New Diesel Fuel Harmful to rubber gaskets?
Discussion in 'Volkswagen' started by bear15, Apr 29, 2007.
  1. bear15
    bear15 Well-Known Member
    Is the New Diesel Fuel Harmful to rubber gaskets? I spoke with a few Diesel mechanics who are reporting problems with the new Diesel Fuel in VW Diesel engines-- e.g. rubber gaskets & seals in fuel injector pumps degrade especially if the vehicle sits for longer periods of time.
    Any fuel additive suggestions?
  2. bear15
    FYI, I just heard back from a VW rep. that confirmed the below using carefully selected wording.
  3. BailOut
    The only thing in a fuel tank that I've ever heard of eating gaskets and other seals faster is Acetone, but AFAIK neither Diesel #1 or #2 have higher than usual levels of it, and biodiesel doesn't have any at all.
    It seems more likely to me that there is a problem with VW's gaskets rather than the fuel.
    Hi Ed:
    ___Besides the huge drop in Sulfur content for Road diesel (500 to 15 ppm), I have not heard of any other additives in US diesel fuel that would cause this. I did confirm through both a BWM and MB European engineer that US diesel fuel does not meet the European specs but I just have not heard there was a separate additive that could cause rubber degradation with the H2 addition in the cracking process for sulfur removal.
    ___Since we will not see the new VW Diesels here for another 2 years, I think VW has time to fix any problem hey may have found as of late ;)
  5. bear15
    A individual from Germany indicated that he has seen similar problems in Germany.
  6. seftonm
  7. bear15
