CleanMPG Reviews the 2013 Hyundai Elantra GT
Discussion in 'Reviews' started by xcel, Aug 17, 2012.
    [​IMG]The all-new 2013 Elantra GT has proven itself cross country and now at its limits, creates a place it can call its own in the thin air.
    [fimg=right]http://www.cleanmpg.com/photos/data/523/Elantra_GT_at_Julian_Pie_Company_News.jpg[/fimg]Wayne Gerdes - CleanMPG - Aug 17, 2012
    2013 Hyundai Elantra GT with a remarkably smooth 6-speed stick at the Julian Pie Company in Julian, CA - $18,395 to start and a 27/39/31 mpgUS city/highway/combined rating. I bolded the combined number for a reason ;)
    When Hyundai revealed this little beauty at the Chicago Auto Show this past February, I knew it was going to be good. I just did not know how good?
    The Review
    Following on the heels of its stable mate, the 2012 North American Car of the Year winning Elantra sedan, the GT’s DNA was derived from “good stock”. The companies design language, Fluidic Sculpture, is not only modern and attractive but functional. By functional I am speaking about aerodynamically efficient without having to rely on a delta dart shaped exterior profile, complete under body covers, guide fins, strakes, tire dams and various shaped and oversized spoilers.
    In the Hyundai’s Elantra Spells “Continuous Improvement” write-up, the GT has proven itself to be an even better Elantra than the award winning Sedan from which it is derived. And it did so while maintaining the same smaller mid-size 96 cu. ft. of passenger volume and adding a bit more cargo volume at 23 cu. ft. (seats up) albeit more upright than prone.
    The following provides a comparison of the Elantra GT with its direct 5-door hatch competitors in the US.
    C-Segment Hatch Competitive Size Comparison
    Column1Column2Column3Column4Column5Column6Column7
    YearMakeModelPassenger Vol. (cu. ft.)Cargo Vol. (cu. ft.)Max Cargo Cap w/ Rear Seats down (cu. ft.)Total Interior Vol. (cu. ft.)
    2013HyundaiElantra GT962351119
    2012ToyotaMatrix942049114
    2012Mazda35-door951743112
    2012FordFocus 5-door912445110
    2012VWGolf 9315NA108
    2013 Elantra GT Maximum rear cargo area with the rear seats down.​
    The GTs wheelbase has been decreased by 2 in. while still allowing almost identical legroom of 42.0/34.6 in. front/rear respectively by comparison to the sedan at 43.6/33.1 in. front/rear respectively.
    2013 Hyundai Elantra Specifications
    The 2013 Hyundai Elantra GT is available in just one trim level with two available option packages, the Style (as driven) and the Tech package including NAVI and a backup camera. Complete specifications, pricing, standard, and optional equipment for the GT can be found within the 2013 Hyundai Elantra GT specifications page.
    2013 Hyundai Elantra GT’s Exterior Design – New look of Fluidic Sculpture
    From the front, the Elantra GT has progressed from the Elantra sedans hexagonal opening with small opening up top and large opening below separated by a body colored fascia piece to a large hexagonal grille opening with a twist. It now includes an attractive wider 2-bar chrome grille rising from the center to the top outside edges of the hood vs. the non-distinct 2-bar black grille work on the sedan. The hoods deep side creases are an extension of the profiles character line with the projector lamps and wraparounds lenses adding a modern approach to the C-Segment known more for bland proportions than cutting edge design.
    The 2013 Hyundai Elantra GT in Monument Valley, UT last month.​
    From the profile, the all-new GT is provided with Hyundai’s deeply creased character line beginning at the front wheel arch, running through both door handles and continuing smoothly under the wrap around rear lenses before disappearing into the rear bumper fascia. A chrome beltline accentuates the window sill and vehicles overall upscale appearance. The lower rocker panel crease and small but functional rear spoiler off the top of the rear hatch adds a futuristic appearance to the cars overall looks. In addition, the Style Package’s 17 in alloy wheels with chrome inserts are the best looking wheels I have seen on an automobile no matter the segment or cost.
