C-MAX and Fusion Hybrid starting to get bad press
Discussion in 'Ford' started by Paymaster, Nov 20, 2012.
  1. phoebeisis
    Hmm
    I couldn't find the Prius 0-60 times??
    8.6 wow-that is quick for a MPG car/suv -sure explains the less than Prius mpg- no free lunch!!
    Wayne- maybe you looked like some Allah Ackbar terrorist lurking outside a military base
    Lucky they didn't sic a Drone on you (maybe they did?)
    My 2006 Prius seems pretty peppy in city driving- not sure how it would be if I needed to pass some truck that was doing 60 on a 2 lane road-but unlikely I would ever feel that need
  2. waltermlee
    waltermlee Well-Known Member
    I agree the 3rd gen Prius HSI display/monitor needs to be under the PWR level band inorder for the Prius to get achieve better fuel efficiency. I want to emphasis that in hilly areas or in stop-n-go traffic driving environments, the Prius needs to be in Normal or PWR throttle/mode because the Prius needs to use the ICE sooner-than-later to avoid draining the Traction battery (this is less of a problem with the Prius Plugin).
    I didn't mention Warp Steath Mode because IMHO it really takes a FE gauge like the ScangaugeII or Andriod Torque to do it optimally - the Prius' HSI display (which is a aggregate power monitor) is often all over the place in Warp Steath mode. (9_9) I wanted to avoid suggesting anything that required special equipment. I found that Warp Stealth needs something more direct like an RPM/GPH xgauge to do well. I'm not against having a third party fuel efficiency gauge ....I've got two scangaugeII connected to my Prius (HyperDrive1) but my experience with most people is that its often a bit much .... just getting a driver to get and use a scangaugeII is a signficant jump in effort/committment toward fuel efficiency. Hence, my tendency to soft peddle ...
    I have not yet made it home but a few hours from now I will :)
    Charlie, the 0 to 60 times were posted in the following: http://www.cleanmpg.com/forums/showpost.php?p=368111&postcount=248
  4. Paymaster
    Paymaster Well-Known Member
    Wayne, you might find this amusing. It is blurry but the battery is full all the way to the very top. Even the post on the top is blue. I know, not the best but I was cold and had the heat on. Still working on the SOC for the scanguage. He just sent me something else to try. This shows 120% full. As soon as I have that I will post it. Oh, and yes the instant mpg is 7.9.
  5. xcel
    Hi Rich:
    You like seeing pretty colors or something ;)
    I finally got home and am going through over 400 e-mails (mostly junk) so should be catching up over the weekend. This includes the steady state graphs for all three.
  6. xcel
    Here is the 2012 Prius Liftback pkg. 5 Speed vs. Fuel Economy graph...
  7. xcel
    Here is the 2012 Prius v-3 Speed vs. Fuel Economy graph...
  8. xcel
    Here is the 2013 Ford C-MAX SEL Speed vs. Fuel Economy graph...
  9. RichXKU
    RichXKU Well-Known Member
    Excellent, how about a graph with all 3 ?
  10. Paymaster
    Well, on the bright side the C-MAX dropped the least from 50 mph to 70 mph. Have to always look at the bright side right?;)
    C-MAX 51.3 - 38.1 = 13.2 mpg drop
    Prius V 60.1 - 43.1 = 17 mpg drop
    Prius 65.3 - 45.5 = 19.8 mpg drop
  11. RedylC94
    Only because you're looking at fuel consumption inversely, per U.S. custom. Doing a little arithmetic with the same data reveals the C-Max actually had the largest increase in fuel consumed per mile with increasing speed, which is consistent with its higher aero drag.
  12. herm
    herm Well-Known Member
    +10
  13. xcel
    Hi Rich and Herm:
    I was working on the 3 vehicles combination chart when you posted.
  14. Paymaster
    Originally Posted by Paymaster View Post
    "Well, on the bright side the C-MAX dropped the least from 50 mph to 70 mph. Have to always look at the bright side right?;)
    C-MAX 51.3 - 38.1 = 13.2 MPG drop
    Prius V 60.1 - 43.1 = 17 MPG drop
    Prius 65.3 - 45.5 = 19.8 MPG drop
    Sorry, my sarcasm doesn't always come through so well.
  15. RedylC94
    Oh, I recognized the sarcasm, but still wanted to point out how "mpg drop" can obscure things. To be more specific:
    C-Max: 1/38.1-1/51.3 = .00675 increase in gallons/mile
    Prius V: 1/43.1-1/60.1 = .00656 "
    Prius : 1/45.5-1/65.3 = .00666 "
  16. herm
    Where is the plot of the Prius V with the 16" box strapped to the roof? :)
  17. xcel
    Hi Herm:
    The v's 16" x 16" box fit inside the rear hatch with room to spare ;)
  18. Gord
    Any idea how they compare at 40?
    Just interested.....
  19. xcel
    Hi Gord:
    That would not be easy to achieve as it is to slow a speed for the highway and too fast and short for most boulevards in suburbia let alone having to take into account the pack cycles. The C-MAX was a problem at 50 and 55 mph as I had to drive more than twice the normal 10 + mile distance to come across a SoC at 50% AND the elevation start and finish within +/- 10 ft. while on the I-10 in Phoenix.
    The least confidence I had with the above was with the v as it was turning from dusk to dark and winds were dying off on one side and picking up on the other while I was still acquiring data. I wish I could have completed all of the above at home as I know the elevation profiles within +/- 20 ft. over my 40 mile one way N-S and S-N route.
  20. Carcus
    Carcus Well-Known Member
