2014 Nissan Versa Note Pricing, Options and Specifications
Discussion in 'New Automobile Specifications' started by xcel, Jul 1, 2013.
    2014 Nissan Versa Note Pricing Detail
    Column1Column2Column3
    TrimTransmissionMSRP
    S5MT$13,990 USD
    S PlusCVT$15,240 USD
    SVCVT$15,990 USD
    SV with SL PackageCVT$17,690
    SV with SL Tech PacakgeCVT$18,490
    Destination: $790
    The 2014 Nissan Versa Note arrives with the following standard features:
    • Body-color front and rear bumpers, door handles
    • Large multi-reflector halogen headlights, rear combination lights
    • 109 hp and 107 lb-ft of torque 16-valve 1.6L DOHC I4
    • Dual injector system and Twin CVTC (Continuously Variable Timing Control) on intake and exhaust
    • Standard 5-speed manual transmission (S model)
    • Strut front end with stabilizer bar
    • Torsion beam rear with stabilizer bar
    • Electric power steering
    • Standard 15-inch steel wheels with full wheel covers, P185/65HR15 all-season tires
    • Low rolling resistance tires
    • Standard power-assisted front disc/rear drums with Anti-lock brakes (ABS), Electronic Brake Force Distribution (EBD), Vehicle Dynamic Control (VDC), Traction Control System (TC), Brake Assist (BA) and Tire Pressure Monitoring System (TPMS)
    • Interior volume – 115.5 cubic feet
    • Best-in-class cargo space of 21.4 cubic feet
    • Dual power outside mirrors
    • A/C
    • Cloth seat trim
    • 4-way adjustable front bucket seats
    • Standard front seatback map pockets
    • Standard 60/40-split fold-down rear seat
    • Front door map pockets with bottle holder
    • Dual front and rear cupholders
    • Sun visors with extensions
    • 12-volt power outlet
    • Standard AM/FM/CD/Aux-in audio system with 4 speakers
    • Eight exterior colors: Metallic Peacock, MorningSky Blue, Metallic Blue, Red Brick, Brilliant Silver, Magnetic Gray, Super Black and Aspen White
    • Two interior colors: Charcoal and Wheat Stone
    The S Plus adds in addition to the S the following:
    • 40 MPG highway rating
    • Xtronic CVT (Continuously Variable Transmission)
    • Active grille shutter
    • Cruise control
    The SV adds in addition to the S Plus the following:
    • Bluetooth Hands-free Phone System
    • Integrated Key with remote keyless entry
    • Power windows and door locks
    • Illuminated steering wheel-mounted audio controls
    • Front map light
    • Sun visors with vanity mirrors and extensions
    • 6-way manual driver’s seat with armrest
    • Upgraded cloth seat and door trim
    • Leather-wrapped steering wheel
    • Silver accents on shift knob and shifter surround
    • Chrome inside door handles, chrome-accented parking brake and vents
    • Tricot fabric headliner and glove compartment damper
    The SV with SL package adds in addition to the SV the following:
    • 16" x 6.0" aluminum-alloy wheels
    • P195/55HR16 all-season low rolling resistance tires
    • Nissan Intelligent Key with Push Button Ignition
    • Heated front seats
    • RearView Monitor
    • Fog lights
    • Variable intermittent flat-blade windshield wipers
    • AM/FM/CD audio system with 4.3" color display
    • SiriusXM Satellite Radio and MP3/WMA CD playback capability
    • USB connection port for iPod interface and other compatible devices
    • Rear-seat fold-down center armrest with cup holders
    • Divide-N-Hide Adjustable Floor
    • Tire Pressure Monitoring System (TPMS) with Easy-Fill Tire Alert
    Options
    Sport Value Package ($760) includes 15" alloys and rear spoiler
    Chrome Package ($290) includes chrome exhaust tip and door handles
    Accessories
    Splash Guards ($160)
    Vehicle tracking and recovery ($590)
    Chrome Rear hatch accent ($80)
    Chrome Exterior Door handles ($75)
    Wheel Locks ($44)
    Carpeted Floor mats ($175)
    All season floor mats ($95)
    Advanced Interior Illumination ($455)
    Auto dimming Rear View ($270)
    Rear Cargo Cover ($90)
    Drive-N-Hide Adjustable Floor ($195)
    Interior accent lighting ($200)
    Engineering
    Displacement (cc): 1,598 cc
    Horsepower @ rpm: 109@6000
    Torque (lb.-ft. @ rpm): 107@4,400
    Redline (rpm): 6,500
    Bore and Stroke (mm): 78.0x83.6
    Compression Ratio: 9.8:1
    Valvetrain: DOHC
    Dual Multi-Point Fuel Injection per cylinder
    Drive-by-Wire Throttle System
    Front-Wheel Drive
    CARB Emissions Rating: ULEV-2
    Transmissions
    Gear Ratios
    5-Speed Manual Transmission
    1st: 3.73
    2nd: 2.05
    3rd: 1.39
    4th: 1.03
    5th: 0.82
    Final Drive: 4.07
    Reverse: 3.55
    CVT Transmission (available)
    4.006 to 0.550
    Final Drive: 3.754
    Reverse: 3.770
    RPM@ 60 mph calculated: 2,747 with the 5-speed MT and 1,700 with the CVT
    Body/Suspension/Chassis
    Unit-Body Construction
    McPherson strut front suspension
    Torsion beam rear suspension
    Stabilizer Bar (mm., front/rear): 22.0 mm/20.2 mm
    Electrically Power-Assisted Rack-and-Pinion Steering
    Steering Wheel Turns, Lock-to-Lock: 2.96
    Steering Ratio: 16.8:1
    Turning Diameter, Curb-to-Curb (ft.): 34.8 ft