    From the rear, the GT continues to provide a unique presence with a deeply creased character line running across the top of the rear taillights. The large rear Hyundai emblem is not just a badge but pivots to reveal a rear view camera when shifting to reverse gear on GTs equipped with the top of the line Tech Package.
    While some of its competitor have a particular side or angle that provides an attractive appearance, none can say they “look” great from all directions and any angle like the Elantra GT can.
    2013 Hyundai Elantra GT’s Interior Design
    The attractive exterior continues into the interior. The most conspicuous aspect appears vibrantly after the sun goes down. Most of the Elantra GT’s excellent tactile feeling driver controlled switches and dials are back lit in hues of red, blue and white making them easy to locate when it gets dark. In addition, the color scheme at night creates a youthful presence unlike anything in its class. The only control that detracts is the center mounted E-flasher triangle above the radio display. It’s “Red” and it is “Large” which stands out disproportionately as it probably should.
    Soft and high quality interior plastics abound. A class-above leatherette stitched hood over the instrument pod is standard equipment. Bright pewter colored accents borders the entire center stack, front vents and surrounds the door controls up to the sills.
    Looking closer, even the vent directional’s have a bright insert inlaid into them. The radio and ventilation control dials and manual shifter includes chrome like plastic surrounds adding to the Elantra’s appeal. The radio control knobs are a touch to small diameter for easy manipulation.
    Few of the well thought out additions are standard fare in competitors C-Segment offerings let alone at this price!
    2013 Elantra GT with the 6-speed AT interior shown.​
    The control stalks appear to be designed with intent and match up well with the best in the business Honda and Toyota pieces. The wheel controls are logically placed and mostly effortless to manipulate although the lower phone controls on the left and steering mode, trip and reset buttons on the right are cumbersome to operate due to their low wheel placement.
    The headliner is a rich looking fabric on foam backing vs. others in its class that appear shod with mouse fir on egg cartons. Even the sunshades with extensions have the same appearance and texture although it is obvious they are made from a plastic substitute.
    Speaking of sun visors, the map lights under the sun visors have switches that automatically shut off when you stow the visor in its flipped up position. You have heard me explain the virtues of this in previous write-ups on the Sonata, Sonata Hybrid and Accent before but I am doing it again because it is a fantastic design and should be emulated by everyone.
    While the aluminum overly on the accelerator, brake and dead pedals are nice looking, I found them to be a bit hard on the feet when driving without shoes as I normally do.
    The leather wrapped wheel and shift knob are to die for. Good diameter wheel and the leather is a smooth type without texture which I prefer over rougher textured leather most are equipped with.
    Storage? It is loaded! An honest to goodness sunglass holder at the top next to the sunroof controls, deep front and rear door map pockets, deep open tray beneath the center console, dual cupholders in the front central transom and fold down rear armrest, “A/C cooled” large glovebox, armrest storage box that the cover slides to accommodate both larger and smaller persons, front seatback pocket(s) and a hidden storage area beneath the rear hatch floor. Drop the 60/40 rear seatbacks and you can fit quite a bit of stuff you would not normally be able to carry in a sedan from any segment let alone any C-segment offering.
    Seating is possibly the most important attribute and is also a plus. At first I thought the seat back bolsters were a bit confining compared to the regular lightly bolstered Elantra sedan but after 2,000 + miles, I now prefer them. The lower cushions are long enough for most and the foam material is firm enough to prevent sagging yet soft enough to be comfortable over the long haul. Both the upper and lower seating surfaces are also heated for colder winter mornings some of us experience in the northern reaches.
    A 10-way power adjustable driver’s seat including power lumbar is available with the Style package and is another feature I suspect you cannot purchase from a competitor within the mainstream C-segment class.
    Finally there is the Style package’s panoramic sunroof. It’s HUGE when open! While I am not a fan of direct sunlight while behind the wheel, those that are will enjoy this class-exclusive feature even if the entire package’s content at $2,750 may seem a bit steep.
    Let the sun shine in.​
    All told, the GT is stylish and futuristic both inside and out. And it should scare the bejesus out of the C-segment competitors as most do not provide a total package like Hyundai has with the new Elantra GT.
