Saving Gas By Hypermiling
Discussion in 'Articles' started by xcel, May 11, 2007.
    CleanMPG Hypermilers Jeff Townsley (Psyshack) and Randall Burkhalter (Highwater) were featured on Tulsa’s Channel 6 News at 10:00.
    [xfloat=right][/xfloat]Scott Thompson - KOTV - May 10, 2006
    One hypermiler regularly goes 100 miles on one gallon of gas, and has even gone more than 1,500 miles on one tank of gas.
    As seen last night on KOTV - Channel 6 - Tulsa. Oklahoma Drivers Take Fuel Efficiency To The Extreme.
    Gas has dropped a penny, but it’s still almost $3 a gallon. It's not a record in Tulsa, but this week, the national average did hit a record $3.07 a gallon. In San Francisco, the price is over $4.30, and Monday some analysts were predicting $4 a gallon nationwide by summer. On Wednesday they upped that estimate to $5. Had enough? Well, Friday morning, pause before you blow past that car on the highway, and consider that the driver may be saving lots of money and gasoline, while you're not. News On 6 anchor Scott Thompson reports on the driving techniques of hypermilers.
    Friday afternoon and Jeff Townsley is beginning his drive home from work. Forty-two miles lie between his east Tulsa office and his Okmulgee home, but he's not dreading the trip. In fact, every time he gets behind the wheel, he sees it as his chance to stick it to OPEC. And he says you can, too.
    "So many of these tactics and techniques are so basic and so simple that all it requires is good vehicle maintenance and slowing down," hypermiler Jeff Townsley said.
    Jeff's what's known as a hypermiler, he's determined to squeeze the highest gas mileage he can out of his Honda Civic. And just two blocks into the trip, he starts saving money by shifting to neutral.
    "See, we've got a red light down here, there's not much of a reason to go after, we're just gonna shut the car off," said Townsley.
    Yep, he's turned the motor off, but kept the battery power on, and he's coasting toward the entrance ramp to U.S. Highway169. It's a trick he tries at every stoplight.
    "Ha, lookee there, we've got a green light," Townsley said.
    "So it's anticipation?" asked News On 6 anchor Scott Thompson.
    "Anticipation, timing, some of my hypermiling friends would have considered this too hot of an approach, but as a hypermiler I'm kind of on the hot side," Townsley said.
    Hypermilers like Jeff drive extremely focused. They always stay at the speed limit or below, and don't let the stares, gestures and honking bother them.
    "Now everybody's passing us. That's fine," he said. "Is that the way it always is?" Thompson asked.
    "That's the way it always is," replied Townsley. "When people are giving you hand signals and honking at you, you just grin at 'em because hey, you can get all mad and you're driving a car capable of 40 miles per gallon and you're getting 23, I know you are, hey, I'm havin' a good day, I'm pushing 50."
    "If you'd had told me I could have gotten 100 miles per gallon in a car, I'd have told you you were crazy," said hypermiler Randy Burkhalter.
    Over in Perry, the king of Oklahoma hypermilers is starting his commute, too. When Randy Burkhalter got a job in town, it meant a 90 mile roundtrip from his home in Blackwell. So he parked his pickup and bought a used Honda Insight, a hybrid gasoline-battery powered car. And then he learned the techniques of hypermiling, which means turning the long, lonesome highway into a roller-coaster, shifting to neutral, turning off the engine and letting inertia carry the car.
    "We're in neutral. We have no RPM's, we're at 42 miles per hour and our fuel economy across the bottom is pegged at over 150, this is instantaneous at the bottom, this is since we first began the trip 11 miles ago," Burkhalter said.
    Both men practice ridge riding. That's hugging the right-side white line. It keeps the car out of the ruts in the road, and in wet weather that saves gas. Both men also plan their routes to avoid construction, congestion, left-hand turns, backing-up, braking and traffic signals. For Jeff, it means taking back roads to avoid Glenpool's stoplights.
    "By and large, I stay away from it if at all possible," Townsley said.
    For Randy, Tonkawa's sole stoplight is unavoidable. So, he's mastered the art of watching for it blocks away, and timing his glide through the green.
    It was that route through Tonkawa last summer that Randy set a world record of 1,534 miles on a tank of gas. Then, Randy and five other hypermilers drove his little car around Tonkawa for 8 days straight, and on one 10.5 gallon tank of gas, they covered 2,255 miles, which they figure must be a record, too.
    Jeff finally pulls into Okmulgee and decides to fill-up and figure his mileage for his trip home, 47½ miles per gallon. He figures he could have hit 50 if the headwind weren't so strong.
    And Randy, home at last, says hypermiling boosts the Insight's EPA mileage more than 20%, he ends his trip at 105 miles per gallon.
    "That's pretty good. Take that, OPEC," he said.
    I know what you're thinking; sure, he's got a hybrid. But when that car was in the shop last month, Randy drove his wife's plain old Honda Civic to work, and using hypermiling techniques, he got over 60 miles per gallon.
    By the way, the Oklahoma Highway Patrol says coasting downgrade in neutral or with the clutch disengaged is illegal.
    Extended Interviews with CleanMPG Hypermilers Randy Burkhalter and Jeff Townsley.
    To learn how you can up your cars gas mileage, click here.
    Randall in rural Oklahoma - Hybrid cars and small sedans are the hypermilers car of choice, but they say even a Hummer owner can hypermile.