    Power-Assisted Ventilated Front Disc/Rear Drum Brakes (in.): 10.02/8.0
    Wheels: 15” x 5.5 JJ steel wheel w/ cover, 15” x 5.5 JJ Alloy, 16” x 6.0 JJ Alloy
    Tires: 185/65HR15 Bridgestone or Continental all-season or 185/55HR16 Continental all-season
    Compact Spare Tire: T125/70D15
    Interior Measurements
    Headroom (in., front/rear): 40.8/38.0
    Legroom (in., front/rear): 41.3/38.3
    Shoulder Room (in., front/rear): 51.7/51.9
    Hiproom (in., front/rear): 48.5/48.8
    Cargo Volume (cu. ft.): 21.4 (to the roof)
    Passenger Volume (cu. ft.): 94.1
    Seating Capacity: 5 (in a pinch)
    Exterior Measurements
    Wheelbase (in.): 102.4
    Length (in.): 163.0
    Height (in.): 60.5
    Width (in.): 66.7
    Track (in., front/rear): 58.3/58.5
    Curb Weight (lbs): S 5MT = 2,412, S Plus CVT = 2,460, SV CVT = 2,482
    Weight Dist. (F/R): 60/40
    Cd: S 5MT = 0.308, S Plus CVT and SV = 0.298
    EPA Mileage Estimates/Capacities
    5-Speed Manual (mpgUS City/Highway/Combined): 27/36/30
    CVT (mpgUS City/Highway/Combined): 31/40/35
    Crankcase (qt.): 3.2
    Coolant System (qt. MT/CVT): 6.7/7.2
    Fuel (gal.): 10.8
  2. NeilBlanchard
    Thank you for all the details! Any idea what the difference in Cd comes from - Cd: S 5MT = 0.308, S Plus Cvt and SV = 0.298 ? Are the wheels smoother or have smaller holes?
    Is the floor flat when the rear seats are folded down? What are the differences in dimensions between the Note and the Honda Fit?
  3. RedylC94
    The difference in Cd comes mostly from the active grill shutter, probably.
    The floor is supposed to be flat with rear seats folded if the optional two-position cargo floor at its upper position, I think.
    The excesssive engine revs with the manual is disappointing. Somewhere about mid-way between what it is and the CVT would be reasonable. As usual, that's aimed at keeping people too lazy (or too ignorant) to downshift from complaining they can't pass safely on an uphill.
    Hi Neil and RedylC94:
    Here are two pics of the hatch area with the rear seats folded down with the second holding some beach stuff as we were at a “Make your surfboard yourself” place for the first stop of the short lead drive last week.
    2014 Nissan Versa Note First Drive
    It is not flat but it is not bad either.
    Regarding the Cd, it is the shutter and more under body panel work on the Plus on up IIRC.
  5. EdwinTheMagnificent
    With the Versa Note CVT models , Nissan have managed to out-Fit the Fit. Honda should be paying attention to this car !
  6. EdwinTheMagnificent
    I'm convinced that this is part of a big conspiracy to sell MT's to the foolish while forcing the "wise" to pay more for a less durable (but perhaps more profitable) transmission.
    Nissan is certainly not the only manufacturer guilty of this.
  7. NeilBlanchard
    Thank you for the further information - I didn't realize that it had an active cooling intake. Is there a picture of the underside with the belly pan?
    I think the reason they do such crappy gearing on the manual is (in case?) you get cruise control? I drive a Scion xA which is similarly hobbled - ~3,500RPM at ~65MPH is just terrible. It could be ~2,000-2,200 at 65RPM and be totally fine. On flat ground, I can use 5th gear at 35-38MPH or so.
    Back on topic of the Note: I really hope that Nissan builds a Note EV! I think they need to improve the Cd of the Leaf as well get it down to <0.24 and good things will happen.
  8. xcel
    Hi Neil:
    I did not take a pic of the underside but here is the pictorial from the short lead handout.
  9. EdwinTheMagnificent
    Wayne , is it only certain models that get the Active Grille Shutter and other aero tweaks ?
    For some crazy reason . I am really liking this car. Almost enough to buy a CVT-equipped car.
  10. xcel
    Hi Edwin:
    The S Plus on up with the CVT has the shutters.
    I would not get to hyped up about the 2014 Versa Note as it has some pretty large shortcomings I will post about in a First Drive review possibly tomorrow.
  11. ALS
    Hi Wayne,
    Yep lets begin with the model up charge for Blue Tooth and the USB port as a start.
    They should be both included in the S-Plus package. There is no way I'm paying $3,700 up charge for the USB port let alone $2,000 more for the Blue tooth.
    Al
  12. xcel
    Hi Al:
    My early conclusion will wrap that up along with the extremely poor ergonomics and low rent interior appointments.
  13. NeilBlanchard
    Thanks for the image of the underside - they have a few small teaks, but deflectors are quick fixes. A full smooth belly pan would be far better. And true wheel strakes would be better than deflectors.
  14. tribosessive
    One thing I would like to get picky about is the fold down rear seats. Why doesn't everyone have fold flat rear sears like the Matrix? Also the gearing on the 5MT has got to be just right, I agree big time on that one. Continue to refine the CVT. I guess Suburu is the leader on that one. Durability must be there for me to even consider CVT. Thank you for providing us the details, xcel.