    2013 Hyundai Elantra GT Drivetrain
    The 2013 Elantra offers a single drivetrain consisting of the award winning 148 HP MPFI 1.8L out of the current Elantra mated to either a 6-speed manual or 6-speed automatic transmission. I am sure some will want a more powerful mill for this “Hot Hatch” and when questioned about the addition, John Krafcik, President and CEO of Hyundai Motor America responded with the following:
    The 1.8L engines internals are what make it noteworthy as it is loaded with the very latest fuel efficiency and performance enhancements. These include:
    • Atkinsonized Dual Continuously Variable Valve Timing (D-CVVT) intake and exhaust valve control
    • Offset Crankshaft
    • 2-stage variable intake manifold
    • Electronic “Drive-by-Wire” throttle control
    • Roller swing arm and hydraulic lash valve adjusters
    In "clean car states", the Elantra GT is offered in a PZEV format with an unnoticeable loss of 3 HP and only 1 lb-ft. of torque.
    The 1.8L MPFI Elantra mill.​
    2013 Hyundai Elantra GT Ride and Handling
    The all-new 2013 Elantra GT is equipped with a sport tuned McPherson strut front end and lightweight V-beam with integrated 22 mm stabilizer bars that provide a handling solution superior to any Elantra that has come before it. Shod with lower rolling resistance Hankook Optimo H426s, the GT can best be described as “throwable” thanks to not only the new suspension and steering tune but its very light weight by comparison to other C-segment hatches. It reminds me of the Mazda3’s superb handling traits up to about 90% of its limits with predictable understeer after tire adhesion has been surpassed with no ill-handling or steering surprises on any number of road surfaces driven.
    Steering feel and linearity in particular is finally first rate with an all new driver selectable steering mode adding to the accolades. Coming out of the mountains with higher speed turns, I found Sport mode suited my needs best. Standard higher speed highway driving and Normal and Comfort modes felt best. Around town, Comfort mode made lower speed parking lot maneuvers thoughtless. Hyundai has really improved this area from previous Elantra sedans and I can only hope their future sedans will incorporate the new steering feel and user selectable mode hardware.
    Hard braking is both progressive and quick thanks to large discs on all four corners besting its main competitors 60 to 0 mph stopping distances by multiple car lengths according to Hyundai in-house test results.
    All in, the all-new Elantra GT feels “sporty” albeit ride comfort has been reduced by comparison to the sedan. Over rougher pavement stretches with pronounced expansion joints you will pay a small price for the superior handling. Over sharp angled curbs or really rough roads, the suspension will bottom out hard; regain composure and then top out with a lot of harshness and noise intrusion into the cabin. It is probably the only area that Hyundai should improve upon their strut front end and torsion beam equipped rear end as driven.
    2013 Hyundai Elantra Safety
    Active Safety features include Anti-lock Braking System (ABS) with 4-wheel discs, Electronic Brake-force Distribution (EBD), Vehicle Stability Management (VSM), Electronic Stability Control System (ESC) with Traction Control System (TCS), Brake Assist (BA) and a tire pressure monitoring system (TPMS).
    Passive Safety includes a passenger safety cell and body structure made of 57% high-tensile and ultra high-tensile strength steels plus front and rear door reinforcements. In addition, the airbag count has increased by one over the current Elantra sedan and coupe with front, side and side plus a driver’s knee airbag. Front seatbelt pretensioners and LATCH are also standard.
    The 2013 Hyundai Elantra GT has not yet been tested by the IIHS but the 2012 Elantra sedan earned a “Top Safety Pick”. I suspect the 2013 Elantra GT will earn the same. This does not include the new “small overlap front test results” for either the 2013 Elantra sedan or GT hatch.
    2012 Hyundai Elantra Sedan IIHS “Top Safety Pick”
    The 2013 Hyundai Elantra GT earned “5-stars” on the tougher 2011 NHTSA crash tests.
    2013 Hyundai Elantra GT Fuel Economy Results
    The first measured tank occurred on the All-American Road Trip described in excruciating detail in the link below.
    2013 Hyundai Elantra GT on an All-American Road Trip
    First measured top off to top off fill: 918 miles on 12.741 gal = 72.051 mpg.
