How many revs at 60mph
Discussion in 'The Daily Grind' started by Gord, Sep 5, 2011.
  1. Gord
    I thought I'd have a look at how many revs my FR-V does at 60mph, so I did it this morning and it was 1875.
    I was wondering how this compared with everyone else's after the discussion on the 2012 Honda Fit which was 2850!
  2. Blackbelt
    Blackbelt Well-Known Member
    Re: How many revs ay 60mph
    My Kizashi is around 1700 at 60, :)
  3. seftonm
    1600 in the Golf TDI
  4. Right Lane Cruiser
    2600 or so in the Elantra, 2000 in the Insight.
  5. alvaro84
    ~3860 with a BMW F650CS in 5th (4000 at 100km/h). Could use a sixth gear on the freeway, but I rarely go there now.
    ~6760 with a Hyosung GV250 (7000 at 100km/h). Being chain driven it's easier to make the gears taller. It may happen in the future.
  6. basjoos
    basjoos Well-Known Member
    1935rpm @ 60mph (2K @ 100kmh) in my 92 Honda Civic CX.
  7. lxmike
    lxmike Well-Known Member
    I'm not sure cause i haven't been over 50 in my insight. i'm probably a lil lower than sean because i have a slightly taller tire.
  8. SentraSE-R
    SentraSE-R Pishtaco
    ~2100 rpm @ 60 mph in my 2002 Nissan Sentra SE-R Spec V (6MT)
    ~2200 rpm @ 60 mph in my wife's 2006 Hyundai Elantra (4 AT)
    ~3200 rpm @ 60 mph in my 2006 Scion xB (5 MT) with OEM tires
    ~3000 rpm @ 60 mph in my 2006 Scion xB (5 MT) with 5.3% taller tires
  9. PaleMelanesian
    I'm at about 2600 in my Civic. It works for my 55-mpg-and-under commute but it's horrible on the highway.
  10. some_other_dave
    1990 CRX Si: 3000 RPM @ 60 MPH
    2011 MINI Cooper: 2400 RPM @ 60 MPH
    2011 MINI Cooper S: 2400 RPM @ 60 MPH
    2012 Fiat 500: 2400 RPM @ 60 MPH
    The last three I have driven recently.
    -soD
  11. fuzzy
    fuzzy Mild hypermiler
    At 60 mph:
    2500 rpm in 1986 Honda Accord (5MT, 2.0L)
    2700 rpm in 1997 Subaru Legacy GT (5MT, 2.5L)
    ~3000 rpm in 1989 Acura Integra (5MT, 1.6L)
    The last two are still in the household stable. The Honda left when the Prius was acquired.
  12. Gord
    Wow some big differences there, especially the bikes!
  13. JusBringIt
    JusBringIt Be Inspired
    160 hp (factory rating) 1999 Avenger V6: 2100rpms at 60mph
    140 hp (factory rating) 1997 Mitsubishi Eclipse GS I4: 2500rpms at 55mph. Not sure what it is at 60mph, however, it goes up 50 rpms for every mph increase (1500rpms at 35mph). That equates to:
    2750/too many rpms at 60mph
  14. Die2self
    2850 @ 60 MPH for the 2011 MT Honda Fit
  15. alvaro84
    These bikes are different enough themselves: a 650cc single and a 250cc V-twin.
  16. Kacey Green
    Kacey Green Well-Known Member
    under 2k in my HCH3
  17. Gord
    The VW Golf TDi seems to be the lowest so far at 1600. But low doesn't always seem to correlate with high mpg - just look at Andrew's 2600, that's the same as my OH's Honda Jazz/Fit 1.2 :eek: :D
    I've just read that the 1.2 (1246cc) engine has a taller fifth gear than the same year 1.4 (1339cc) and only 6bhp less!
  18. ItsNotAboutTheMoney
    Read Andrew's comment and you'll see that he wouldn't be getting his great mileage if he were driving at 60mph. ;)
  19. PaleMelanesian
    That's right. A highway trip with speeds above 50 mph drops my mpg from mid-80's to mid-70's.
  20. Gord
    I try not go above 55mph in the Jazz/Fit so I think I'll try 50 as a max. At some point will check it with the UG - cheers :D