    Randall performing a FAS for the cameras - Hypermilers use extreme methods to save gas, like shifting into neutral and turning off the engine while driving.
    Hypermilers like Jeff say one way to save gas is take a route with the smoothest roads and fewest stops.
    Jeff Filling up - When you’re getting upwards of 100 miles a gallon you don’t have to fill up very often.​
    Trailer #1:
    Scott Thompson: What was your mileage on the trip home today?
    Randall: 105 miles per gallon even.
    Scott Thompson: A Group of Extreme drivers with secrets they’ll share.
    Jeff: It’s easily implemented with a little bit of practice in your daily routine.
    Randall: Anybody can do it in any vehicle.
    Scott Thompson: But there techniques can be controversial. So people hurl obscenities at them or do finger gestures. I am Scott Thompson, my special Report at 10:00
    Trailer #2:
    Scott Thompson: Tonight at 10:00, it doesn’t matter if your car is a classic or not, you can boost your gas mileage and beat record high process of the pump. Meet green country drivers who have mastered the techniques of stretching fuel economy every time they get behind the wheel and they say you can learn how too.
    Randall: I don’t listen to the radio. I am paying attention to the car, what the car is doing, the traffic ahead of me, behind me, the traffic that is approaching from both sides.
    Jeff: It will make you a better driver. You are more aware of your surroundings, the motoring public as a whole, what’s going on around you.
    Scott Thompson: Both those fellows have boosted their gas mileage more then 20% by paying attention behind the wheel. You can too, find out how. Tonight at 10:00 …[rm][/rm]
  2. Pravus Prime
    Pravus Prime Banned
    Re: Saving Gas By Hypermiling.
    Congrats guys! With gas prices constantly rising, I have a feeling that hypermilers will be getting more and more attention this summer.
  3. Chuck
    Chuck just the messenger
    Totally did not expect to see something like this in the morning.
    Well done Randy and Jeff!
    This will be a hard act to follow (possibility of Channel 11 in Dallas doing an interview)
  4. Earthling
    Earthling Trying to be kind to Mother Earth
    It was warm yesterday and I did hypermile my Prius, having my best result ever, around 54 mpg highway on an 80-mile trip. Hypermiling is nice.
    I celebrated by walking to work today.
  5. laurieaw
    way to go, guys. awesome interview, and it sounds like the announcer was putting things in a positive spin......:woot:
  6. Chuck
    When the temperature breaks around 65F, the improvement is apparent. :)
  7. Texashchman
    Texashchman Well-Known Member
    Great Job! kevin
  8. SlowHands
    SlowHands Hypermiling Ironman
    Great job both of you... and sure sounded like positive spin to me. Going to show all 3 video clips to my wife and kids, and people at work.
  9. Chuck
    A clip for Jeff, one for Randy....where is the 3rd one?
  10. noflash
    noflash Senior Member
    Congrats and well done!
  11. Bruce
    Bruce cheapskate
    Way to go, guys!
    So is speeding.
  12. philmcneal
    w00t go psyshack!
    although yes people fail to realize that speeding is a crime... but i guess its okay if EVERYONE DOES IT!!!!!!!
    if everyone is doing it.. it must be OKAY!!! what a ****** up mentally....
  13. diamondlarry
    Way to go Psyshack and Highwater!:Banane48:
  14. highwater
    highwater Well-Known Member
    Thanks to all of you.
    Jeff and I, were hoping Wayne and cleanmpg, would be proud parents.:D
    Scott Thompson, the anchor, sent me an email yesterday, for a response they were getting to emails at the station. It seems the increase in gas prices and the story may have connected. Here is part of the email....
    From Scott Thompson at News Channel 6 Tulsa,
    lower case xxx's randall.
  15. psyshack
    Randall and I really fretted over this.
    Im really glad it turned out as good as it did.
    Now if we just had a convert or 12. :)
  16. Chuck
    I'm happy this worked out well - given the tendacy to put hypermiling in a bad light.
    At the Live Green Expo in Plano last week, Dan sought out someone from Channel 11 in Fort Worth/Dallas and he seemed very interested in doing an interview this summer - Jeff and Randall have an excellent pattern to go by. Dan was telling me on his hypermiler talk the audience was really interested in ScanGage, but the moment he touched on slowing down, it was like kids reacting to parents telling them to eat their veggies. If interviewed, I'll try to find ways to make going slow less unpleasant.
  17. tarabell
    tarabell Well-Known Member
    Randall and Jeff, I finally watched the videos and wow were they good! The reporter could have played up the dangers just for ratings and they didn't. A real positive report. I remember the night this got posted I noticed a spike in visitors here and wondered what was happening.
  18. psyshack
    I tired to talk with the wife lastnight about trading her Accord for a HCHII for her. It fell on def ears. Told her to not whine at me when shes paying $5.00 a gallon for gas.
  19. johnf514
    johnf514 Zoom? Try Glide!
    Well done! I'm excited to see these kinds of segments being run on news stations - hopefully these kinds of things can be picked up my national programs (think of the exposure of a CNN/NBC/CBS/ABC segment!) and we can get this country to listen up and slow down. :)
  20. psyshack
    I got feed back lastnight from people in western Arkansas. It appears OETA in Oklahoma ran the news item. So folks that were watching OETA in western Arkansas saw it yesterday evening.