    While the average driver will never achieve these results, the Elantra GT with its 6-speed stick is capable of taking out a Gen-III Prius on an all-highway drive at the limits which for an affordable hot hatch is pretty damn impressive.
    The second OEM average Fuel Consumption Display (aFCD) calibration drive was completed using basic and intermediate techniques in the following: Hyundai’s Elantra Spells “Continuous Improvement”
    Final measured top off to top off fill: 72.5 miles on 1.182 gallons = 61.33 mpgUS.
    From the first full measured tank when throwing the book at it on an almost 100% all-highway drive and the calibration drive loop using just the basics, we have a final 990.5 actual miles on 13.923 gallons = 71.14 mpgUS.
    For ScanGauge-II calibration, if you are driving advanced input a – 5.3% offset for calibration which includes the mileage offset. For basic and intermediate hypermiling techniques, you do not need to change the fuel offset but will need to change the speed/distance offset by 1.7%.
    2013 Hyundai Elantra GT – Maximum Effort Drive
    I have never experienced higher than triple digit mpgUS in a non-hybrid/non-diesel automobile. I have however experienced the following:
    • 220 mpgUS on a RT loop in a Honda Insight-I
    • 138 mpgUS in a Honda Civic turbo diesel
    • 136 mpgUS on a RT loop in a Prius-II
    • 126 mpgUS on a RT loop in a Prius c
    • 115 mpgUS on a RT loop in a Honda CR-Z
    • 105 mpgUS on a RT loop in a Honda Civic Hybrid-II
    • 100 mpgUS on a RT loop in a Prius-III
    And beyond triple digits for entire tanks in any number of Insight-I’s and Prius-II’s. I have reached 80 to a high of 99 mpg in Sonics, Accents, Rio’s, FFH’s, TCHs, HSH’s, Prius v's and even my old Ranger P/U truck. What has escaped me however are triple digits in a conventionally powered modern day automobile. Until now.
    The following drive was completed in the 2013 Elantra GT on a 2.25 mile RT loop that I circumnavigated 11 times over the period of about an hour and five minutes. The start and finish point were at the lowest point of the route and within 15 ft. of each other. This route has a number of quick hit alternates and paved maintenance lanes so in case of traffic; I could and did cut that drive loop short and turn around or pull over in a reverse pass. Conditions were absolutely perfect. Temperatures ranged from 73 to 79 degrees, there was no perceptible wind from any direction and traffic was extremely light.
    Because this is an advanced all-out drive, the 2013 Elantra GT’s aFCD does not record FAS mpg and stops at 99.9 mpg so I had to use a calibrated ScanGauge-II. Trip A/B and Odometer accumulate so I could use those for distance although they will record short by over 5% at this level of application.
    Drive start and finish location at 128 mpgUS and probably a little more given the shortage of miles recorded.​
    The Insight-I was a hybrid thoroughbred that has not been matched in terms of maximum range (2,254.4 miles on a RT single tank loop) or maximum MPGs at four times its EPA when it achieved 220_mpgUS on a RT drive loop. The Elantra GT will not come close to that range or actual mpg of course but it is the first modern day automobile that has surpassed its EPA by over four times its combined rating of 31 mpgUS. And it did so while ladened with the latest features and amenities plus is a blast to drive.
    2013 Hyundai Elantra Conclusions
    The Elantra sedan has been chided by the uninformed and those looking to make a quick buck for its lack of fuel economy prowess. The above results reveal something entirely different. As of this writing, I do not know if an all-out maximum effort drive in a conventionally powered North American automobile of any type available from any manufacturer can top what the Elantra GT achieved.
    Even on the all-highway drive I can only think of two other manufacturers B or C-Segment non-hybrid/non-diesel automobiles that “may possibly” best the Elantra GT. And this is Hyundai’s least efficient Elantra model!
    The improved steering, improved handling, improved throttle tip in response, improved NAVI, improved clutch and shifting action of the manual, additional features and amenities over the current 2012 North American Car of the Year was surprising. Think about it. Last year the 2012 Hyundai Elantra sedan was named NACOTY and today Hyundai offers the Elantra GT that is improved in a number of significant ways.
