. ksstathead
    Sounds good. Should look better and have a bit better aero than pipe foam.
    Best of luck. Consider a scanguage to watch your temps.
  5. Sabby
    Sabby Member
    I am hoping for a little better aero. I have a Scanguage. I just wanted to get it fitted while it is still warm out. Perhaps it will be put on in mid October.