    I forgot to mention the GT is quieter than most of its competitors. My only issue is that this GT needs a headlight adjustment as they are set to low for good lighting of the road ahead during the overnight hours.
    The 2013 Hyundai Elantra GT at the Field of Dreams home in Dyersville, IA. It is indeed a dream… or was it :D
  2. Ophbalance
    Re: Can a Modern Automobile Reach 4X’s Its EPA? Apparently a Hyundai Just Did…
    Maybe, someday, I can hope to buy one of these with Hyundai's hybrid drive in it? Well, I can dream at least. My Prius isn't going anywhere for a for years anyway ;).
  3. killer6795
    killer6795 MazdaMiser
    Nice write-up Wayne. Argh, I keep going back and forth between the Elantra GT and the Mazda3 5-door SkyActiv.......
    Hopefully my current Mazda will live for many more years, but it's fun to dream.
  4. CRT1
    CRT1 Newbie McNewbster
    Wait for the CMax. Wayne is going to crush some numbers with that ride.
  5. ALS
    Hi Wayne,
    NICE :)
    Al
  6. PaleMelanesian
    128 mpg? Holy .... :eek:!!! I expect you're driving in a similar manner to what I do daily, so I might be able to top 100 for a tank? :D
    How's the rear suspension handle mid-corner bumps? Does it skip sideways? It's too bad they didn't use the i30's independent multi-link setup.
    I know you haven't done a full assault in the Mazda in good weather, or the Honda, but I'd really like to know how those stack up, both in handling and mileage.
  7. seftonm
    128mpg is crazy!!
    One thing though, the Golf's cargo area is plus/minus an inch or two of the Elantra's. The Golf's measurements must be with the cargo cover in place because I can't see plus/minus an inch making for 53% more space. Having that as a standard feature when some others do not seems to be a detriment on the spec sheet. I wonder if the 3 is the same way because its measurement looks pretty low as well. And at least from the EPA, the Golf's cabin is 94 ft^3.
    Also I have all those fancy chrome-like plastic bits too :p
  8. PaleMelanesian
    I think you're right about the seats-up cargo spec. The numbers are too far off for such similar-sized vehicles.
  9. PaleMelanesian
    My car is rated a similar 31 mpg combined. I've topped 100 mpg round trip commute only twice. At my estimated 92 mpg average at the end of this tank is 92% of max, thanks to daily driving challenges.
    This car at 92% of max gives 117 mpg. With its 14 gallon tank that's ... 1638 miles! Even if it "only" comes in at 100 mpg average that's still 1400 miles (plus whatever extra the tank can hold ;)).
  10. 2RR2NV
    2RR2NV Ultimate Newbie
    hmmm, is it even worth it to trade in LRE for that grey goose???? i know i wouldn't be getting the MT, but dang.....it's better in almost every way. showed the wife, she was quite smitten with it. she wanted a hatchback, but didn't like the looks of the Elantra touring... but the GT, a whole new ball game. her only gripe was the rims.... no likey. but big whoop.
    hmmmm
  11. WriConsult
    WriConsult Super Moderator
    Wow wow wow that is amazing. A cart that is far more capable of beating its EPA than most of its peers. Hmmmmmm ... what other car do I remember Wayne talking about that way? Oh yeah, the Civic. Hyundai really is the new Honda!
    Oh BTW, about the air conditioned glovebox: my Elantra Touring also has this feature. I hadn't thought much of it until our trip last month to Idaho, when we sweltered in 100+ temperatures for 5 days out of the trip. We kept trail mix and snack bars -- basically things with chocolate in them that would otherwise melt -- in there, and they stayed nice and cool when we were driving. Not a feature that I'd base a car purchase on, but it was GREAT to have for that particular trip.
    I'm still trying to wrap my brain around the cargo spec on this car. Seems smaller than competition like the Mazda3 and Focus 5-doors based on Wayne's measurements. And Wayne said the front-to-back cargo floor length is only 30", same as the Accent and several inches shorter than either the 3 or the Focus.
    It seems a LOT smaller than the Elantra Touring (rated 24cf by Hyundai, 28cf by the EPA) that it replaces, which was based on the longer version of the i30 platform. The only way I can figure they got the cargo up to 23cf was by lowering the load floor, which unfortunately means they switched to a design where you have to flip up the seat cushions in order to fold down the seats. In the Touring, to get a flat load floor all you have to do is flip down the seatback in a single motion that takes 2 seconds for each side.
    I'm still wondering if switching to the shorter i30 will prove to be a mistake on Hyundai's part, since this is a pretty small trunk for a starting price of $19k. It seems like they're going for a taller cargo hold like those in the Fit, Soul or the original xB, but those are/were MUCH lower-priced cars. I don't think the GT will be a sales flop like the current-gen Matrix since in other respects it's such an awesome car, but I do think the larger version would have been a better choice.
  12. diamondlarry
    Very nice! That is very close to what I have done in '07 Prius. I did 137+ on the Fuel Economy Championship course. However, getting 70+ on the highway is a ton of work in the Prius and...this car is significantly fewer $$'s. Hmm.;)
  13. xcel
    The 2013 Hyundai Elantra GT advert for Canada... And they even used Jeff Bridges voiceover for the English version.
    [flash]http://www.youtube.com/v/rV1MqUfrx-M?version=3[/flash]
  14. xcel
    I completed the steady state speed vs. Fuel Economy runs yesterday afternoon with the following conditions and results. Temperature was a balmy 72 to 74 degrees F and winds out of the SSE at ~ 10 mph forcing two direction measurement.
    North bound and south bound FE results were achieved by setting the CC at the target 50, 55, 60, 65 and 70 mph and running for a minimum of 10 miles with the same start and finish point elevation. The North and southbound results were than averaged and multiplied by 1.007 to match up with the distance and actual aFCD offset for an actual fuel economy result.
    The aFCD to actual offset was determined during the Elantra GTs second measured fill as seen in the following: Re: Hyundai’s Elantra Spells “Continuous Improvement” – Measured Fill Fuel Economy Results.
    Remember that the Elantra GT is rated at 27/39 mpgUS city/highway and for possibly the first time, a Hyundai essentially tied its EPA highway estimate at 70 mph.
    I will incorporate the Speed vs. FE results graph into the review itself in a few minutes.
    Let me know what you think of the graph based format? It takes a bit longer to build but may be easier to understand at a glance?
  15. RichXKU
    RichXKU Well-Known Member
    This chart (the blue line) is what should be printed on every window sticker!
    Much easier to see it in graph view.
  16. RedylC94
    I agree! City results should still be included. Although steady-state mileage is in some senses less realistic than the official highway test, it is a lot easier to understand, and makes the relationship of speed to mpg more clear, so it's a lot more useful.
    I had been eagerly awaiting this test. Thanks, Wayne. What happened to the 50 mph numbers?
  17. xcel
    Hi RedylC94:
    Darn it, my 50 mph data series was removed when I was manipulating the chart axis. I am in the process of rebuilding it with the 50 mph data. Thanks for noticing.
  18. sidewinder
    sidewinder Member
    Wayne,
    Do you have enough data to compile some stats for a Sonata 2.0T or just the regular 2.4L?
    Was wondering also if you have ever been stopped for going too slow i.e. 50 in a 70 ?
  19. xcel
    Hi Sidewinder:
    The Sonata with the stick we drove from Madison to NY City was for a short event drive and I really did not have the time to collect a full Speed vs. FE table or graph for it.
    2011 Hyundai Sonata “Challenge” - One day, 1,000 miles and just one tank of gas…
    And A few times to see if anything was wrong and never a ticket as I was am always legal while between the limits in the right lane. In the above case, there is a 4 or so miles of construction along I-94 just across the IL/WI border where I can get the 50 mph data. The 70 mph data is actually 5 over which is at the very edge of my envelope and tolerance for wasting fuel to provide data.
  20. ksstathead
    ksstathead Moderator
    This graph would make a great cell phone app. Make, model, engine, tranny, final ratio = bam. That would slow some drivers down. Of course, getting the data would be a bear, but even having a few of the fuel sippers and a few others where folks claim to do better at 85 or whatever...
